Any decking "experts" here? Looking for sun shade advice
Discussion in 'Home Improvement' started by Burdturger, Apr 5, 2020.
  1. Apr 5, 2020 at 1:53 PM
    Burdturger
    Burdturger [OP] New Member
    Thinking of adding a cheap sun shade over our deck. I don't want to drill into the house and I'm looking for the most cheap, effective, and correct way to do it. My neighbors added two 4x4 posts in the inside corners of their deck and just attached a square sunshade to each post and then put eye hooks in their siding.
    I don't exactly want to copy their idea :D Instead of a square sun shade, I want to do multi-leveled triangle sun shades.
    My deck is just your standard pine deck, about 5 feet off the ground and is 14x14. I don't anticipate getting full coverage with this idea but I just want some shade as it is better than none.
    I just don't know the best/easiest way to attach new 4x4 posts for the shades. Ideally I would think I need them in the ground. Alternatively, I suppose I can just put them in the corers of the deck with some lag bolts. Would this be okay? I'll update this post shortly with pictures.
  2. Apr 5, 2020 at 1:56 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Have a picture of the deck setup? Would help picture what you’re trying to accomplish with your current setup.
  3. Apr 5, 2020 at 2:01 PM
    Burdturger
    Excuse the mess. Here are a few pics for reference. Notice the neighbors set up as mentioned above
  4. Apr 5, 2020 at 2:06 PM
    Burdturger
    here is the layout
  5. Apr 5, 2020 at 2:07 PM
    Burdturger
    here is what i'm thinking of doing. again not wanting to attach to the house
    Second picture is kind of what I'm shooting for.
  6. Apr 5, 2020 at 4:27 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Based on what I can see the sun angle/travel path is, I think you have the triangles in the right spot, could use a single larger one, but 2 medium sized look more eye pleasing, maybe different colors? Only think I can suggest because I've seen in on a friend's, is to attach the left triangle (as looking towards house) to the 1x4 above the doorway, then attach the 2nd one beneath and mid-way between the larger upstairs window. The idea being to attach them at a higher elevation than the front sides, for added shade and water drainage, wind buffering.
