Any recommendation on brakes for a 2010 DC 5.7L
Discussion in '2nd Gen Builds (2007-2013)' started by ttflier, Nov 26, 2018.
  1. Nov 26, 2018 at 10:10 AM
    ttflier
    ttflier [OP] New Member
    Jack
    2010 DC 5.7
    So my next project is to update the brakes on my Double Cab, 5.7L V8. Brakes were done in the past, but I currently have just shy of 140K and when I changed out the wheels recently, my inspection of the pads revealed they were worn almost down to the audible sensor and the rotors measured .049. I am also getting a slight pulsating in the steering wheel when braking.
    I used a set of Powerbrake Z36s on my last truck and was happy with them, however I do plan to tow a small 5th wheel and was wondering if I am best sticking with OEM rotors and pads (my Tundra does have the factory towing package)? Are there better options available?
  2. Feb 6, 2019 at 7:17 PM
    Vince
    Vince New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    I used the power stop break kit with slotted rotors and heavy duty break pads tow my 35.6 foot camper not break fatigue.
  3. Feb 6, 2019 at 7:18 PM
    Vince
    Vince New Member
    Vincent
  4. Feb 14, 2019 at 9:38 AM
    rodneysworld
    rodneysworld New Member
    rodney
    2011 charcoal gray tundra
    series 77 K n D intake, rims and tires, KYB shocks, leveling kit, drilled slotted rotors, carbon fiber pads, interceptor tuner, flomaster catback dual exhaust, Spider halo projector headlights, Pioneer head unit, JL Audio Amps, JL Audio allaroundSpeakers
    I also have Power Stop slotted Rotors and carbon fiber pads I love em
    No need to upgrade calipers because tow package comes w upgraded calipers
  5. Feb 14, 2019 at 10:07 AM
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    you guys with PowerStops - are they Z36 or Z23
  6. Feb 14, 2019 at 10:13 AM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    I did StopTech Cryo Slotted Rotors in the front and Centric Premium Rotors in the rear (StopTech are Centric Premiums that get slotted and cryo treated). Did Hawk LTS pads all around. Prepped the hubs good with wire wheel/3M resurfacing tool to fit around the lugs. Applied anti-seize to the mating surface on the hub and rotor. Couldn't be happier with the performance. Pads grab like crazy. If I stomp on it
  7. Feb 14, 2019 at 10:23 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    I'll most likely go with factory B R A K E S when it's time, unless Toyota has let it's Beancounters "chince-out" on them by that time. I have 81,000 miles on my 2010 and according to my Mechanic, I should get 100,000 miles with my stock BRAKES.
    Mnorris1206 and DalTee like this.
  8. Feb 14, 2019 at 9:01 PM
    Vince
    Vince New Member
    Vincent
  9. Feb 14, 2019 at 9:15 PM
    bensky
    bensky PlatinumPro
    Ben
    Utah
    2018 Red Platinum Tundra
    I use the Toyota pads. They’ve always lasted forever and are always quiet. I live in a hilly area so rotors are always a problem. I found Frozen Rotors cryogenically treated rotors. They last about two to three times as long as the stock rotors.
  10. Mar 12, 2019 at 2:45 PM
    Yodder J
    Yodder J New Member
    Northwest Arkansas
    2011 Silver Tundra SR5 4WD DC
    DAP Tune, Truxedo ProX15 bed cover, WildPeak AT3s
    How do you know if your Tundra has the tow package?
  11. Mar 12, 2019 at 3:48 PM
    CMB
    CMB New Member
    Cecil County MD.
    If you have the 5.7 V8, you'll see a cooler in front of the Radiator and a 7 Pin Connector for a Trailer. With that package you'll have 4.30 gears + a heavy duty alternator maybe even a heavier flasher for signals and probably some stuff I forgot.
  12. Mar 12, 2019 at 4:57 PM
    bfd300
    bfd300 New Member
    Search E-bay for brakemotive I been using the for years. All my vehicles and friends use them. Drilled and slotted rotors, ceramic pads. Great stopping power.
    Texas Bandit likes this.
  13. Mar 12, 2019 at 5:02 PM
    Mnorris1206
    08 tundra
    You probably can I just done my brakes @82k on my 08 but they where really close because I also pull a camper so I think it was definitely time
  14. Mar 12, 2019 at 6:40 PM
    I have the Power Stop Z36 kit and I am very happy.
  15. Mar 13, 2019 at 5:13 AM
    CMB
    CMB New Member
    Cecil County MD.
    OK, time for a Coffee BRAKE.
    Mnorris1206[QUOTED] likes this.
  16. Mar 13, 2019 at 5:26 AM
    Mnorris1206
    08 tundra
    BRAKES LOL they are used for stopping vehicles Haha
  17. Mar 13, 2019 at 6:07 AM
    CMB
    CMB New Member
    Cecil County MD.
    Not according to some of the posts I see hereo_O
  18. Mar 13, 2019 at 6:15 AM
    Mnorris1206
    08 tundra
    Yep I fixed mine. Talk to text messes me all up.
  19. May 1, 2019 at 9:27 PM
    steve-smith
    steve-smith New Member
    2019 Toyota Tundra
    310 to 381 hp
    I have a 2008 Tundra with few issues however I wasn't able to locate any cut wires and cleaning the battery terminals and ground did not solve this issues. After I start the truck, the first time I hit the brakes it sounds like the ABS grinds. Then all the lights are back on. What’s the problem here? Any suggestion from anyone end.
