Any lift suspension kit that keep factory comfort?
Discussion in 'Suspension' started by S13ka24de, Feb 17, 2025.
  1. Feb 17, 2025 at 7:01 PM
    S13ka24de
    S13ka24de [OP] New Member
    Hi guys i hv the $1k eibach front and back strut n shocks but it ride really rough. Want to restore factory comfort but also have a lift around 2 and 3 inches any recommendations? Thank you!
  2. Feb 18, 2025 at 1:10 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    If it can be found the best would be a Body Lift. It leaves the suspension alone so no geometry changes. Raises the body only therefore there is less Center of Gravity change (less leaning on hard turns or higher speeds and safer). So a kit would mostly be the body pucks and longer bolts/nuts. Sometimes if enough body lift the ragjoint on the steering column needs to be augmented and the kit includes that.
    Luck.
  3. Feb 18, 2025 at 1:45 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    …In short (not being a wise a$$, just honest) no…
    EDIT: If you are willing to go lower than 2 to 3 inches you will have a better chance but any lift will change comfort and performance.
