Any reason to keep stock leafs after add-a-leaf upgrade?
Discussion in 'Suspension' started by goffredo, Nov 8, 2018.
  1. Nov 8, 2018 at 7:22 PM
    goffredo
    goffredo [OP] Grease Nipple
    Lake Tahoe, California
    2018 Tundra Limited Double Cab Magnetic Gray
    Rica25 likes this.
  2. Nov 8, 2018 at 7:54 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    I’d keep em if it were me, I’d wonder if you couldn’t find a way to add em back into the pack if you wanted. I say that because the Icon expansion pack has a rep for getting soft and sagging.
    goffredo[OP] and Pudge like this.
  3. Nov 9, 2018 at 9:54 AM
    goffredo
    Thanks, think I'll I'll keep them in the shed til next year and then re-evaluate whether I need them or not.
    Sunnier likes this.
  4. Nov 9, 2018 at 5:18 PM
    Griff
    Griff New Member
    2018 Barcelona Red DC
    Topper, bedslide and more to come
    How do you like the Icon set up.
    I'd keep the leafs until I sold the truck, my 2cents.
  5. Nov 9, 2018 at 5:46 PM
    goffredo
    On the road, compared to the stock Bilstein B6 series, the Icons have a tighter feel when cornering and going over speedbumps. I would almost say it's stiff like a race car, which is kind of nice. The truck doesn't roll as much, it's kind of analogous to the handling improvement felt when putting a good aftermarket sway bar in an older car. Also, over speed bumps, the rear wheels track better; with the stock rear suspension, I found that the rear end bucks and unweights going over speedbumps, sometimes even chirping the rear tires a bit.
    When off-roading, the bumpy ride is softened slightly though it's not butter like I was kind of expecting. The wheels definitely track better to the dirt, and there is much less unweighting of the wheels from the surface, and therefore much better traction. Hitting tall water bars at speed -- not crazy speed because I usually have passengers and gear that I don't want launched all over the cab -- doesn't launch the front of the truck up as much, and then when the front end is coming down the backside of the water bar at speed, the front end compression is somehow soft without being super deep, and the rebound is very smooth and short, compared to stock which gave a BIG deep compression hit with possible bump-stop engagement, and then a BIG pogo upwards with unweighting of the front wheels and subsequent loss of traction. Put more simply, hitting water bars don't cause a lot of upy-downy stuff and the wheels track against the dirt better, so water bars that are in the middle of a turn can be taken at speed without fear of skidding sideways off the trail immediately upon "landing." By landing, again, I'm not talking about going so fast I actually catch air, I just mean the downward gravity crush that follows the unweighting is very controlled and provides great traction.
    They look pretty bad ass too.
    Griff[QUOTED], Sunnier and gosolo like this.
  6. Nov 9, 2018 at 5:48 PM
    TheBeast The Beach
    keep them. that's good steel right there.
  7. Nov 9, 2018 at 5:54 PM
    doggiecareman
    doggiecareman YOLO / Best to do it with a Toyota
    Eric
    North Central CT
    Tundra Army Green Limited Double Cab TRD Off Road 2021
    TRD dual exhaust/Factory running boards/center console safe/Truxedo X15 Tonneau/ceramic coated/ceramic window tint/BFG KO2's/swing cases/debadged
    Better to have them and not need them than to need them and not have them IMO. Sell them with the truck if and when that time comes.
  8. Nov 9, 2018 at 5:56 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I gave mine to a Tundra bro here on the forum ( Almaboy).
    I would like to get a set back if I could find them. Let me know if you choose to let them go.
