Any other options for mounting ax and shovel
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mamba, Mar 22, 2020.
  1. Mar 22, 2020 at 11:07 AM
    Mamba
    Mamba [OP] New Member
    Manny
    2020 Tundra Limited 4x4
    None
    Hello All,
    Any other options besides victory 4x4 and Rago manufacturing for mounting an ax and Krazy breaker shovel using a Retrax on Mx cover? The tow above are good products I guess but looking for an alternative. Thanks
  2. Mar 22, 2020 at 12:40 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Deck railing system?
    If so, t-slot nuts, some scrap and boom. Easy.
    kevine0001 and HulkSmurf14 like this.
  3. Mar 22, 2020 at 1:57 PM
    Mamba
    Manny
    None
    Yes I have a deck rail system can you elaborate?
  4. Mar 22, 2020 at 2:09 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    I use the deck rail system with quick fists easy and inexpensive
    14burrito likes this.
  5. Mar 22, 2020 at 2:10 PM
    xtyfighterx
    Ty
    North Idaho
  6. Mar 22, 2020 at 2:20 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
  7. Mar 22, 2020 at 3:38 PM
    Mamba
    Manny
    None
    Got it thank you brother!
    joonbug[QUOTED] likes this.
  8. Mar 22, 2020 at 3:52 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    As @xtyfighterx and @joonbug have demonstrated, that's what I meant.
    NewImprovedRon and joonbug like this.
  9. May 18, 2020 at 1:37 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Does anyone know what size t-slot nuts fit into the factory rails?
  10. May 18, 2020 at 1:51 PM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
  11. May 18, 2020 at 1:52 PM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    The T nuts I’ve seen are pricey - I use Superstrut/ unitstur spring nuts that will work just as good at a fraction of the price
    https://youtu.be/mdwW4POwTK4
  12. May 20, 2020 at 9:19 AM
    kevine0001
    kevine0001 New Member
    Kevin
    I made something similar to hold my axe, shovel, and even my hi lift. for the hi lift, i welded the bolts to the fabbed metal bracket. Used large wing nuts...
  13. May 25, 2020 at 12:00 PM
    shawn474
    MoCo, Maryland
