Anybody running 275/70/18's on their Sequoia's?
Discussion in 'Sequoia Builds' started by yeeyo, Dec 23, 2021.
  1. Dec 23, 2021 at 11:07 AM
    yeeyo
    yeeyo [OP] New Member
    Rodrigo
    11' Limited Sequoia
    OVtune
    Thinking of changing out our oem stock 20's and run the Fuel Vector 18x9's with a +20mm offset.
    Anyone else on here running something similar.
  2. Dec 23, 2021 at 11:13 AM
    S. Equoia
    S. Equoia New Member
    Ontario, Canada
    2015 Sequoia
    I have a set of 275/70r18 on my 2015 Limited with no lift. +45 offset. No issues.
    yeeyo[OP] likes this.
  3. Dec 23, 2021 at 11:15 AM
    yeeyo
    Rodrigo
    11' Limited Sequoia
    OVtune
    Have any pictures of your set up?
  4. Dec 24, 2021 at 7:52 AM
    farnsrocket
    farnsrocket New Member
    I’ve got 275/70/18’s on Method 316’s 18x9 with +18 offset. Fit great and no rub whatsoever.
    Here they are on stock suspension.
    And here they are with Dobinsons 1.75” rear shocks/springs and Bilstein 6112’s up front set at 2.78”
  5. Dec 24, 2021 at 11:59 AM
    yeeyo
    Rodrigo
    11' Limited Sequoia
    OVtune
    Thanks for the info. This is exactly what I was looking for and the route I want to go with. I’ve ran the 6112’s on our Tacoma and they’re great, definitely adding them to the sequoia.
    farnsrocket[QUOTED] likes this.
  6. Dec 24, 2021 at 12:29 PM
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    What tires? Looks great
  7. Dec 24, 2021 at 1:00 PM
    farnsrocket
    Thanks!
    Venom Power Terra Hunter XT’s :bananadance:
    I kinda took a chance in these cause they were super cheap and some reviews were not so good. They are made in Thailand. My friend who works for Cooper Tires was super butt hurt that I got them. :devil: So far they have been great and no complaints whatsoever! My buddies called them Gambler 500 tires :rofl:and told me good luck getting them to balance but they mounted fine and have so far made it on a loaded down Florida trip from Ohio! Got about 9k miles on them and am waiting to see how they do in the snow this year.
    Venom Power Terra Hunter X/T All-Terrain Tire - LT275/70R18 125/122R E (10 Ply) https://www.amazon.com/dp/B08D3BYLN5?_encoding=UTF8
    edit: I messed up the name, it’s fixed! :D
    Trdwillie14[QUOTED] likes this.
  8. Jan 14, 2022 at 4:45 PM
    yeeyo
    Rodrigo
    11' Limited Sequoia
    OVtune
    Waiting on the 6112’s
  9. Jan 14, 2022 at 5:58 PM
    farnsrocket
  10. Jan 15, 2022 at 8:01 AM
    yeeyo
    Rodrigo
    11' Limited Sequoia
    OVtune
  11. Jan 15, 2022 at 8:13 AM
    S. Equoia
    Ontario, Canada
    2015 Sequoia
    Those wheels were on my list when I was searching. Looks great, stoked to see it lifted!
  12. Feb 2, 2022 at 6:02 PM
    Sotoya20
    Sotoya20 New Member
    Adolfo
    2016 Sequoia SR5
    What setup are you running here(wheels,tires,suspension)? Looks perfect.
    yeeyo[QUOTED][OP] likes this.
  13. Feb 2, 2022 at 7:11 PM
    angkorstrong
    angkorstrong New Member
    2020 Sequoia TRD Pro
    is there a reason you guys went with 18in wheels instead of 17s?
  14. Feb 2, 2022 at 11:51 PM
    farnsrocket
    Personally, it seemed like only some 17” rims fit without issues and it seemed like the calipers were really close to the wheel, I didn’t wanna risk something getting wedged between them. Also, I am on the road for the most part, didn’t need the ultimate off road wheel tire combo. I feel the 18” is a nice compromise.
  15. Feb 3, 2022 at 9:20 AM
    yeeyo
    Rodrigo
    11' Limited Sequoia
    OVtune
    Wheels are Fuel Vector 18x9 with a +20mm offset
    Tires are 275/70/18 Ko2's
    Stock suspension.
    I am waiting on some bilstein shocks, but they're on back order.
    Hellrazor likes this.
  16. Feb 3, 2022 at 9:22 AM
    yeeyo
    Rodrigo
    11' Limited Sequoia
    OVtune
    If i am not mistaken, these vectors don't come in the 17's for the sequoia.
  17. Feb 4, 2022 at 6:09 AM
    Adamdsgn
    Adamdsgn New Member
    2018 Toyota Sequoia
    I think the bolt pattern on most 17s is not compatible with the Sequoia. It comes stock with 20s or 18s (pro model).
  18. Feb 4, 2022 at 6:38 AM
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    The same 17s that work on Tundras should work for Sequoias. Look at Icon and Method and they both provide hub centric 17” rims that look great.
    farnsrocket likes this.
