Any value to oem calipers?
Discussion in '2nd Gen Tundras (2007-2013)' started by MacCTD, Aug 26, 2019.
  1. Aug 26, 2019 at 2:15 PM
    MacCTD
    MacCTD [OP] New Member
    2010 CM 4x4
    5100s
    I am replacing all my brakes on my 2010 Tundra with the Power Stop Z36 rotors, pads and calipers. My stock calipers work fine but are corroded and look terrible, 10 years old, 60k miles in the northeast. The place I purchased the stuff from has no core charge so I do not need to return them, doubt I will ever need them again.
  2. Aug 26, 2019 at 5:48 PM
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    3" Suspension lift 18" method roost 35x12.5x18 ridge grapplers 2020 sequoia LED headlights
    Depends on the market.
    I am actually looking for a set to rebuild and powder coat just for fun.
    Where you located :boink:
  3. Aug 27, 2019 at 3:40 AM
    MacCTD
    2010 CM 4x4
    5100s
    I am in MA.
  4. Sep 2, 2019 at 2:16 PM
    MacCTD
    2010 CM 4x4
    5100s
    Everything is changed out, I will put the calipers in the for sale section.
  5. Sep 2, 2019 at 6:17 PM
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    Post some pics of the new brake setup!
  6. Sep 2, 2019 at 6:47 PM
    MacCTD
    2010 CM 4x4
    5100s
    Went with the black powder coated calipers, only tricky part was threading the hard lines back into the front calipers, did a full flush of the fluid as well with a vacuum bleeder, fluid looked great for being 10 years old.
