Any manual shifters?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rockanock, Feb 19, 2019.
  1. Feb 19, 2019 at 11:08 AM
    Rockanock
    Rockanock [OP] 21 Chevy 2500
    Does anyone regularly drive your truck in the manual/sport mode? I know it’s useful for towing and also a steep grade letting your engine along with brakes slow you down. I haven’t used it on my truck yet. I have heard it could also help on gas mileage also
  2. Feb 19, 2019 at 11:19 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    There's also engine breaking with tow haul mode
    Mountun Goat likes this.
  3. Feb 19, 2019 at 11:20 AM
    xj2202009
    xj2202009 New Member
    x
    Lutz, Fl
    2017 tundra sr double cab v8 5.7L black 4x2
    looking to replace factory Radio with a pioneer avix588bhs
    All it does is change the shifting points, if you are going up a hill and the truck is struggling, you can shift down a gear placing more torque at the wheels, however, the rpm will go up causing your mpg to go down.
    bvia likes this.
  4. Feb 19, 2019 at 12:13 PM
    15whtrd
    15whtrd Mr. Blonde
    S mode does not change the shift points. Only tow haul does.
    OP I use S mode all the time. Most of the time I use 5th at most in the city.
  5. Feb 19, 2019 at 12:15 PM
    johnvan
    johnvan OG
    john
    Rensselaer,New York
    2016 inferno SR5 DC
    Toyota calls it sequential shift, I use it all the time,the computer will still override it if you get too crazy on the shifts. I wish they offered a manual transmission, I still find myself trying to step on the clutch with my left foot!
  6. Feb 19, 2019 at 12:23 PM
    xj2202009
    x
    Lutz, Fl
    Well, delays the shift a bit. I use it all the time as it gives a bit better pick up. Turn off the nanny's, turn on tow mode and the party is on.
  7. Feb 19, 2019 at 1:27 PM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    Can't remember the last time I shifted into "D". With my 10" BA Exhaust and IPT Valve Body upgrade with shift kit, shifting myself just makes for a much better ride. Instead of changing gears with the throttle, I choose the gear 'I' know is best. Helps keep the Torque Converter locked and prevents heat producing constant shifts. I've owned 2 Dodge trucks, so I've talked to several Transmission Techs over the years:rolleyes:. To the last one, they've all told me that people shouldn't allow their automatic transmissions to shift themselves to death, especially when there are other gears available, that would keep the heat down and the fluid cooler.
  8. Feb 19, 2019 at 1:36 PM
    15whtrd
    15whtrd Mr. Blonde
    Exactly!
    I’d like to do that ITP valve body and shift kit. That sounds fun.
    Hammerhead likes this.
  9. Feb 19, 2019 at 2:01 PM
    CMB
    CMB New Member
    Cecil County MD.
    John Lombardo out of New Jersey is the owner of IPT. He was easy to talk to and patient, answering all my questions/concerns. Core- charge was a no hassle deal and made the change-out really simple for the Transmission Shop. His # is 1-866-828-7267 in case you want to get details.
    15whtrd[QUOTED] likes this.
  10. Feb 19, 2019 at 2:07 PM
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    I shift manually more often when I’m offroad than on. The truck can’t predict terrain changes the way I can, nor can it respond fast enough to my last second decision to slide around a curve instead of just drive like a normal person.
    On the street I don’t mess with it much because most of my on pavement driving is pretty flat.
    I think @papasmurf is a manual shifter junkie
    Sunnier, papasmurf and 15whtrd like this.
  11. Feb 19, 2019 at 2:11 PM
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    :anonymous: Hi my name is papasmurf and im a manual shifting junkie..
    CMB, Sunnier, TRDFerguson and 9 others like this.
  12. Feb 19, 2019 at 2:11 PM
    Rockanock
    I’m going to have to try it out. I used to drive a 97 F-350 flat bed dually for work pulling a trencher. It was a manual and I loved it. That old 7.3 was a good motor. Still wish we had it around.
  13. Feb 19, 2019 at 2:14 PM
    KevinK
    Tundras to Sedona
    Shit, that’s exactly the rig I’m looking for to pull a fifth wheel. Late nineties 7.3 with a manual.
    Sunnier, Hammerhead and papasmurf like this.
  14. Feb 19, 2019 at 2:30 PM
    CMB
    CMB New Member
    Cecil County MD.
    Won't take you long, being you actually have some knowledge of what gear to be in for a given task. The Sequential Shifter was one of the reasons I bought my Tundra over a 2010 F-150. The lame-a$$ed 5.4 Ford V8 helped seal the deal on the Tundra too!
    15whtrd likes this.
  15. Feb 19, 2019 at 2:53 PM
    Rockanock
    They are highly sought after! We sold the truck to a guy who wanted it for his company. It had 140k on it when we sold it. I forget how much we let it go for but I still wish it was around.
    KevinK[QUOTED] likes this.
  16. Feb 19, 2019 at 3:29 PM
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    For the first several months of ownership on my 2018, I just put it in "D" and didn't go into "TOW/HAUL" mode. Then I discovered how great it is in T/H mode plus "S" shifting and that is the only way I drive it now. Getting on the freeway with the afterburners lit is a bunch-o-fun!
    KevinK likes this.
  17. Feb 19, 2019 at 3:47 PM
    Therin7
    Therin7 New Member
    West Tennessee
    2014 Tundra Platinum
    Ford just announced a new 7.3...
    KevinK likes this.
  18. Feb 19, 2019 at 4:28 PM
    Geezer
    Geezer New Member
    Heart of the Catskills
    2019 Tundra Limited
    I normally drive in automatic mode, but I drop it into sequential most of the time when I'm slowing or braking.
    Rex Kramer likes this.
  19. Feb 19, 2019 at 4:39 PM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Only when we are drag racing :anonymous:
    KevinK and Sunnier like this.
  20. Feb 19, 2019 at 4:42 PM
    Sequential shifter here.
    CMB and 15whtrd like this.
  21. Feb 19, 2019 at 4:47 PM
    ChrisTRDPro
    ChrisTRDPro New Member
    MT
    2017 Tundra TRD Pro CM
    I use it to engine brake all the time. Saves my brake pads/rotors and the ECU cuts fuel when you do it so I'm sure there is some negligible fuel savings there (maybe it adds up though).
    Rex Kramer and 15whtrd like this.
  22. Feb 19, 2019 at 4:52 PM
    Sunnier
    Sunny
    San Diego, CA
    I shift manually off-road, and on steep grades, up or down. Not around town.
    KevinK and dcsleeper408 like this.
  23. Feb 19, 2019 at 7:00 PM
    Tracy Perry
    Tracy Perry New Member
    Tracy
    East Texas
    2019 MGM TRD Off-Road 4x4
    No joke.... When we got our Tundra I was already planning on using our '96 F-250 PS as a trade in. Didn't really want to fool with having to sell it privately even though I would have gotten more. When I mentioned what kind of vehicle we would use for trade-in (we hadn't brought it with us as we were not planning on buying just then) all they asked was "Does it have any major body damage". They gave us well above KBB on the trade-in sight unseen. The sales manager was up-front and said they would make a comfortable return on it as that body style (pre-99) was in high demand for a work/farm truck.
    KevinK likes this.
  24. Feb 19, 2019 at 7:11 PM
    KevinK
    Tundras to Sedona
    It’ll be choked to death with emissions bullshit and end up a turd like all the modern ones. Only thing going for it will be the marketing of ‘return of the 7.3’
    Bummer.
    CMB and Tracy Perry like this.
  25. Feb 19, 2019 at 7:28 PM
    Therin7
    Therin7 New Member
    West Tennessee
    I haven't even looked at the specs honestly, just saw it scrolling thru youtube. Ford and Dodge are at war with 1000+TQ trucks right now..
  26. Feb 19, 2019 at 7:41 PM
    Rockanock
    Yeah. We have two 6.7 fords right now that we use for work. Both have been great actually. Tons of power but that new emissions and DEF fluid junk sucks. Even our equipment has to have it. They would all have so much more power if it was deleted.
  27. Feb 19, 2019 at 8:43 PM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
    The new 7.3 is a gasser unfortunately. They are keeping the 6.7 diesel.
    KevinK likes this.
  28. Feb 19, 2019 at 8:45 PM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    I use manual shifting all the time to engine break down hills. I really should use it more but it’s just not the same without a clutch :(
    Sunnier likes this.
  29. Feb 20, 2019 at 3:15 AM
    bradleykd
    bradleykd New Member
    Brad
    Kentucky
    2016 Limited-BLACK
    I have messed with it a few times, but i agree with JH5370 - it's just not the same without the clutch.
    Do you guys let off the gas pedal to up shift or just bump the shifter?
  30. Feb 20, 2019 at 3:36 AM
    CMB
    CMB New Member
    Cecil County MD.
    I'll feather the pedal between 4th and 5th to eliminate the 'flare' at the change. Downshifting at the base of a hill, I'll 'help-out' with the pedal to smooth the shift, usually without adding throttle. For me, every shift depends on speed, load and road conditions. Where I live there are a bunch of roads that 3-4th gears are ideal to keep rpm's at the Torque Converter 'lock-up' range.
