Any advice is helpful
Discussion in 'Performance and Tuning' started by Tundra 45, Oct 27, 2024.
  1. Oct 27, 2024 at 6:21 AM
    Tundra 45
    Tundra 45 [OP] New Member
    Dave
    Des Moines, Iowa
    2012 Tundra
    Air bags with remote, 10 ply tires, Bullydog GT gas, K&N high flow drop in air filter, throttle body air swirler
    Hi, I am new to your group. Glad to be here.I have a 2012 Tundra with a Bullydog GT programmer. I pull a 8900 lb camper and I am thinking about putting a Magnuson supercharger on it. I was wondering if anyone has had this type of setup? Lots of questions..... do I actually need to change fuel pump? When my pump went out a couple years ago, I had to get my computer flashed and had to reprogram Bullydog. What a pain! I run E85 most of the time. I know with the supercharger I will have to run premium for the octane. E85 is 104+ on octane, will it be OK to run with supercharger? Also wondering if I will lose mileage? I have read people lose mileage but is it because they can't keep their foot out it? I just want to pull camper better. Thank you in advance for any advice.
    Mdl likes this.
  2. Oct 27, 2024 at 8:47 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    To run e85 with the charger will require a bigger fuel pump. Way bigger injectors. And you’ll get hugely worse mpg.
    not saying those things to be negative. It would be beyond cool to do a supercharger on e85!!
    Mdl likes this.
  3. Oct 27, 2024 at 10:09 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, solid Offroad engine mounts, DIY Traction Bars, Tuning by snivspeedshop.com
    You can run the SC on E85 with the supercharger.
    Although the fit kit for the SC comes with larger injectors, fuel pump and the base tune. You most likely will need to have larger injectors and fuel pumpbthat come with the kit. You should browse around the supercharger forum for some info. It can be a lot at first but lots of knowledgeable people.
    https://www.tundras.com/threads/general-supercharger-thread.85513/
    Another member who ran ethanol, although he no longer posts or has the truck anymore had to build up his fuel system. I'm posting it for informational purposes.
    https://www.tundras.com/threads/5-7-supercharged-e85-fuel-system-diy-project.101526/
    dirtydeeds likes this.
