Anybody fit 35's with 0 offset and Bilstein 6112 at 1.9" setting?
Discussion in 'Wheels & Tires' started by UTAHRTK, Mar 15, 2022.
  1. Mar 15, 2022 at 5:46 AM
    UTAHRTK
    UTAHRTK [OP] New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    Appreciate any details with regard to stuffing 35's with 1.5" lift and 0 offset wheels. While I'm here... anybody go spring under axle? Looking at Deavers; they provide 1" rear lift...Thanks
  2. Mar 15, 2022 at 6:30 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Don’t think that’s possible without a lot of cutting. I’m running a 295/55/20 on a +20 wheel at 1.9” and I still had to do some trimming to get rid of 95% of the rub. No way will a tire 1.5” taller and a 0 offset will fit at only 1.9”.
  3. Mar 15, 2022 at 7:42 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    That offset will be tuff. Sticks tires way out, hit body mount. +18 to +25 offset will be an easier fit.
  4. Mar 15, 2022 at 8:48 AM
    GT87
    GT87 New Member
    Greg
    Western NY
    White 2021 SR5 O/R CM
    295/60r20 Toyo ATIII, 20x9 XD 820, 3/1 ReadyLift Carven Exhaust
    I have 0 offset wheels and 34"s (295/60r20) with a 3/1 lift and I rub the front bumper (clear the body mount just fine). I had to remove all the front mud flaps and heated/pushed the front bumper liner forward and it still rubs a little in reverse. I just ordered some 1/2" front bumper spacers so hopefully that will do the trick. That being said, an inch larger tire and an inch less of lift you will at the very least have to do what I did and more would be my guess. Might have to completely remove the front bumper plastic and do a BMC as well. Will look badass though!
  5. Mar 15, 2022 at 5:24 PM
    UTAHRTK
    SOCAL
    Thanks- I think that 35s at 1.75' ish front height/ stock rear would look bitch'n. Im good with BMC but not sure if I'd have to cut the actual stock metal bumper (even if I shimmed it). I already trimmed the wheel well liners for the 295/70/17 (33.2 x 12); I have a slight rub in reverse hard turn on the plastic mud flaps but left them on and they have worn down. I think the 0 offset is great for clearing UCAs and a fairly aggressive stance but not for clearing body mount I pondered about 305/70/17 and maybe 315/70/17 but at that point I will cut and may as well go 35s. I am somewhat concerned with the impact on gearing- gears are not in the forecast any time soon- either is an aftermarket front bumper. One course of action I have is to have a shop here - The Truck Shop- do what is necessary to fit 35's.
    :spending:
