Any sort of sensor calibration required with an alignment?
Discussion in 'Suspension' started by vman82, Mar 27, 2023.
  1. Mar 27, 2023 at 2:20 PM
    vman82
    vman82 [OP] New Member
    2021 Toyota Tundra Crewmax Limited
    I have a 2021 Limited Tundra Crewcab. With all the safety equipment and sensors on the vehicle now, do you guys know if I can take my truck to get an alignment at Firestone or do I need it take it back to the dealership? Any sort of calibration required with an alignment? Any other advice otherwise? Thanks.
  2. Mar 27, 2023 at 3:19 PM
    FO LO
    FO LO New Member
    17 CM w/ 5.7 and 4.30s
    Wouldn't mess with sensors unless you modified the truck or you're having issues. For the alignment, is it warranty work or did you hit something?
  3. Mar 27, 2023 at 3:38 PM
    vman82
    Truck is completely stock. I hit a new curb that the city put up at a roundabout... A combination of no cones, rain, and low visibility... smh...sucks. Anyway, is it okay to get an alignment at my local Firestone or do I need to take it to Toyota. I'm unfamiliar with all the sensors (or calibrations if needed) that they put on these trucks. Does it require a special alignment machine?
  4. Mar 27, 2023 at 3:51 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The sensors didnt get knocked out, the physical alignment did id hit up firestone. Look up alignment, there are deep threads in which people have better luck with different specs than toyota lists
  5. Mar 28, 2023 at 4:17 PM
    vman82
    Thanks!
