Anybody know how to debadge without messing up the paint?
Discussion in 'Detailing' started by veg hed, May 22, 2016.
  1. May 22, 2016 at 5:02 PM
    veg hed
    veg hed [OP] Thug
    Utah
    2016 Ta-Tundra Barcelona Red
  2. May 22, 2016 at 5:21 PM
    Heat gun or blow dryer and use heavy fishing line to cut behind it.
    After, use goof off or something similar to remove the residue.
    Pro trip: use masking tape to tape around it before you remove it, so you know it's back in the factory location.
    veg hed[OP] and Okie like this.
  3. May 22, 2016 at 5:21 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    Guys here are using fishing string (kinda saw back and forth). Then use goo gone to get the sticky stuff off.
    veg hed[OP] likes this.
  4. May 22, 2016 at 5:36 PM
    r4z0r51o
    r4z0r51o have fallen off the forum, but I’m still alive.
    Dave
    Northeast San Francisco Bay Area
    2016 Silver Sky Metallic Crewmax 5.7L TRD 4x4
    22x12”HostileRage/33”NittoRidgeGrap/StealthFighter/FOX-BDS
    Like the others have said ... I used 20lb test fishing line using a see saw motion just behind the emblem. I didn't have to use any heat. Afterwards it was easy enough to just rub the excess tape off with my finger. I used a little bit of wax to clean everything before mounting my new emblem.
  5. May 22, 2016 at 6:03 PM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    I had a hell of a time getting mine off. I had to buy some 3m adhesive remover and still took a couple hours to get all that shit off! I'd like to order those black ones myself.
  6. May 23, 2016 at 5:04 PM
    Rkcruza
    Rkcruza New Member
    Bob
    2002 Tundra AC 4WD TRD OR SR5
    De Badged / Decaled, Firestone Ride Rite Air Bags w/ Daystar Cups, 17" Rims, Big Brake kit w/ slotted & drilled rotors, plus lots of work related stuff.
    The waxed Dental Floss also works very well...if you don't have a heat gun, Mama's blow dryer will help. No need to get things real hot, but if you warm it up it comes off much easier. Adhesive remover from the auto paint supply will get rid of the residue if it is being stubborn.
  7. May 23, 2016 at 8:26 PM
    Don't de badge. Keep chrome...............Seriously, do the above. Most success seems to be with fishing line and a blow dryer. (Don't use too much heat)
  8. May 23, 2016 at 8:41 PM
    veg hed
    veg hed [OP] Thug
    Utah
    Yeah, some good tips here. Next I'm going to figure out how to color match those bumpers.
  9. May 23, 2016 at 8:45 PM
    We have a heat gun at work that I use as a load to test Bio-Med safety analyzers. I vary the output to draw the required 10 amp load. It can get really super hot. A blow dryer should be OK. You might be able to get some one to color match your bumpers with some serious powder coat or Line X. A thought.
  10. May 23, 2016 at 8:47 PM
    veg hed
    veg hed [OP] Thug
    Utah
    I'm just thinking about having them painted if that's an option...
  11. May 23, 2016 at 8:52 PM
    Of course paint is a good option. I have a feeling you will be hitting WY outback. Sage brush and paint doesn't mix as far as longevity, let alone plasti dip. I've seen some Rhino'd/Line X'd bumpers and they looked good and should be highly resistant to scratches. I guess it depends on where you plan on taking your Tundra. (Budget too.) Someone else will chime in , I'm sure.
  12. May 23, 2016 at 8:54 PM
    veg hed
    veg hed [OP] Thug
    Utah
    Hmmm. Sounds like I have some options. I didn't even think about rhino line.
  13. May 23, 2016 at 8:59 PM
    You have a lot of options. Start a new separate thread about your concerns about bumper options. A lot of guys here have utilized what I have mentioned concerning what they did with their bumpers. Can't hurt.
  14. May 24, 2016 at 4:55 AM
    veg hed
    veg hed [OP] Thug
    Utah
    Yeah, I was going to do this for sure. A lot of good info on this site.
  15. May 24, 2016 at 6:50 AM
    Actually why not start a build thread? That way we can "help" address anything you need to know on one thread. My build thread is pretty much a dump all whatever thread anyways.
    veg hed[QUOTED][OP] likes this.
  16. May 24, 2016 at 6:58 PM
    Medic
    Medic New Member
    Ontario, Canada
    2014 Limited Crew Max
    If you check out my thread, I had my grille and hood bulge Rhino lined and it turned out great. It was also half the price I was quoted by the local paint shop to color match. Bugs come right off with little to no elbow grease and looks much more aggressive.
    veg hed[OP] and Black Wolf like this.
  17. May 24, 2016 at 7:07 PM
    I rest my case. So many folks here like @Medic know exactly what you may be looking for.
    Medic likes this.
  18. May 24, 2016 at 7:35 PM
    veg hed
    veg hed [OP] Thug
    Utah
    Copy that...I just ordered my paint matched TRD Pro Grill from Roman...I'll get on that build thread.
    Black Wolf[QUOTED] and T-Rex266 like this.
  19. May 25, 2016 at 5:00 AM
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    Go to a gas station car wash. Took me about 4 minutes of backing up and moving forward to get in between the sensors. And found out after that 1 of my badges had been torn off and a license plate cover torn in half.
    Black Wolf likes this.
  20. May 25, 2016 at 7:46 AM
    I hadn't thought of that.:frusty: When I got my Tundra I went to the drive thru car wash where I used to take my Taco. Didn't fit.
