Any bath remodelers on board?
Discussion in 'Off-Topic Discussion' started by Britrider750, Feb 14, 2019.
  1. Feb 14, 2019 at 7:46 AM
    Britrider750
    Britrider750 [OP] Old dude with cool truck.
    Ron
    Clayton, North Carolina
    2017 TRD Off Road
    All weather Tundra floor mats, spray bed liner Extang Trifecta 2.0 tonneau
    Looking to install a bath exhaust fan.
    One question is, how long can I run a 4" duct. using a 60-80 CFM fan.
    Based on the joist config., I would have to run about 13' to the nearest outside wall.
    Another question is can I safely cut a 4" hole in a 2 x10 rim joist in order to pop through the wall.
    I tried asking the good folks at my local big box and all they could say was " it should work."
    Any advice would greatly be appreciated.
    Thanks.
  2. Feb 14, 2019 at 9:29 AM
    Racingjohndeere55
    Racingjohndeere55 New Member
    YardBird likes this.
  3. Feb 14, 2019 at 9:34 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Depends on code in your state. They all vary.
  4. Feb 14, 2019 at 9:38 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    The length should be fine as long as you’re maintaining fall so water doesn’t accumulate in the line. I have my vents on a timer so they typically stay on 15-20 mins after my shower is done. That gives it ample time to pull the moisture plus dry up any condensation that may be in the line. Also, insulating the duct is a must.
    Structurally, Going through the rim joist shouldn’t be too much of an issue as your joists are baring most of the load on the foundation wall. Wouldn’t hurt to reinforce with an additional board around the cutout. Just make sure you seal the hell out of the duct at the hole inside and outside.
    But like others said, check local code.
    I’m not a professional but have done my fair share of diy home remodeling.
  5. Feb 14, 2019 at 9:45 AM
    Racingjohndeere55
    This info is good to know. I'll be doing a bathroom remodel soon.
  6. Feb 14, 2019 at 9:53 AM
    Britrider750
    Ron
    2017 TRD Off Road
    Thanks guys, I will definately check with the code officer just to make sure.
    I too read that the rim joist is looked at differently compared to a spanning joist.
    Yeah, good thought about pitching the duct downwards slightly for condensation.
  7. Feb 14, 2019 at 10:03 AM
    Greybeard
    Greybeard Retiree in training
    Forsyth Georgia
    2014 SR5 Double Cab
    If you are talking about in the attic, I have always run them over to the soffit with a soffit mounted spring loaded vent.
    Racingjohndeere55 likes this.
  8. Feb 14, 2019 at 10:19 AM
    Britrider750
    Ron
    2017 TRD Off Road
    No, I wish it could be through the attic. This will be going in first floor ceiling of a two story.
  9. Feb 14, 2019 at 11:09 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    BTW. Do yourself a favor and buy a good fan. They're expensive but totally worth it IMO. Panasonic makes really good fart fans.
    RangerBP, Hbjeff and YardBird like this.
  10. Feb 14, 2019 at 11:19 AM
    Britrider750
    Ron
    2017 TRD Off Road
    Yes, been scoping out Panasonics line of Whisper EZ bath fans.
    They look to be designed very well and have been suggested to me by others.
  11. Feb 15, 2019 at 4:23 AM
    Slayer
    Slayer Member
    Slayer
    typically fart fans will push 75' .. reduce 3' for each elbow.
    cutting rim.. no worries
    be smart .. if the fan is of some age.. replace the fan while things are open.
    consider a fan/light combo that will allow heat lamp bulbs
    OBXTundra likes this.
