Any hesitance at purchasing a 2016 Sequoia with 44k miles?
Discussion in 'Sequoia 2nd Gen (2008-2022)' started by JoJoCal19, Nov 22, 2019.
  1. Nov 22, 2019 at 11:45 AM
    JoJoCal19
    JoJoCal19 [OP] New Member
    Looking at replacing our Oddy with a full size SUV. I miss my Tundra and was about to pull the trigger on a new one but with 3 kids we really could use the third row for occasional parent or friend that we want to take with us somewhere.
    While a new Sequoia is doable, I just don't want to pay that much for one. I found what looks to be an immaculate 2016 Limited with bench (a must) and factory JBL audio and Blu Ray player (omg yes) with 44k miles. Its a CPO so that helps. It started its life in Mass but was only there from June to Decemeber, so not sure how much salt its seen but I will definitely check in on that. And from owning a 2017 Tundra I know to check the camshaft towers for leaking.
    I am specifically looking for something to last 8-10 years. They're asking like $38k and I'm targeting $36k for it. Any hesitance at looking at this vehicle to drive for another 8+ years?
    EDIT: Forgot to add, this is a 4WD model as well, which I know they run a little more than RWD. We drive to the mountains in winter as well as on the beach here so 4WD is mandatory.
  2. Nov 22, 2019 at 12:02 PM
    15whtrd
    15whtrd Mr. Blonde
    Sounds like a good deal. I bet that things not even broken in yet. That’s about average miles for something that age. It’s about four years old with about 11 to 12,000 miles per year on it depending on when it was sold. Just check for surface rust and maybe give it a good treatment of something like fluid film or the likes.
  3. Nov 22, 2019 at 12:02 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    If PO treated it well then it should be good to go. @War Machine has had several of these and his have lasted forever.
  4. Nov 22, 2019 at 12:05 PM
    MAGDADDY
    MAGDADDY TTC #280
    JON
    Houston TX
    18 Platinum CM MGM
    Leer 100XL, Bedrug, Go Rhino running boards, LED int/ext lighting, Bilstein 6112/5100 1/2”shims up front, Coachbuilder +3 shackles, CB drop, TRD front/rear sway bar, 275/65/20 Michelin LTX M/S 2, sequoia painted mirror cap/door handles, Rago Fab low pro ditch brackets, Baja Designs S2 sports ditch lights. Baja Designs S2 sport rear flush mount pod
    Sounds pretty good! I’d say haggle your best and see what happens. If the truck is super clean chances are it was well cared for. And sequoia sounds like a perfect fit for your fam. Post up some pics if you have any.
    JoJoCal19[OP] and 15whtrd like this.
  5. Nov 22, 2019 at 12:08 PM
    Primo
    Primo White Tundra
    Primo
    San Antonio, Texas
    2016 SR Double Cab
    Level kit and TRD Pro Grill Installed.
    44 thousand miles ? Not bad, but for 38 ? anything under 35 grand for the Sequoia is a good price.
    JoJoCal19[OP] likes this.
  6. Nov 22, 2019 at 12:09 PM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    It sounds like a good deal. As others have said, do a good check for rust and other obvious leaks, but other than that it sounds like you might have a long term vehicle there.
  7. Nov 22, 2019 at 12:23 PM
    Metro14536
    Metro14536 New Member
    Brandon
    Las Vegas, NV
    2025 Ice Cap SR5 TRD Rally
    Not even half way broken in yet...the sequoia is even better than the tundra.
    You will only get about 800,000 miles out of it before you have to do anything besides basic maintenance so be careful o_O:bananadance::bananadance:
    khunk, JoJoCal19[OP] and War Machine like this.
  8. Nov 22, 2019 at 12:28 PM
    Badger Co-Op
    Badger Co-Op Blood sausage, cheese, and lutefisk; hit me!
    Kenny
    WISCO
    Check car gurus dot com....I've found MUCH lower Tundy pricing therein....
    War Machine likes this.
  9. Nov 22, 2019 at 12:30 PM
    War Machine
    War Machine SSEM # 5 3MW
    I’d have absolutely no hesitation at all with a Sequoia with that mileage. Our 2012 Limited is at over 200k and still running perfectly. Not only that, but nothing has ever failed on it. Nothing. Other than wearable parts like brakes, tires, etc, every part of that truck is still original. Hasn’t spent a second broken down in 8 years and 200,000 miles.
    I can’t recommend the Sequoia enough. Drives like a dream, and built like a tank. Nothing has ever broken on the interior either. The chrome wore off the emblem on the steering wheel. That’s it. We’ve been all over the country in it.
    This is just a hunch, but I’d bet it’s well cared for. People who own these vehicles tend to be people who take care of their stuff.
    As for the price, it seems high, but I’m certainly not an expert. I do know that dealerships will move a ton on the price of a new one. The Sequoia is one of, if not the worst selling vehicle Toyota has in the US. It’s an outstanding vehicle, but doesn’t have the bells and whistles that people are looking for in a vehicle like this.
    I’m not sure if it’s the same with a used one, but they’ll budge a ton on a new one.
  10. Nov 22, 2019 at 12:35 PM
    Porkchop Express
    Porkchop Express Its all in the reflexes
    Cody
    2017 Tundra CM
    Lift , tires , stereo , TRD headlights , Rolling tonneau
    We have an 04 Sequoia with 225K miles and that tank has been incredible. This summer , my wife has rear ended in the Sequoia and its fine, a little wrinkly in the back , but drives fine. The Jeep grand Cherokee that failed to stop at the red light was destroyed. I will never doubt the Sequoia's reliability , or the shittyness of Chrysler.
    JoJoCal19[OP] and GODZILLA like this.
  11. Nov 22, 2019 at 1:29 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    I almost bought one..
    There were a few I found online at local dealers with ~100K for like $15K.
    When I went to the dealership they "had just sold." :rolleyes:
    I ended up with what I really wanted.. my Tundra.
    I wouldn't hesitate at all to buy something like that. But then again I'm pretty handy with a wrench so even a Toyota with something like 150K+ doesn't scare me.
    JoJoCal19[OP] and Badger Co-Op like this.
  12. Nov 22, 2019 at 5:00 PM
    MS22
    MS22 New Member
    02 Tundra 4x4
  13. Nov 22, 2019 at 8:48 PM
    JoJoCal19
    Thanks guys. I'm going to check it out tomorrow. It is the nicest one at least within 500 miles of me.
    MAGDADDY likes this.
  14. Nov 23, 2019 at 8:52 PM
    JoJoCal19
    Well, I went tonight to check it out. It was absolutely amazing. Way smoother and quieter than my Tundra. The thing looks and drove like it was new, an absolute dream to drive. As bad as I wanted it, I almost walked out without it several times. In the end whoever put the deal together in the system for the FI guy to submit flubbed the number and I ended up with that Sequoia for $35k, which seems great for a 4WD Limited with the BSM and rear entertainment options. It was raining when I got home but Ill post a pic tomorrow.
    Seafury, YotaMan, Rex Kramer and 4 others like this.
  15. Nov 23, 2019 at 8:54 PM
    18" TRD Off Road Wheels
    Congrats on the new ride!
  16. Nov 23, 2019 at 9:32 PM
    TheBeast The Beach
    congrats ! they are really nice ! and share some parts with the Tundra :)
  17. Nov 24, 2019 at 5:26 AM
    Badger Co-Op
    Kenny
    WISCO
  18. Nov 24, 2019 at 5:31 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
  19. Nov 24, 2019 at 3:28 PM
    JoJoCal19
    Yes 5.7L :)
  20. Nov 24, 2019 at 3:29 PM
    Pics, you bastard! Pics!
    :worthless:
    TundraDude18 likes this.
  21. Nov 24, 2019 at 4:21 PM
    JoJoCal19
    Ask and ye shall receive!!!!
    BuckWallace and GODZILLA like this.
  22. Nov 24, 2019 at 4:27 PM
    JoJoCal19
    I did have a momentary issue with it today that I'm going to post about in a new post. Hopefully it was a one time hiccup.
  23. Nov 24, 2019 at 4:56 PM
    hitech
    hitech New Member
    Blair
    SOMD
    2018 CM TRD OR Limited
    Nice! I love Sequioas, that is really nice and you got a really good deal. The interior looks almost new. Congrats.
    JoJoCal19[OP] and TheBeast like this.
  24. Nov 24, 2019 at 5:04 PM
    Fishin RGV-Trd Pro
    Fishin RGV-Trd Pro White is faster
    Alex
    RGV Texas
    2011 White Toyota Tundra Limited
    Congrats. Very nice.
    :thumbsup:
  25. Nov 27, 2019 at 11:41 AM
    Primo
    Primo White Tundra
    Primo
    San Antonio, Texas
    2016 SR Double Cab
    Purdy.
  26. Dec 6, 2019 at 4:58 PM
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    My wife has a 2017 she bought new about two years ago. Fabulous vehicle, we love it (2wd).
  27. Feb 28, 2020 at 4:07 PM
    Cthulhu
    I bought this 16 Limited 4x4 this past July, 38,000 miles for $38K. I absolutely love it!!!
    BrandonL812 and Mountun Goat like this.
  28. Feb 28, 2020 at 4:25 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Not at all if the price and condition are right.
    I looked at them before buying a Tundra (as I came from a 4runner, I like a SUV). But they were priced much higher than what I found my Tundra for. Do love a nice Sequoia. I would probably have one if the prices for them were in line with a similar year, condition and mileage Tundra.
  29. Mar 1, 2020 at 5:57 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    Weird. Here in Texas I was looking at 2 sequoias that were priced 10k less than comparable tundras.
