Any experience with "key replacement" companies?
Discussion in '2nd Gen Tundras (2007-2013)' started by Mel94dB, Feb 28, 2024.
  1. Feb 28, 2024 at 2:13 AM
    Mel94dB
    Mel94dB [OP] New Member
    Hi - I have a 2007 Tundra TRD and a bad habit of locking my keys in the truck. Yes, I've bought a hide-a-key trailer hitch thing. However, on the rare occasion I've needed to tow something I remove that, forget to put it back in, and then lock both the main and the spare in the truck again. I could use a new brain. The nearest dealer is more than an hour away and taking a half-day to go get keys made isn't very appealing.
    Meanwhile, I've seen ads online for companies (ex. Tom's Key Company, Car Key Express, Keyless Entry Remote, etc.) that offer to sell you a key and help you get it programmed. It seems that Tom's, for example, will rent you the programming device.
    Has anyone used any of these services? Does this method work?
  2. Feb 28, 2024 at 2:47 AM
    TXBrit
    TXBrit New Member
    Weatherford TX
    2019 MGM Platinum
    I recently had a new Honda key made by Toms, it came with the programing tool and was easy to use. Worked out well. Key was cut from photographs of original key.
  3. Feb 28, 2024 at 4:32 AM
    lerbud1
    lerbud1 New Member
    Larry
    Waco, TX
    2021 Tundra SR5
    I used Toms for my Tundra and got ripped off. I tried the key photo deal and key was wrong and programmer would not work. No refund as they said they never received the stuff back. Customer service would take 2-3 days for a reply. Ended up using local locksmith for the same price.
  4. Feb 28, 2024 at 10:29 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    I've used lowes for a key replacement. As well as a minute key kiosk at a bed bath and beyond. Both have had keys made in minutes before, pun intended.
    Anyhow, get yourself a magnetic key lock box and store it on your frame of the truck. Use it when needed, but also return it to its stored space for future use again.
    Or stop smoking whatever it is that's preventing this from happening again.
    1lowlife likes this.
  5. Mar 2, 2024 at 1:59 PM
    Tridom
    Tridom New Member
    Dominick
    Hampton Roads, VA
    2012 Tundra SR5 4.6L V8
    But those non programed keys and will only unlock the door. I need a programmed second key and those cost way to much from a dealer.
  6. Mar 2, 2024 at 4:17 PM
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
    2008 Salsa Red Tundra DC SR5 4x4
    Chrome delete, Sequioa grill, bed lights, LED + head, fog & tail lights, Dynamat throughout, front & rear cameras, Pheonix PX6 13" head unit, 8" subwoofer, JBL speaker upgrades, tonneau cover, custom shifter, steering wheel cover
    If you're a bit of a techie, buy Techstream from Amazon. You can use it to program a replacement blank. A locksmith did the physical cutting for $5.
    12volt.solutions sells a remote starter kit that works with a phone or watch app. That's a good way to unlock your truck if your keys are locked inside.
  7. Mar 2, 2024 at 8:52 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    They are programmed keys.
    think it's was like 70-80 bucks though. Tech stream is the way for sure. But other options exist outside of the dealers.
    Tridom[QUOTED] likes this.
  8. Mar 2, 2024 at 9:06 PM
    2mchfun
    Welcome from OKC! Maybe you should just keep the extra key on a loop around your neck.
    Tridom and OldGuy03 like this.
  9. Mar 3, 2024 at 7:37 AM
    Tridom
    Tridom New Member
    Dominick
    Hampton Roads, VA
    Lowes can program them? Last time I checked the only place I was able to get a programmed key was from the dealer. Interesting.
    OldGuy03[QUOTED] likes this.
  10. Mar 3, 2024 at 8:03 AM
    Tridom
    Tridom New Member
    Dominick
    Hampton Roads, VA
    So...I went to the Amazon link you posted and couldn't find the programmer. But I ended up buying the Autogine interior light kit for 25 bucks.
    Just wanna say thanks for making me spend money. LMAO
  11. Mar 3, 2024 at 5:49 PM
    PhotoNerd
    Tony
    Waterford, CT
  12. Mar 3, 2024 at 8:43 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    I didn't know either, but I walked past their key making station one day and saw keys labeled for Toyota. Then I tracked down a blue vest and asked him to cut me a key. He puts my key into his machine and the machine spits out a part number that he finds on his wall. Bam, does everything the factory keys does. He didn't have my wife's key in stock so I did hers at the key kiosk in a bed bath and beyond. They didn't have it in stock either but did mail me one within 3/4 days.
  13. Mar 7, 2024 at 4:38 PM
    Tridom
    Tridom New Member
    Dominick
    Hampton Roads, VA
    Cool. I need to check into that. Now I just need to find another remote FOB for it also.
  14. Mar 7, 2024 at 4:58 PM
    Bozothedog
    Bozothedog New Member
    I purchased a remote on ebay and found a locksmith who specialized in car keys. He cut the key and programed the remote for about 75.00. Call around your local area and you will probably find someone.
  15. Mar 7, 2024 at 8:55 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    Stream tech. Fobs and keys all in the program software.
