Anyone added exhaust tip to stock tailpipes?
Discussion in 'Performance and Tuning' started by ToyotaTundraMike, Feb 15, 2016.
  1. Feb 15, 2016 at 1:58 PM
    ToyotaTundraMike
    ToyotaTundraMike [OP] Not A New Member
    2015 Tundra
    Trying to figure out what size inlet I should order. The flared end of our stock pipes makes it difficult.
    Plan is to cut the flared portion off and install a black tip. Does anyone know what size the pipe is after you cut the flare off? Thinking I will probably need a tip with a 2.75"-3" inlet, but would like to know for sure.
  2. Feb 15, 2016 at 2:01 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Ill get that in a sec for you.
  3. Feb 15, 2016 at 2:08 PM
    csuviper
    Broomfield, CO
    OD is just under 2.75" for the main exhaust.
    The bigger flared end is 3 3/8" OD
    TXTundra89 and 5ive7even like this.
  4. Feb 15, 2016 at 2:19 PM
    ToyotaTundraMike
    2015 Tundra
    Sweet, thanks a lot Brian! Sounds like a little cutting and a bolt-on tip with a 2.75" inlet and about a 4" outlet will work for me.
    Now just need to get down there before I order and look to see about how long I will need it to be.
  5. Feb 15, 2016 at 2:21 PM
    csuviper
    Broomfield, CO
    No problem. Needed a break from work. Only one in the office.
  6. Feb 15, 2016 at 2:38 PM
    ToyotaTundraMike
    2015 Tundra
    MotoTundra likes this.
  7. Feb 15, 2016 at 2:41 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
  8. Feb 15, 2016 at 4:55 PM
    TruckLife900
    TruckLife900 I'd rather B hunting
    2013 White SR5
    Clean that thing! :p
  9. Feb 15, 2016 at 5:29 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I was thinking if I end up going with a BAMuffler I would want to go with a nice exhaust tip. I like the idea of everything all black, if I go that route, I think that is what I will do.
    You better post up pics!!
  10. Feb 15, 2016 at 6:58 PM
    Y0TA PR0
    Rafael
    2017 TRD PRO
    Haha I gave up trying to keep it clean With this crazy weather up here in Alberta.
  11. Feb 16, 2016 at 6:30 AM
    ToyotaTundraMike
    2015 Tundra
    Will do, check out this video. This guy wen't with all black, and even though the tailpipe is a different shade than the tip, I think it looks pretty sharp. This is the video that sold me on the 7" system.
    https://player.vimeo.com/video/95234359
  12. Feb 16, 2016 at 12:34 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    @ToyotaTundraMike that is a great video, thanks for posting the link! Also I think that all black combo looks great.
    Man I wish my pockets were deeper at the moment. Someday!
    ToyotaTundraMike[OP] likes this.
  13. Feb 16, 2016 at 2:43 PM
    ToyotaTundraMike
    2015 Tundra
    No problem man, it's one of the better videos I have seen on the BA exhaust. Asked the guy what he used on it and he hit the tailpipe with some flat black VHT flameproof header paint. Thinking about doing the same to mine. Wish I could find a spare tailpipe to mess with that way I can have everything ready to mount when the BA system arrives.
  14. Feb 16, 2016 at 4:21 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Yeah it looked good. It's under the truck so it doesn't need to match perfect. I see a lot of stock exhausts for sale on CL. You may get lucky.
  15. Feb 16, 2016 at 4:48 PM
    oil brother
    oil brother New Member
    MikeOMike
    Orange County, California
    2014 Crewmax
    3 & 1 Leveling kit W/ Pro Comp series 5183 Rims and Nitto Terra Grappler 305/55/20 Trimmed Bumper, modified inner fenders. Rhino lined Pocket style fender flairs and Rhino Lined dechrome grill, limo tinted back windows and front windshield visor. Weather Guard 127-5 Black Diamond plate Aluminum toolbox
    Cut the tailpipe flair, slip it in and tighten it up.DSC00107.jpg DSC00106.jpg Opp St n Truck 161.jpg
  16. Feb 16, 2016 at 7:11 PM
    ToyotaTundraMike
    2015 Tundra
    Looks good, whats the length of that tip?
  17. Feb 16, 2016 at 8:13 PM
    oil brother
    MikeOMike
    2014 Crewmax
    Thanks for asking, It's 9 3/4 x4" wide
  18. Feb 16, 2016 at 8:26 PM
    ToyotaTundraMike
    2015 Tundra
    Cool thanks!. The 10" by 4" wide one that I ordered should work out perfect then.
  19. Feb 17, 2016 at 9:58 AM
    csuviper
    Broomfield, CO
    Just go ahead and remove the tail pipe section and paint it up. I believe the muffler will be supported enough to stay on without the rear piping.
  20. Feb 17, 2016 at 10:28 AM
    ToyotaTundraMike
    2015 Tundra
    Nice thanks for the tip!
  21. May 15, 2020 at 8:49 AM
    tundranm
    tundranm New Member
    How did you guys cut the tailpipe? I see there are OEM exhaust tips out there but I want one a little longer so I don't have exhaust residue on the side. Once you cut off the flared end, then we are looking at 2.75 inlet correct?
  22. May 15, 2020 at 8:59 AM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    Do exhaust tips add HP or make a white Tundra go faster? :rolleyes:
    TXTundra89 likes this.
  23. May 15, 2020 at 9:20 AM
    1999cutiger
    1999cutiger Top Flow Lifestyle
    2017 Toyota Tundra SR5 4x4
    RBP 67R AK-8 20x9 wheels General Grabber ATX 275/60/20
  24. May 15, 2020 at 9:29 AM
    tundranm
    tundranm New Member
    That is the one that comes on the TSS. I don't mind the looks new but it sure is ugly after it gets some use. I want one that is a little longer so I don't have exhaust residue on the bumper and paint. This is what I just had to scrub off yesterday. I guess the previous owner didn't believe in washing that area. The rest of the truck looks perfect.
  25. May 15, 2020 at 11:15 AM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    Looking again, I think it's because yours is too long. It sticks out past the regular pipe. Is that welded on or bolted on? You're going to need that to poke out about 3 more inches to make it make a significant difference, and by then it would look funny. Anyway, I'm on my second Tundra and I clean them regularly, never had that issue. You might want to run it the way it is for a while to see if your maintenance habits will be sufficient enough to keep that from happening; and save you some coin.
  26. May 15, 2020 at 11:24 AM
    tundranm
    tundranm New Member
    It is bolted on. Hmm I don't know what the issue is but I don't like it haha. Either way I have to get rid of that ugly ass tip. These OEM tips might look great new but not after use. Maybe the black chrome OEM holds up better
  27. May 15, 2020 at 11:27 AM
    19TurdPro
    2019 Tundra TRD Pro
    What finish is the one that's on there?
    Any chance it can be removed and polished back to a nice finish?
    I'd cut about 3.5 inches of your OE pipe off and mount it back on, that way you can't see the OE pipe inside, and it recesses back under the bed a little. Driving down the road I doubt exhaust fumes are going to hit the paint. I'm guessing what you're seeing is a lot of paint neglect and idling.
  28. May 15, 2020 at 11:36 AM
    tundranm
    tundranm New Member
    It is this one that comes on the TSS (and I think TRD pro too). The paint comes off as soon as you touch it. I guess I could take it off and hit it with some high temp paint.
    https://trdshop.carlocktoyotaoftupelo.com/p-exhaust-tip-black-tundra-57l-2014--00012t183402
    Yeah, I guess this was a fleet vehicle. The rest of the paint/vehicle is in perfect condition which is why I bought it.
  29. May 31, 2020 at 4:17 PM
    BTundra1020
    BTundra1020 New Member
    Brandon
    2010 Toyota Tundra Trd
    BA exhausr
    Did this size tip end up working for you after you cut it? Will it fit my 2010 pipe if I cut flared end?
  30. May 31, 2020 at 4:43 PM
    Iowa12tundra
    Iowa12tundra New Member
    2012 tundra crew
    For me I ordered a 2.5 and it did not fit. I then tried a 2.75 and that worked.
