Antenna
Discussion in '1st Gen Tundras (2000-2006)' started by Jam lady, Dec 26, 2023.
  1. Dec 26, 2023 at 6:50 AM
    Jam lady
    Jam lady [OP] New Member
    Beverly
    03 White
    Hello I'm new to the group thanks for having me. I have an 03 Tundra and the car wash took off my antenna. Someone tried to use a threading tool to get the piece out and of course it didn't work. How do I get that housing out to replace the entire antenna?
  2. Dec 26, 2023 at 6:53 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    You’ll need to pull the inner fender liner for access to it, basically the plastic liner above your passenger tire
    The Black Mamba likes this.
  3. Dec 26, 2023 at 7:28 AM
    The Black Mamba
    The Black Mamba Black Sneks Matter
    Ryan
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Welcome. As Frenchy said, the antenna housing is located inside the inner fender. It is held in place with 1 bolt. The chrome piece at the top of the antenna mast itself unscrews and after that the mast can be unscrewed. DO NOT DAMAGE OR LOSE THE CHROME RING AS IT HAS BEEN DISCONTINUED! The plastic black around the fender pops up through the top of the fender. Then you remove the radio, disconnect the antenna and thread the cable through the firewall behind the glove box to remove the assembly.
    @whodatschrome has pretty good pics of his relocation here: https://www.tundras.com/threads/tacoed-tundra-project.130491/page-6#post-3356247
    EDIT: @Voss has detailed pics here too Antenna removal? | Toyota Tundra Forum (tundras.com) When I removed mine to install the snorkel, Voss' was the tread I followed.
    Schcoman, shifty` and FrenchToasty like this.
  4. Dec 26, 2023 at 11:18 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Post a photo
