Anti-freeze leak
Discussion in '2nd Gen Tundras (2007-2013)' started by BannzBeez, Jan 28, 2024.
  1. Jan 28, 2024 at 11:06 AM
    BannzBeez
    BannzBeez [OP] Trial and error educated
    Humble, Tx.
    2012 Tundra Dbl. cab 5.7 4wd
    N-fab chrome tube step Rockstar 20x9 wheels/ 34’s Nitto Ridge Graplers RC 6” lift/ M1 shocks MOOG upper/lower control arms/ ball joints/tie rod ends.. Replaced rear differential After market extension side mirrors with turn signal..
    Found the pink crystals, dripping down from the rear of the motor, onto the bell housing and off the trans. pan …??
    Never over heats, or runs hot, always a normal consistent temp during operation… added maybe a gallon of coolant in 12years..
    No visible signs of a leak, other than this..??
    Anyone have suggestions..?
  2. Jan 28, 2024 at 11:51 AM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    Valley plate leaking imo
  3. Jan 28, 2024 at 12:31 PM
    BannzBeez
    Humble, Tx.
    Is this under the intake ..?
    Had a suspicion it may be leaking from the back
  4. Jan 28, 2024 at 12:46 PM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    Yes, you might be able to confirm looking underneath the intake aided by a flashlight.
