Any info remote start
Discussion in '2.5 Gen Tundras (2014-2021)' started by kcaustin66, Oct 9, 2019.
  1. Oct 9, 2019 at 11:02 PM
    kcaustin66
    kcaustin66 [OP] New Member
    kevin
    Palestine Texas (East Texas)
    2015 Toyota Tundra CM 1794 4wd
    3” lift, black step bars, aftermarket wheels, LT305/55R20 was this way when I brought it.
    Any special buys on remote start, and links and my car
    2015
  2. Oct 9, 2019 at 11:14 PM
    YotaMan
    YotaMan Silver Bullet
    Colorado Springs
    2021 Platinum
    Fiesta346 and Toyokuhl like this.
  3. Oct 10, 2019 at 1:39 AM
    Ted4311
    Ted4311 Don't Sweat The Small Stuff
    SOMD
    14 Tundra MGM TRD-OFFROAD 4X4
    A LOT... NEVER ENDS
  4. Oct 10, 2019 at 2:34 AM
    TD28
    TD28 New Member
    2018 Plat CM Mag Grey 4x4
    6 in. ProComp Suspension and many more
    I installed the unit from 12Volt Solutions. Installation was a breeze, utilizes factory key/keyfob so NO extra fobs. Haven't had any issues.
    soloshairtrigger likes this.
  5. Oct 10, 2019 at 3:03 AM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    Best remote I ever had.
    Hard to read in the sun though
    Migraine, TundraOverlord and Toyokuhl like this.
  6. Oct 10, 2019 at 4:18 AM
    Toyokuhl
    Toyokuhl New Member
    aaron
    SWFL
    2018 Cav Blue CM OR
    I LOVE my Compustar. I have had 2 now and will be putting one on my GF's truck for christmas!
    stuckinohio likes this.
  7. Oct 10, 2019 at 5:29 AM
    7.62X51
    7.62X51 New Member
    Virginia Beach
    I second 12Volt Solutions. Have had mine for over a year. Zero issues, easy to install and no extra key FOB. One recommendation though. I think they come pre-programmed for 12 mins of run time before it shuts off. I had them program mine for 30 mins.
    HulkSmurf14 and soloshairtrigger like this.
  8. Oct 10, 2019 at 6:35 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    I like the idea of 12Volt Solutions...but I'm cautious to the range of the remote...That's where all other aftermarkets win...especially CompuStar
  9. Oct 10, 2019 at 6:43 AM
    7.62X51
    7.62X51 New Member
    Virginia Beach
    I would say at best mine works out to a hundred feet. Which works for me.
  10. Oct 10, 2019 at 7:11 AM
    Fiesta346
    Fiesta346 New Member
    PA
    2013 Rock Warrior
    I got a Compustar in my truck. Had them in previous automatic vehicles i'd recommend them.
  11. Oct 10, 2019 at 7:44 AM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    My dad, boss and myself all have Vipers and have had no issues.
  12. Oct 10, 2019 at 7:56 AM
    801Tundra
    801Tundra New Member
    UTAH
    2019 Crewmax Limited
    Can't go wrong with Compustar or Viper. Personally run the Compustar 4900S and the range is awesome. If going with the tech12volts or 12voltsolutions kits I would spring for the app which basically gives you unlimited range. Range with the OEM fob is not ideal for most remote start situations.
  13. Oct 10, 2019 at 7:59 AM
    sundance
    sundance New Member
  14. Oct 10, 2019 at 8:03 AM
    xJuice
    xJuice This guy...
    Josh
    DFW, TX
    '19 MGM DC SR5 4.6 TSS
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill, Remote Start, One-touch Auto Windows
    sundance[QUOTED] likes this.
  15. Oct 10, 2019 at 8:05 AM
    sundance
    sundance New Member
    You the man. I looked for it and didn't see it. Sorry.
    He will program every how you want it. He sends an message to confirm when you buy. At least, that is what he did for me. There are some options on certain models that are not on others.
    I love mine. Its more now. I think I gave $200 even for mine a couple of years ago.
    xJuice[QUOTED] likes this.
  16. Oct 10, 2019 at 8:20 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    They are still around. I was trading emails with them last year before i got the compustar, thats now been removed from my Tundra.
    Here is their website - http://www.andersonelectronics.net/foevplandplr.html
  17. Oct 10, 2019 at 8:39 AM
    bsavoir
    bsavoir New Member
    Killeen, TX
    2016 Tundra Limited CM 4x4
    Gibson Metal Mulisha Exhaust, Replaced bulbs w/ LED's, AFe intake, Bullydog Tuner, Aftermarket Audio system, Rhino Bed Light sports bar, Tonneau Cover, Spyder Auto Headlights and Taillights, Recon 3rd Brake Light, Kensun HID's, Fender Flares, Custom Leather Interior, Heated Seats, 5% Tint on the Rear Windows, Pod light Foglights, 31" light bar behind the grille, linex spray bedliner, linex sprayed grille, ditch lights w/ dual 3in LED pods, 60" Tailgate LED strip.
    I've had a Fortin Evo One on 2 Tundras (2014 and 2016) with a minor issue. The issue was it was setup for a different model (settings). I paid about $200 for the kit and the programmer. They also make a harness that makes it plug n play with the exception of a wire tap. You can use the original key fob (3x lock or lock, unlock, lock) extended range fobs are also compatible. I have had no need to use the extended range fobs.
  18. Oct 10, 2019 at 8:42 AM
    sundance
    sundance New Member
    That's what I liked about anderson programming it for you. I believe most people that had problems with the fortin was due to programming.
    I found that holding the unlock button down for 3 to 4 seconds works just like the 3 clicks and its much easier to do with my fat thumbs and old age.
  19. Oct 10, 2019 at 11:14 AM
    Rebel Tundra Man
    Rebel Tundra Man New Member
    Tyler
    Western Kentucky
    2016 Black Limited CM
    4" RCX Lift, 20x10 Fuel Coupler's, 35x12.50x20 Nitto Ridge Grappler's, Color Match Front End, LED Bulbs, RCX Tube Steps, Green LED Underglow
    I see that @tech12volt has a group buy going on right now for $199.99 I'm about to jump in on that myself. normal price for the fortin is $230 or $240?
    KingsAustin likes this.
  20. Oct 10, 2019 at 1:45 PM
    6XC
    6XC OPS4
    '18 MGM Tundra SR5 TSS Crewmax 4x4
    Was quoted $890 installed for Compustar PRO T12 remote start only, no alarm :eek2:
    YotaMan likes this.
  21. Oct 10, 2019 at 3:07 PM
    KingsAustin
    KingsAustin Grey Goose II
    Morgan County, AL
    2021 Limited Night Shade
    BakFlip MX4, Gator All Weather mats, Console Safe, Ceramic Tint, Roadmaster Active Suspension, Interior/exterior LED conversion, Wireless console charger, AJT designs.
    12volt remote start was my choice under the Tundra group buy. The instructions and YouTube video were a breeze to help in the install. It took longer to zip tie everything. Good luck
  22. Oct 10, 2019 at 7:28 PM
    bsavoir
    bsavoir New Member
    Killeen, TX
    This is why i do most of my own work, some places charge an outrages amount of money for something simple as a lot of kits are now becoming Plug n Play. For that price you can install Fortin EVO One with the Thar-ONE-Toy7 T-harness and a RF kit and still be under the cost of that.
  23. Oct 10, 2019 at 8:12 PM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    The Fortin Evo One and the Carlink ASCL6 are a great pair. The ASCL6 works connects via 4G LTE and allows you to start your truck via an app on your phone.
    I have this one from StartX. It's a Fortin EVO One with his own harness. 0 splicing.
    https://smile.amazon.com/Start-X-Re...keywords=start+x+tundra&qid=1570763481&sr=8-4
    Also, there is one ASCL6 on Amazon right now for $109.00. I've seen it as low as $90.00
    https://smile.amazon.com/Audiovox-A...f=sr_1_1?keywords=ascl6&qid=1570763543&sr=8-1
    Jump on it, that's a good deal.
  24. Oct 10, 2019 at 9:26 PM
    TXTundra2722
    2015 Black Tundra
    I agree on the 12volts kit. I've had mine for over a year now without any issues. I also use the factory key fob and have had zero issues with starting it in the drive and I'm in the house. When I'm in the parking lot, I swear I gave longer range than used too, because I can start it over 200 feet away. There are add on kits as well if you need to start from a further distance as well.
  25. Oct 11, 2019 at 4:57 AM
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    I have the 12voltsolutions remote starter. Took less than an hour to install and works great. I got that one because I didn’t want to get involved with carrying a second fob in my pocket. Range is obviously that of the stock remote fob, which for me is about 90 to 100 feet. I might get the Wi-Fi module so I can have unlimited starting distance for those times that I need it.
  26. Oct 11, 2019 at 5:42 AM
    mambo143
    mambo143 New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, Coachbuilder 1” shackle lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack. Westin HD Brush Guard, Spidertrax 1.5 spacers. TRD Brakes. Headlight Revolution LED. TRD rear Torsion Bar. Dirty Deeds 10 inch Stainless. TRD Pro Grill. Bushwhacker Pocket Flares. Baja Designs Combo Driving/Fog lights.
    Just pulled the trigger on a 12 volt system. Glad I came across the thread. It’s that time of year.
  27. Oct 11, 2019 at 6:46 AM
    7.62X51
    7.62X51 New Member
    Virginia Beach
    Correct me if I'm wrong but don't most long range modules have a yearly re-occurring subscription fee?
  28. Oct 11, 2019 at 11:40 AM
    bsavoir
    bsavoir New Member
    Killeen, TX
    I know the cell based ones do, but not the 1500ft+ remotes dont
  29. Oct 12, 2019 at 9:22 AM
    james@tech12volts
    james@tech12volts tech12volts.com INNOVATIONS IN AUDIO ! Vendor
    james
    The last TUNDRA remote start group we will ever do is going on right now . This will save you almost 100 dollars from our normal price.
    Its covers 2010 gkey only to 2017 and 2018 and 2019 H key . 199.99 shipped. No cutting except on 18 and 19 modules and they require 1 wire be cut. These work off of your factory remotes . We have sold 1000s of these and know them on the Tundra better than anyone . We will not start shipping until the first 50 are ordered so usually about a week to start shipping but sometimes 2 . This will be the cheapest you will ever see this plug n play remote starts . We also have the Carlink modules on group as well and that pricing is adjusted in the same listing . its 135 and that includes the first year of service. The Carlinks will be priced at 189 after this group is over but you can add it later if you want .
    video of install in 2015 which is the same for 2010 gkey to 2017 .
    https://www.youtube.com/watch?v=NrGw_-WEE4g
    2018 and 19 only difference will be you do not have to go to passenger side at all and there is 1 TPMS wire you have to cut and connect but it is very easy as well and we do have a video for it also .
    Plenty of customers on here have them . buy yours here
    https://www.shop.tech12volts.com/product.sc?productId=537&categoryId=59
    for 2018 2019 guys I have talked to 12 volt solutions and he is willing to sell anyone that buys a remote start from me a harness that will allow you to make the 18 19 completely plug n play . You will have to buy it from his site and i will get a link for it as soon as he post it up . link to get that plug so zero cutting on 2018 and 2019 https://www.12volt.solutions/produc...rZbpE7GaCRTlwxCMeAfi8D_E-1ERkzdHlRyjoiWutIZcQ
    lsutiger9904 likes this.
  30. Oct 12, 2019 at 4:55 PM
    KingsAustin
    Morgan County, AL
    James@tech12volts
    I have a couple tech questions for you. Still getting used to using the system.
    1) If you remote start and unlock the doors, but do not put the key into the ignition. Does the engine start time out and turn off?
    2) If you remote start and do not unlock the doors. Does the engine time out and turn off?
    Thanks for the support!
