Any regrets with 285/70/17?
Discussion in 'Wheels & Tires' started by ryderboy, Sep 14, 2022.
  1. Sep 14, 2022 at 1:06 PM
    ryderboy
    ryderboy [OP] New Member
    06 tundra sr5 double cab
    So I just put a 2” level on the truck with 1.25” spidertrax wheel spacers( I love the stock wheels). I’m running stock size 265/65/17 copper at3. To be honest I think it looks great. Now my worry is I have a set of 285/70/17 maxis razr at’s sitting in the garage and just by looking at the truck now it seems like they will be to stuffed. Does anyone wish they went with a 265/7017? For looks or performance wise?
  2. Sep 14, 2022 at 1:06 PM
    ryderboy
    The truck is a 06 double cab btw
  3. Sep 14, 2022 at 1:16 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Stuffed? Pics?
    Bikeric likes this.
  4. Sep 14, 2022 at 1:29 PM
    ryderboy
    Stuffed as in just looking to big inside the wheel well
    Jack McCarthy likes this.
  5. Sep 14, 2022 at 1:55 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    I have 285/70/17 ko2s on a 06 double cab. I rub on the frame with a full lock to the left only. I added the spider spacers for a -38 offset and took them off after 5 min because the tires rubbed too much. Please note that was after a lot of cutting. My original offset was 0 on my methods, I also have camburg upper arms to help with alignment.
    After seeing a few trucks at off-road meets. The 06 double cab has different clearance than AC/other years around the body mount locations
    Sirfive and shifty` like this.
  6. Sep 14, 2022 at 2:12 PM
    ryderboy
    So it sounds like I’ll be doing some trimming. I expected that though. I had to do it on my last 4 trucks so I’m not a stranger to it. I guess I’ll just wait and see. I’ll get them mounted next week. I just hope it’s not stupid amounts of cutting or I’ll drop down to a 265/70. I know I’ll definitely have to take off the mud flaps cause it’s about an inch away now with the wheel spacers on
  7. Sep 14, 2022 at 2:21 PM
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    That sounds like alot of work to me. It might be better if I just take those Maxxis tires off your hands.........
  8. Sep 14, 2022 at 2:31 PM
    ryderboy
    Haha I was very impressed by how aggressive they are in person. I looked for as many reviews as I could but they never looked very aggressive but always got good reviews. I’m hoping they perform well in winter. My coopers are old, hard and starting to dry rot. They are horrible in the rain
  9. Sep 14, 2022 at 6:56 PM
    Cummins3500
    Cummins3500 Never finishes.....
    Logan
    Damn I loooked at those maxxis razors hard before I decided on my general grabbers
    [*added per request :thumbsup:, 265/75/16’s bfg all terrains same wheel specs posted below]
    Top setup
    *Wheels: 16x8, 4.5 back space, 0 offset
    *Suspension: leveled on coil overs, no rear lift
    * spidertrax 1.25in wheel spacers
    *285/75/16 general grabber x3’s
    * pinch weld trimming and hammering
    bottom setup
    *Wheels: 16x8, 4.5 backspace, 0 offset
    *Suspension: leveled on spacers, no rear lift
    *265/75/16 BFG all-terrains
    *no rubbing
    Jmpell and shifty` like this.
  10. Sep 14, 2022 at 7:03 PM
    Got any pics of the bottom setup in the daylight? Kinda hard to see how much meat is showing.
    I'm wondering if 275/75/16 wouldn't be a perfect median for no-rub-no-hammer with a decent amount of meat.
    Your overall tire diameter is basically where @bmf4069 is with his truck right now (32.8") except he's running 255/85 R16 tires, though his sidewall looks not quite as tall:
  11. Sep 14, 2022 at 7:16 PM
    Cummins3500
    Logan
    added one @shifty` same specs and tires as the bottom, just a shot when I swapped to methods. Pre suspension over haul and tire upsize. Trucks been through a few iterations.
    @ryderboy I can post you some shots of that tire size he’s mentioning on a first gen sequoia. My wife runs that size on hers with aftermarket wheels
  12. Sep 14, 2022 at 7:24 PM
    Thanks. And sorry OP, not trying to hijack your thread. The overall size of his tires are actually in the ballpark of what you're looking to install IIRC, although I'd really need to crunch the numbers to figure out how that 20mm difference in height with same aspect ratio would actually pan out for width and all.
    If I were to swap up and go with aftermarket wheels, the end result I'd prefer to go for would be something like what I photoshopped onto @FirstGenVols' truck a while back. I'll have a hell of a time trying to figure out what tire size would get me here on 16s though. :rofl:
  13. Sep 14, 2022 at 7:36 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    2” Lift, Bilstein 5100’s and 885’s second notch, Rear 5100’s Icon 3 Leaf Pack and Firestone Air Bags w/Daystar Cradles. Spider Trax 1.25” Wheel Spacers, 4Runner Pro Wheels, Falken AT3W 285/75r17 (34x11).
    Scotty P has no regrets…
    My next size will be 285/75r17 like 34.5” I’ll make them fit.
  14. Sep 15, 2022 at 3:22 PM
    ryderboy
    Well I’m putting them on Monday so I’ll post pics. I guess I don’t care to much about trimming.
    I forgot to mention I did put on the front sumo springs about 2 months ago and they are amazing. It didn’t change the ride to much but it does get rid of a lot of body roll. Just in case anyone was wondering if they should get them or not I think they are definitely worth it.
  15. Sep 23, 2022 at 1:58 PM
    digitalferg
    digitalferg New Member
    Wandering the Wild West
    2006 Tundra DC TRD 4x4
    While we're on the subject of 285/70/17s... What load range do ya'll run on these trucks? I've got an '06 DoubleCab. Would ya'll recommend 6-ply C load range? --or 10-ply E Load range?
    I'll be doing plenty of highway, but for sure plenty of offroad. Prob like 80/20. But no heavy hauling or trailer, just people and camping and fishing gear.
    I'm leaning towards C load 6-ply for cost savings, but if the E's are more highly recommended for the DC, I'd go Es. I ran E rated 255/85/16s on my 1G Tacoma DCs in Cooper and BFG and the BFG was tolerable, but the Coopers were harsh beasts for the lighter Tacoma.
  16. Sep 23, 2022 at 3:15 PM
    ryderboy
    I have always ran e rated tires. I haven’t always needed them but I figured a more robust tire is always better on a truck. I never really noticed any negative side effects of them. That is until this truck. Idk if it’s the weight of them or the size but I did notice a sizable reduction in power. My other trucks have had plenty of power to turn whatever tire I put on besides my Tacoma which was the worst truck ever. I only had it for 6 months. My stock size coopers were e rated and it was fine on the tundra. So maybe a 265/70/17 would be better
  17. Sep 24, 2022 at 8:13 AM
    Casper421
    In the woods
    06 DC
    285/75r17 is around 33.8”
    285/75r18 is around 34.5”
  18. Sep 24, 2022 at 6:15 PM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    I run SL on mine strictly for power and gas mileage. My truck is really just used to get me to any moto or mountain bike trails though. From what I have seen C and E basically weigh the same and kill the already bad gas mileage and rob that 4.7 power.
  19. Sep 24, 2022 at 6:26 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Whats the goal? Go anywhere, do anything? Look cool in parking lots? Mud? Sand? Rocks?
    Sure, id like a truck that can get to the same place my 2wd atv can get, but as a daily, i'd prefer 18mpg (4x4) over road noise. I've got a buddy that likes to wheel his shit, and would love to hang, but most of his advantage is sliders. If i got rid of my bitchelins, and had a manly 31, it wouldnt have too much of a disadvantage against the 33's. And 35's need a more dedicated build than i'd go for, since a dirtbike can usually go where 40's cant.
    txagg likes this.
  20. Sep 24, 2022 at 8:08 PM
    Hummer
    Hummer New Member
    2023 Tundra CrewMax Limited 19K miles
    Studs Baby, Studs!
    Fwiw, I bought a set of FJ Cruiser wheels with 285 70R 17 Wrangler DuraTracs. Great tires but they are too big for the stock wheel configuration and I need space in the wheel wells to mount tire chains when necessary. So, I took off the DuraTracs and mounted Nokian 265 70 17 studded snow tires and have the Wranglers up for sale. https://boulder.craigslist.org/wto/d/ward-goodyear-wrangler-duratrac-lt285/7538039617.html
  21. Sep 30, 2022 at 4:27 PM
    digitalferg
    Threw on some 285-70-17s with Sequoia wheels that I found on FB market for pretty cheap. Didn't want to spend $1500 on new tires just to figure if I'll regret it or not. Heh.
    No regrets so far. :cool: (well, other than I had already bought the same damn wheels separately from a wrecking yard a couple months ago so now i have two sets....)
    Gotta massage the inner fender a bit still. Hopefully these run ok and last a decent while.
    abcinv and txagg like this.
  22. Sep 30, 2022 at 4:31 PM
    Hummer
    Hummer New Member
    Studs Baby, Studs!
    They look brute, and those are nice wheels.
  23. Sep 30, 2022 at 6:45 PM
    Best OEM wheel choice for these trucks. Better than a lot of the aftermarket.
    I still need a full size spare.
    abcinv and digitalferg[QUOTED] like this.
  24. Sep 30, 2022 at 7:52 PM
    digitalferg
    Agreed. I love these wheels on these trucks and any Toyota of this era/vintage. They look awesome, IMO. I just missed out on a set of Hyper Silver ones last week. I like those even more.
    My other set were junked up chrome so I had them sandblasted and I painted them black. I'll prob put them on eventually, but for now I'm digging it.
    There's another set near me the guy is asking $75 for four. I prob should just scoop them up for the good of the people. Heh
    Sunnier and shifty`[QUOTED] like this.
  25. Sep 30, 2022 at 7:56 PM
    I've got the hypersilver, that's what I need a spare of. I've only seen two sets around me for sale, most recent one was $500 with "fair" condition tires. If it would've been $300, I'd have bought, I can keep one and sell the other three for $100/ea, no doubt. I need to go back and see if they ever sold, maybe kick 'em an offer.
    But yeah, I've called up 3 different junk/salvage places who supposedly have these in stock, and all three times, they've been the darker Sequoia ones. Big part of the reason I finally said "screw it" and went into passive hunting mode.
    I really wish I'd had asked my dad to pick up the full set I saw listed in Dothan AL several months back for $150. I just didn't want him to make an hour round trip to buy stuff off a Craigslist stranger.
  26. Sep 30, 2022 at 10:21 PM
    digitalferg
    Hyper Silver is not the darker Sequoia ones? I thought that was one-and-the-same... Though I did wonder why they were called Silver when they were more gray...
    The ones I just picked up on my truck came from a Sequoia. Dude I bought them from was calling them "sparkle silver"... they don't seem that sparkly to me...
    So what is this one? This is the set for sale near me for $75....
  27. Oct 1, 2022 at 11:09 AM
    That looks like the one on my truck, which I'm pretty sure is hyper silver.
  28. Oct 1, 2022 at 2:17 PM
    Hummer
    Hummer New Member
    Studs Baby, Studs!
    Yes, that's the OEM wheel that came on my '03 Tundra. Some that I see on the older Sequoias are more of a lustrous silver gray. They're a handsome wheel too. Anyone know what the color was called?
  29. Oct 1, 2022 at 2:20 PM
    I believe the Sequoia was called hyper grey (not 'gray') or dark hyper silver, and the Tundra's just hyper silver.
    Hummer likes this.
  30. Oct 22, 2022 at 4:58 AM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Georgia
    2006 Tundra 4X4 Limited Dbl Cab
    Late to the party but here's the difference in the two -
    Hyper Silver
    Seen them called Gunmetal and Charcoal
    Small pic, zoom it for the different shade
    I believe there was a chrome version also...
    FirstGenVol likes this.
