Any known issues with 2015's?
Discussion in '2.5 Gen Tundras (2014-2021)' started by grichg, Jul 28, 2020.
  1. Jul 28, 2020 at 9:30 AM
    grichg
    grichg [OP] New Member
    rich
    Thinking of buying a Tundra TSS for sale with 23k miles.
    Any known issues with that year?
    thanks
  2. Jul 28, 2020 at 9:33 AM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    I had a 2015 for 3 years. The ONLY complaints I had about the truck was the 26 gallon gas tank and the dim headlights, which ultimately ended up being one of the major reasons I bought a newer model.
    Performance wise, it was a solid truck.
  3. Jul 28, 2020 at 9:33 AM
    19TurdPro
    2019 Tundra TRD Pro
    I should say, the headlights weren't dim.....they just don't illuminate the road all that well.
    JimboSlice413 likes this.
  4. Jul 28, 2020 at 9:34 AM
    grichg
    rich
    So they changed tank size after 2015? Do you know what year? thanks
  5. Jul 28, 2020 at 9:38 AM
    19TurdPro
    2019 Tundra TRD Pro
    Yes, 2016 they started offering a bigger tank, and I believe it's on SR5 trims and above. I don't believe the base SR model gets the larger tank.
    grichg[OP] likes this.
  6. Jul 28, 2020 at 9:39 AM
    grichg
    rich
    good info
  7. Jul 28, 2020 at 9:41 AM
    johnvan
    johnvan OG
    john
    Rensselaer,New York
    2016 inferno SR5 DC
    2016 with SR5 upgrade package has 38 gallon fuel tank. Limited and Platinum also.
    grichg[QUOTED][OP] likes this.
  8. Jul 28, 2020 at 10:46 AM
    Brownsfanhere
    Brownsfanhere New Member
    2015 Crew Max
    I love my 15. Of course led headlights would be nice. Just got a good deal and jumped on it. No regrets. Trouble free since day 1.
    ATHiker likes this.
  9. Jul 28, 2020 at 11:32 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Not much if any change from 2014-present. Except for things mentioned like bigger gas tank and LED lights on some models. There are two V8's offered; 4.6 and 5.7L. Many prefer the 5.7 with more power but the 4.6 is very capable.
  10. Jul 28, 2020 at 11:39 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Don't get a 15. The small tank is terrible. Even worse, don't get a 16+ with a small tank.
  11. Jul 28, 2020 at 11:52 AM
    7dgoat
    7dgoat Member
    NJ
    2025 Terra Platinum Off-road
    I owned a 15 pro for 5 yrs. Never had a problem with that truck. Not even a recall! The headlights are adjustable. With the inside adjuster all the way up I felt they were to low. So I turned the adjuster ring on the back of the headlights 2 full turns. That brought the beams to the desired height I wanted. I never felt like I wanted more after that. The 26 gallon tank never bothered me. I have a gas station on my way to work so it was very convenient to get gas. I would usually fill up around 250 miles. On trips I needed a little break after that anyway. Hope this helps your decision.
    Iowa12tundra likes this.
  12. Jul 28, 2020 at 12:25 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Of the 3rd gen years, 2015 is the only year with zero recalls or TSB’s. It’s also the only year that shows ALL categories of ratings in consumer reports as”best”.
    I did replace the 26g tank on mine.
  13. Jul 28, 2020 at 2:42 PM
    grichg
    rich
    great info being provided, thanks.
  14. Jul 28, 2020 at 3:36 PM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    Love my 2015. I have not had any major issues with it. It has been a solid truck. I have replaced any items that I did not like suck as the headlights. I put the 2018 LED headlights in it. Other than that its a solid performer.
  15. Jul 28, 2020 at 3:53 PM
    Haggis777
    Haggis777 I.L.J.C.M.L.
    SW Michigan
    2015 Silver SR5 TRD Tundra Canadian Model
    LEDs interior & exterior, stubby antenna, Bak-Flip cover, 285's, AGM battery, block heater, Pine tree air freshener
    Have owned my 2015 SR5 TRD double cab for 2 years.
    Love this truck. Spacious, strong, sporty.
    Had 19,700 miles when purchased.
    Now at 31,000....not 1 problem.
    I DID replace the headlights, fog lamps and interior lights to LEDs.
    I thought the 26 gallon tank would bother me, but it's just like any other truck I have owned so no big deal.
    Changing the oil with the cartridge set up is a bit different, but not a problem at all.
    Hope you buy it! 23K is low mileage.
    You won't be disappointed!
  16. Jul 28, 2020 at 3:56 PM
    Blueknights75
    Ron
    Clayton, NC
    Just look for cam tower and rear diff leaks. Other than those two issue enjoy that Tundra!
    Luckydog and Haggis777 like this.
  17. Jul 29, 2020 at 1:14 PM
    grichg
    rich
    Did buy a bigger tank from a later year? How was mounti
  18. Jul 29, 2020 at 5:54 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I got the 46g transferflow tank installed by a local shop.
    Cheaper than the 38g OEM tank.
  19. Jul 31, 2020 at 6:46 PM
    Haggis777
    SW Michigan
    Did you buy the truck!?
  20. Jul 31, 2020 at 8:31 PM
    nmichtundra
    nmichtundra New Member
    I'm so on board with the 46G Transferflow! Currently have the 26G tank on my 2015 1794... really don't like the size, light comes on after 20G. We are about to be on deck to buy a trailer, so towing long distances with a small tank will get annoying. I've been quoted roughly $2100 in AZ for the tank and install ...
    gosolo[QUOTED] likes this.
  21. Jul 31, 2020 at 10:45 PM
    grichg
    rich
    This process of buy a truck has been frustrating and exhausting. First truck I wanted they guy said no worries he'd sell to me on Monday when banks opened. Then ended up selling Sunday night behind my back after promising it me. So F'ing pissed.
    Second one in Texas and guy has gone radio silent but still posted. Block called him the other day and he said its mine but went radio silent again.'
    The 2015 was in Oklahoma and guy was cool but I stalled since it was a 2015 and I really wanted a 2017 or newer. But one decided I was pulling the trigger and he ended up taking an offer from another guy. I blew that one....
    No Double Cab 4 door 4x4 in CA Private Party and few at Dealers without paying a grip of cash. Lots of them East of the Mississipp1 though....
    The search goes on but good info from you guys. Just want one so I can start the fun building it.
  22. Aug 1, 2020 at 4:42 PM
    KingsAustin
    KingsAustin Grey Goose II
    Morgan County, AL
    2021 Limited Night Shade
    BakFlip MX4, Gator All Weather mats, Console Safe, Ceramic Tint, Roadmaster Active Suspension, Interior/exterior LED conversion, Wireless console charger, AJT designs.
    I have a 2015 SR5 DC TRD that I bought with 9,000 miles certified. The only issues that I have had was a tranny issue that was fixed by Toyota with no problems. I have 65k on it now and it sits in the driveway. I have been seriously thinking of selling it due to this whole CVD. We are doing well with one vehicle.
  23. Aug 3, 2020 at 7:17 AM
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
    On any used tundra, I'd be sure to check out the underside of the bed for signs of rust. Look where the crossmembers meet the bed floor pan. Do a search if you are not familiar with this issue on tundras.
    It was a serious problem on gen 1 and gen 2 trucks. I'll let you know in another few years if its a problem on gen 3 ;)
  24. Aug 3, 2020 at 2:15 PM
    TRDpro4x4
    TRDpro4x4 New Member
    2016 TRD DC 5.7V8
    Good truck that too with low miles dont stay for us. I Purchased an used 2016 TRD DC with 26 gal tank, dont really bother me.
    Good Tundras that too with low miles dont last in the market long, I purchased a used 2016 TRD DC with 26g tank months ago. The tank never bothered me. On longer trip may be a sleek gas container secured on the bed will take care of that issue. Its a great truck with lots of power, NO recalls or defects. Having owned a 07 before i see a good improved design on the frame. Good luck.
  25. Aug 3, 2020 at 2:45 PM
    grichg
    rich
    **UPDATE**
    Found a 2016 5.7L 4X4 with 15K miles-38 gallon tank and flying up to buy it tomorrow. Older retired guy bought and figured out he didnt need it. His loss my gain and now for some fun to put about $10k into it and buildit up.
  26. Aug 3, 2020 at 4:35 PM
    Brownsfanhere
    2015 Crew Max
    Congratulations
  27. Aug 3, 2020 at 5:09 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    I have a 2016 and the headlights are terrible.
  28. Aug 3, 2020 at 5:26 PM
    Haggis777
    SW Michigan
    I hear you...I WFH even without Covid. Might put 2,000 on my 2015 this year...only 31,000 miles on it total.
    BUT it's paid for! Will be hanging on to it.
    Still comes in way too handy throughout the year... especially pulling people out of snowy ditches in the winter! (Michigan)
    KingsAustin[QUOTED] likes this.
  29. Aug 3, 2020 at 6:36 PM
    brobert225
    brobert225 Firm grasp of the obvious
    I upgraded to the pro LEDs on my 2015. Awesome lights. The gas tank outlasts my need to stretch and wee, so no issue.
  30. Aug 25, 2022 at 6:44 AM
    Biby
    Biby New Member
    Hay guys i got a tundra sr5 2015. I whant put some wheels and i like a 20×12 but not sure if it going to fit pleace advice
