ANY ISSUES w/ changing the TRANSMISSION Fluid to Amsoil ?
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by rapide, Jul 23, 2024.
  1. Jul 23, 2024 at 1:27 PM
    rapide
    rapide [OP] New Member
    jim
    double cab limited
    Gents,
    I recently bought a used 2020 Tundra DC, Limited w/ 78K miles.
    I had her fully inspected by an independent shop which was an excellent idea. Carmax is now going to cover some $4300.oo repairs to safety items, full new alignment, body bumper R/R, New front brakes rotors pads.
    I'm having to maintain the routines, oil trans, R/E fluid changes... yada yada.
    I had the transmission fluid changed only. Not the whole enchilada.
    Questions come up and I need some help & quality answers , please . . . .
    What's a typical oil / filter change to a tranny costs ?
    IS THERE ANY .... issues to change the fluid to a amsoil brand ?
  2. Jul 23, 2024 at 1:29 PM
    Totmacher
    Totmacher New Member
    Daniel
    West TN
    mesquite Tundra or blue 4Runner
    Some
    Stock ATF is synthetic. Toyota WS fluid.
    OHwendTrd and rapide[OP] like this.
  3. Jul 23, 2024 at 8:05 PM
    rapide
    jim
    double cab limited
  4. Jul 23, 2024 at 10:40 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    I'm a dealer if you need anything. Can hook you up
    rapide[OP] likes this.
  5. Jul 24, 2024 at 3:27 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    Hi Jim, welcome to the forum. Here's generally what I use:
    Oil: Pennzoil 5w-30 ultra platinum (very comparable to amsoil signature, fraction of cost, $90 for 15 quarts)
    Filter: Toyota OE
    Transmission: Toyota WS, OE (one of the few fluids car care nut recommends this oil remain OE only)
    Front Differential: Amsoil Severe Gear Oil 75w-90
    Rear Differential: Amsoil Severe Gear Oil 75w-90
    Transfer Case: 75w Ravenoil
    Coolant: Toyota OE (have not replaced yet, hear you need to use the pink stuff from Toyota)
    Amsoil is a great brand and provides a quality product. But I found it to be unnecessarily costly when there are equal alternatives for much less. And you can see I do use Amsoil for certain things.
