Any recommendation on brakes for a 2010 DC 5.7L
Discussion in '2nd Gen Tundras (2007-2013)' started by ttflier, Nov 29, 2018.
  1. Nov 29, 2018 at 8:44 AM
    ttflier
    ttflier [OP] New Member
    Jack
    2010 DC 5.7
    So my next project is to update the brakes on my Double Cab, 5.7L V8. Brakes were done in the past, but I currently have just shy of 140K and when I changed out the wheels recently, my inspection of the pads revealed they were worn almost down to the audible sensor and the rotors measured .049. I am also getting a slight pulsating in the steering wheel when braking.
    I used a set of Powerbrake Z36s on my last truck and was happy with them, however I do plan to tow a small 5th wheel and was wondering if I am best sticking with OEM rotors and pads (my Tundra does have the factory towing package)? Are there better options available?
  2. Nov 29, 2018 at 6:03 PM
    FXFormat
    FXFormat New Member
    I overhauled my whole braking system, i just used Carquest platinum pads and rotors, so far so good, stops great, no noise, and doesn't shake. I got new calipers too, one of the piston was seized on each caliper.
    Stormtrooper81 and groverdill like this.
  3. Nov 30, 2018 at 2:10 PM
    el_taco
    el_taco New Member
    Whoa...that after pic looks clean...did u get it undercoated as well?
  4. Nov 30, 2018 at 2:17 PM
    FXFormat
    FXFormat New Member
    I just wirebrushed the frame and hit it with some undercoating spray to protect against the NE winters.
  5. Dec 8, 2018 at 7:50 PM
    throttlejock
    throttlejock New Member
    Seth
    Stoptech rotors - blanks or slotted, and EBC Yellow Stuff pads. Take the bed-in procedure seriously and you'll be left with a strong set of brakes that dont stink and fade like the stockers. I went with a more aggressive pad setup last time around, carbotech actually makes a street/track pad setup thats hugely aggressive but the pads killed a set of rotors in less than 10k miles.
  6. Dec 8, 2018 at 8:10 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    DBA Survival Series T3 rotors
    Hawk pads
    :thumbsup::thumbsup:
  7. Dec 8, 2018 at 8:16 PM
    Dabutcher
    Dabutcher New Member
    D
    Twin Cities
    2022 Tundra 1794 Supersonic Red
    Nitto Ridgegrapplers 175/60/20
    Went with oem Genuine Toyota rotors. First set lasted 98k miles. Good enough to go with again. Good luck. D
    Stormtrooper81 likes this.
