Anybody running 17x8.5 with +35 offset wheels have any issues with tires rubbing on frame?
Discussion in 'Wheels & Tires' started by brkncly, Feb 19, 2024.
  1. Feb 19, 2024 at 6:56 PM
    brkncly
    brkncly [OP] New Member
    Oregon
    I will be installing a 3” suspension lift. Wheels are Method 703s with a +35 offset and 6.20” back space. Haven’t decided to either go with a 34x11.50 or 35x12.50 tire. My question is with a +35 offset wheels, will the tires be rubbing on the frame or rubbing against any other components. If I have to, I’ll do a CMC so I don’t rub at full turn. I want my tires to not poke out that’s why I was thinking the +35 wheel offset. I had a shop tell me that the tires would be rubbing against the frame with the +35 offset wheels. Please help if you have any experience with this of any advice. Thanks!
  2. Feb 19, 2024 at 7:02 PM
    b6graham
    b6graham New Member
    2020 Voodoo 1794 RW Wheels 315/70
    Tires rubbing frame?
  3. Feb 19, 2024 at 7:22 PM
    brkncly
    Oregon
    That’s what I’m wanting to find out, if the tires will rub against the frame while doing a full turn with +35 offset wheels.
  4. Feb 19, 2024 at 10:12 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    May rub the skid plate, which is silly easy to fix.
    +35mm is a great offset for max clearance on our trucks. What shop told you otherwise???
  5. Feb 19, 2024 at 10:19 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    Bu to answer your question, yes. A LOT of people run exactly what you’re talking about.
  6. Feb 20, 2024 at 5:32 AM
    b6graham
    b6graham New Member
    yeah that would be my concern...what shop
  7. Feb 20, 2024 at 8:00 AM
    brkncly
    Oregon
    Yes they will rub the frame?
  8. Feb 20, 2024 at 9:13 AM
    Chad D.
    Chad D. New Member
    Western Oregon
    Shit. I did a poor job on that one!
    I meant they should work nicely. Every truck is a tad different, due to alignment specs, but it is unlikely that you will have frame contact trouble. Typically the only place people have contact with a high-positive offset (think OEM +60mm) wheel is a wide tire will hit the UCA. Then maybe the skid plate.
    It’s lower offset wheels that cause fitment trouble. Stay north of +18mm and you’re typically good. +25 to +30 for a 9” wide and +30 to +35 for a 8.5” wide wheel.
    equin likes this.
  9. Mar 5, 2024 at 6:07 PM
    bmtrujillo98
    bmtrujillo98 New Member
    Is anyone running 12.5” wide tires on a +35mm wheel with SPC upper control arms?
