Anybody else find the 14" screen too reflective?
Discussion in '3rd Gen Tundras (2022+)' started by overl4nd, Oct 16, 2023.
  1. Oct 16, 2023 at 12:27 AM
    overl4nd
    overl4nd [OP] New Member
    During the day if my co passenger is wearing light colored clothes like whites or beige etc., I cannot see the screen if its too bright out, esp if the sun is shining on the co passenger. Its too reflective.
    Any solutions anyone has found? Its impossible to see the map at all at times!
  2. Oct 16, 2023 at 2:03 AM
    Blufin
    Blufin Seasoned member
    Bob
    Cape Cod,MA.
    23 Capstone
  3. Oct 16, 2023 at 2:57 AM
    TundraWorkHorse
    TundraWorkHorse New Member
    2023 Toyota Tundra Platinum
    Nope not at all . Does help if you change it to a dark theme and use a different wallpaper.
    Midnight Rider likes this.
  4. Oct 16, 2023 at 3:05 AM
    OLV1071571
    OLV1071571 New Member
    2024 Silver Limited CrewMax 5.5ft
    Also consider some made in the USA options for screen protectors. Or at least from friendly countries.
    I haven't seen it as an issue but my hood sure seems reflective. Much more so than my 2015 Silverado I came from.
  5. Oct 16, 2023 at 3:21 AM
    Blufin
    Bob
    Cape Cod,MA.
    23 Capstone
    Yes I too came from the same truck and noticed the hood,IForce Max badge and the passenger trims catching all kinds of light & it was a distraction to me at first but you'll get use to it.
    The Screen can be a bit to get use to because of the glare I ended up putting on the matte finish it almost is a duel cure,it eliminated the glare and it hides the paw prints when navigating on it.
    OLV1071571[QUOTED] likes this.
  6. Oct 16, 2023 at 4:15 AM
    nodak67
    nodak67 New Member
    JR
    have the protech kit with the 14" and the MID protector. get the matte version to cut down on glare/reflections. the MID install is a major pita. had bubbles on the first install for over a month, removed it and installed the 2nd one (i got the dual kit cause i suck at installing them). left the 2nd MID installed for over 3 months before all the bubbles disappeared.
  7. Oct 16, 2023 at 6:46 AM
    Kap1
    Kap1 New Member
    San Francisco, CA
    I've got 99 problems but the screen ain't one
  8. Oct 16, 2023 at 7:51 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    No reflection, but my entire truck is tinted
    Nomoredomestics likes this.
  9. Oct 16, 2023 at 8:01 AM
    Kawaski pro mule 22
    Kawaski pro mule 22 New Member
    East Texas
    22 model tundra 1794 MGM
    None
    Going toward sun in morning or afternoon sun reflection is rough off the hood.
  10. Oct 16, 2023 at 9:03 AM
    Bourbonator
    Bourbonator New Member
    North ID
    '23 LE CM 6.5
    I took the protective film off and immediately put a protective screen on, I've never noticed excessive glare or reflection.
  11. Oct 16, 2023 at 10:14 AM
    kirkb
    kirkb Lurking Member
    DFW
    2024 Tundra Limited 4x4 WCP Nightshade
  12. Oct 16, 2023 at 10:20 AM
    overl4nd
    thank you!Will go for the tempered glass one!
  13. Oct 16, 2023 at 10:50 AM
    TRDoffroadPRO
    TRDoffroadPRO New Member
    2023 Hybrid CM Limited TRD OFR
  14. Oct 16, 2023 at 11:20 AM
    PikesPeakTRD
    PikesPeakTRD New Member
    23 Hybrid Limited TRD OR MGM
    Not me either. Using some protector from Amazon.
