Anybody add fender flares to their RCLB 1GT?
Discussion in '1st Gen Tundras (2000-2006)' started by Crust, Jul 15, 2024.
  1. Jul 15, 2024 at 1:40 PM
    Crust
    Crust [OP] New Member
    06 4WD V8 RCLB
    Anybody add fender flares to their RCLB 1GT? Looking for input on adding OEM white fender flares to my 06 RCLB.
  2. Jul 15, 2024 at 2:34 PM
    The Black Mamba
    The Black Mamba He must increase, but I must decrease - John 3:30
    Ryan
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  3. Jul 15, 2024 at 2:44 PM
    shifty` In South Dakota Trouble ain't hard to find
    What you can add depends on whether you have ny bolt holes punched into the sheet metal, or whether you can find something you like that's installed with adhesives, or if you're willing to screw into the body.
    First determine: What do you have? Do yopu have punched provisions?
    If not .... Are you willing to punch provisions into the body? If yes, you can choose any OEM option, but you'll want to template off another truck to get spacing correct, or the flares will waffle.
    If not .... are you willing to screw into the body? If yes, you can use either the welt-style chrome strips that screw up under the lip of the fender edge like the Darryl Waltrip package used, or potentially find a screw-on aftermarket fender that installs with sheet metal screws.
    If not, you can choose any option that uses 2-sided adhesive, which is what some of the specialty packages used, potentially the X-SP trim package, the Ivan Allen trim package, or any number of aftermarket flares. Don't discount 2-sided adhesive, it's what a LOT of manufacturers use to hold on trim, flares, skirts, etc.
    BluegrapeVr6 likes this.
