Any turbo builds for 2nd or 3rd Gens?
Discussion in 'Performance and Tuning' started by Seanson, Jan 3, 2017.
  1. Jan 3, 2017 at 9:05 AM
    Seanson
    Seanson [OP] New Member
    2010 Tundra TRD Reg Cab Short Box
    So my buddy's trying to talk me into setting up a turbo on 2010 RCSB sr5 trd4x4 with the 5.7. A quick search on here didn't reveal much. I'm hoping somebody might have a few pictures of a decent set up.
    GNTundra likes this.
  2. Jan 3, 2017 at 9:42 AM
    sdhq_offroad
    sdhq_offroad New Member
    GILBERT, AZ
    For those numbers, I feel like a supercharger would be a much easier route considering they are both putting out the same numbers.
  3. Jan 3, 2017 at 10:12 AM
    Seanson
    Well ideally I'm hoping for a cheaper option then the TRD/Magnuson s/c.
  4. Jan 3, 2017 at 10:14 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
  5. Jan 3, 2017 at 10:27 AM
    sdhq_offroad
    GILBERT, AZ
    I am also a little biased towards superchargers as well because I'd rather have the power through the whole range of RPM, not just when I'm at 4K+
    Our shop Tundra also had an AEM water-methanol injection system
  6. Jan 3, 2017 at 10:55 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    Depends on the size of the turbo, a lot of OEM setups use small turbos so you get full boost/torque as low as 1500rpm.
    trayday and GNTundra like this.
  7. Jan 20, 2017 at 1:24 PM
    MAD
    MAD New Member
    We are currently in the process of putting twin turbos on a 07 Tundra 4x4 and as you are finding this is no easy task. We have been fortunate to find a great support of people and shops here and there to help move the project forward. It is a little late in the build but the transmission and engine have been built to handle everything these turbos can put out. Keep in mind this is a mild build, being its uncharted waters, not much previous knowledge to pull from and its going to be an everyday driver that has to run on 91 octane fuel in 110*+ Arizona heat. Here are few pictures from the fabrication shop.
    SuperSilverTundra likes this.
  8. Jan 20, 2017 at 2:16 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    For larger engines, I prefer superchargers all day. Instant power without the lag or extra plumbing.
  9. Jan 20, 2017 at 4:22 PM
    Mike Tread lightly.
    south carolina
    I hope the engine was pulled and the stock internals where changed if not good luck all I will say.
  10. Jan 23, 2017 at 12:24 PM
    MAD
    MAD New Member
    GNTundra
    My mistake the turbos snap gauged at 53.5mm, see picture and they are journal type. I would tend to agree with the simplicity of adding a supercharge from a kit but this owner wanted to be unique and he voted for turbos. I believe the TRD supercharging kit can still be bought from Magnuson and Toyota TRD will even install a safe tune.
    Plus if you want to keep the hundie from gettin snatched off the dashboard our vote is turbos.
    Yes the engine and the transmission both have been built to handle the anticipated HP of those twins. As for longevity its a fine relationship, when you want one higher the other will have to be lowered.
  11. Jan 24, 2017 at 9:17 AM
    MAD
    MAD New Member
    Building a custom intercooler....
    ColoradoTJ, Hattori and GNTundra like this.
  12. Jan 24, 2017 at 3:31 PM
    Seanson
    That's nucking futz man! Can I ask how much this build is guna cost ?
  13. Jan 25, 2017 at 7:40 AM
    MAD
    MAD New Member
    Seanson
    We would rather not say, but as you can imaging it's not a small ticket...built engine, built transmission and a custom one off turbo system.
    GNTundra
    I bet you would pay a hundred dollars for that show!
  14. Jan 25, 2017 at 10:15 AM
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    What tune are you guys thinking about running on this setup? Also, is it going to be able to run e85 and switch to 93? I've been planning my own system on gt2860rs turbos and AEM Infinity. Big part for me is getting the manifolds made and the IC piping . Finding the pistons and rods are quite simple since C/P will make the pistons and Pauter has the X-Beam rods. Did you guys balance the crank?
    Lot of questions but thats what happens when you want to vent into the atmosphere!
  15. Jan 25, 2017 at 11:36 AM
    MAD
    MAD New Member
    Hattori
    We're going to tune it on the dyno but Haltech might help us with a base tune. For simplicity we're only using 91 octane fuel maps. Yes, we internally balance the engine.
    Also if your looking for the same intake that's on the Dynosty rollers is was make by Sleeper Design.
    Hattori likes this.
  16. Jan 25, 2017 at 12:12 PM
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    Cool! Yea the Haltech will definitely do it. Would there be a option for me to just buy the manifolds from you guys outfitted with the flange(s) of my choice? T4 with a vband wastegate pipe?
  17. Jan 25, 2017 at 1:13 PM
    MAD
    MAD New Member
    Hattori
    I think we can work on something but let us get through this build first, that way we hopefully iron out most of the bugs.
  18. Jan 25, 2017 at 1:14 PM
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    Ill be waiting:thumbsup:
  19. Jan 26, 2017 at 10:26 AM
    MAD
    MAD New Member
    Stainless piping
    Hattori and TruckyTruck like this.
  20. Jan 27, 2017 at 1:22 PM
    MAD
    MAD New Member
    Piping the sequel, its about the same but more action
  21. Jan 27, 2017 at 1:27 PM
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    BEAUTIFULLLLLLLLLL!!!!
  22. Feb 1, 2017 at 10:42 AM
    MAD
    MAD New Member
    More progress and parts, we'd like to the Dynosty for the upgraded fuel system
    GNTundra, Mountun Goat and Hattori like this.
  23. Feb 9, 2017 at 7:50 AM
    MAD
    MAD New Member
    A few more progress pictures, for more of what we're doing you can take a look at our Instagram feed.
  24. Feb 9, 2017 at 7:51 AM
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    UM HMMM!
  25. Feb 9, 2017 at 8:51 AM
    Ardnut
    Ardnut New Member
    TX
    Now that this guy is covering the R&D cost, might be a kit in the pipeline? :devil:
  26. Feb 17, 2017 at 7:18 AM
    MAD
    MAD New Member
    Its been a minute since we've accomplished anything, therefore the lack of pictures. The driver side header took three revisions before it worked and could be pulled out without pulling the engine. I know most people would be fine with a one and done but we want this thing to be user friendly and serviceability goes along with that.
    Ardnut, there are places in the system that only have 1" of clearance so its not something were going to be able to mass produce, especially considering the driver side header.
    GNTundra and Hattori like this.
  27. Feb 23, 2017 at 4:21 PM
    MAD
    MAD New Member
    Couple more progress pictures
  28. Feb 23, 2017 at 6:52 PM
    Albertaundra
    Albertaundra aka...IgnorantlyAlberta
    David
    '16 SR5 crewmax TRD, '06 Taco walletbreaker
    Bone stock tundra...
    Hahaha yes!!!
  29. Feb 23, 2017 at 8:13 PM
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    Ohhhhhh that looks sequential!!! Do thine eyes deceive me??!!
  30. Feb 24, 2017 at 8:48 AM
    MAD
    MAD New Member
    Hattori
    There are not, in fact they are each being feed by one side of the motor. The tube you see between them is the outlet for the driver side turbo making its way to the passenger side fender, where it combines into one and off to the intercooler. These are true duals, each having there own exhaust inlet and exhaust outlet tubing.
