ANOTHER Towing Question.
Discussion in '2.5 Gen Tundras (2014-2021)' started by ATCinfantry, Apr 16, 2021.
  1. Apr 16, 2021 at 6:01 PM
    ATCinfantry
    ATCinfantry [OP] Pot Stirrer
    Trey
    Memphis, TN
    2017 Toyota Tundra MGM SR5 TSS Off Road Package
    Running Boards. AJT YEET Chrome interior kit. Tonneau cover. More Mods Coming SOON!
    First of all, I don't understand the whole weight rating deal. So much crap, loaded, unloaded, curb weight, gross weight, GCVRW or whatever. Kinda tired of reading about it so I'm just gonna ask and hopefully get some help.
    The truck: 2017 Toyota Tundra Crewmax with towing package.
    Trailer: 24' car hauler - 3600lbs empty
    Car: 1967 Camaro Racecar - 2800lbs
    Gear: About 1k lbs worth of tools, fuel, tires, generator, battery charger, canopy tent, wife, kids, food, drinks, etc.
    Question: Will this exceed the (insert appropriate legal weight) or will I be good.
    I don't want to get in an accident, someone die and go to jail for negligent homicide because I wanted to go racing. I know its a stretch but lets be honest, it could happen. I don't wanna take the risk. BUT I don't wanna sell my Tundra either.
    I know the truck CAN tow it but I need to make sure I can LEGALLY tow it.
  2. Apr 16, 2021 at 6:05 PM
    ATCinfantry
    Trey
    Memphis, TN
    I just wish Toyota would be like "Look MF, don't put a trailer behind your truck that weighs more than xxxx lbs" or you might go to jail. Or maybe they do and I'm too Mississippi to understand that lol.
    AircareTundra likes this.
  3. Apr 16, 2021 at 6:12 PM
    TundraDude18
    TundraDude18 Deus vult
    'Merica
    '21 Limited CM
    Silver Bullet Express
  4. Apr 16, 2021 at 6:33 PM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    As long as most of your gear is in the trailer with the car, you should be good.
    15whtrd likes this.
  5. Apr 16, 2021 at 6:35 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Get your gcwr gross combined weight rating number and work backwards from there. Your truck probably weights about 6200lbs for 4wd give or take. Thats the total they want the truck and trailer to weight altogether
  6. Apr 16, 2021 at 6:39 PM
    A-A-Ron
    A-A-Ron Done messed up
    Aaron
    Seattle
    2021 Ford F-250 Lariat Diesel
    The payload rating will be the issue. Really need to move as much of the weight to the trailer as possible and not in the truck. Any idea the hitch weight with the car loaded? Keep in mind you need at least 10% of the total trailer/car weight on your hitch to have proper control. A hitch scale might help you balance this all out.
    Cpl_Punishment and gladecreekwy like this.
  7. Apr 16, 2021 at 6:42 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Luckily you can move the car on the trailer to get the perfect hitch weight :)
    15whtrd likes this.
  8. Apr 16, 2021 at 6:44 PM
    timsp8
    NY
    But not too far back where you end up with too much weight behind the trailer axle. Key word “perfect”.
    15whtrd and Hbjeff[QUOTED] like this.
  9. Apr 17, 2021 at 4:39 AM
    TundraHulk02
    TundraHulk02 New Member
    2020 White Tundra TRD Sport CrewMax
    Def find out your capacity weight on the inside of your drivers door. Don’t exceed that. That’s the issue I have right now. I’m only allowed 1270lbs. My trailers hitch is 705lbs, then I add the myself, wife & kids. I’m only like 150lbs shy of going over. Tundras payload is garbage. Didn’t really notice until u want to finally buy something to tow.
    Jtundra81 and Nightshade Tundra like this.
  10. Apr 17, 2021 at 5:19 AM
    timsp8
    NY
    Somewhere on here someone said the spec includes a 150lb driver and passenger. I never found that info myself on the spec web for sae j2807 though.
  11. Apr 17, 2021 at 5:40 AM
    TundraHulk02
    Ya I never saw anything like that, even my manual says to include all passengers
  12. Apr 17, 2021 at 5:51 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    that spec is for towing capacity, not for payload.
    Hbjeff and Cpl_Punishment like this.
  13. Apr 17, 2021 at 5:58 AM
    Netmonkey
    Georgetown, TX
    you are probably good. put all the gear that you can into the trailer to keep that weight off the truck. a 7400 pound trailer load means at least a 740 pound tongue weight. look at the yellow sticker on your drivers side door jam. there will be a Payload number. it is probably around 1200-1300 pounds. subtract 740 from the Payload and that is how much weight you have left for your family and other gear in the truck. with your trailer setup, you can move the load around to lower or increase your tongue weight.
    it is good that you are asking and learning now instead of just loading up and heading out without understanding your setup.
    good luck :)
  14. Apr 17, 2021 at 6:18 AM
    DvilleMafia
    DvilleMafia New Member
    DFW
    2018 Tundra SR5 4x4
    it really is. Mine is a whopping 1145 lbs. subtract my weight and a few passengers and I’m not left with much.
  15. Apr 17, 2021 at 6:20 AM
    I agree with others, you should be good if loaded correctly. 3600+2800+500 (half the 1000lbs will be in the trailer)=6900 lbs. 690lbs tongue weight (aprox). You should be fine.
    15whtrd, nvrgvup444 and Netmonkey like this.
  16. Apr 17, 2021 at 6:28 AM
    timsp8
    NY
    Figured he was talking about towing since he mentioned a trailer and hitch weight. The thread is about towing as well. You have to consider both when calculating the numbers.
    Found this:
    In addition to a vehicle’s base curb weight, the “Tow Vehicle Total Weight” (TVTW) for testing for ¾- and 1-ton trucks allocates 150 pounds for the driver, 150 pounds for a passenger, the weight of all tow package equipment, and 100 pounds of optional equipment (hitch ball, weight distribution bars, and such) split evenly between the front and rear axles.
    http://www.trucktrend.com/how-to/towing/1502-sae-j2807-tow-tests-the-standard/
  17. Apr 17, 2021 at 6:33 AM
    On a side note, do you have an ATC enclosed trailer @ATCinfantry? Those are amazing trailers and would put them up there with Sundowner trailers.
    Stroke250 likes this.
  18. Apr 17, 2021 at 7:00 AM
    TundraHulk02
    So is this just for 3/4-1 ton trucks then? Doesn’t specify 1/2 ton
  19. Apr 17, 2021 at 8:08 AM
    timsp8
    NY
    I don’t know. That might be where some of the confusion is from too. I’ve seen both sides on here. Some say it includes it and some say it doesn’t.
  20. Apr 17, 2021 at 1:27 PM
    ATCinfantry
    Trey
    Memphis, TN
    Ok. So after looking at my door,
    GVWR is 7000.
    GAWR FRT 3900
    GAWR RR 4150
    Yellow sticker: Reduced payload capacity by 163lbs
    The trailer I'm looking at is a 24' enclosed car hauler that weighs 3600lbs empty.
  21. Apr 17, 2021 at 1:37 PM
    ATCinfantry
    Trey
    Memphis, TN
    I havent bought a trailer yet because I want to make sure I can tow it safely and legally. No I dont have an ATC trailer. The ATC in my user name stands for Air Traffic Control. I am not set on a specific manufacturer but I'm gonna buy the lightest trailer that will support weight I put in it. So whoever has that, has my business lol.
  22. Apr 17, 2021 at 1:57 PM
    I would be looking at Sundowner or ATC trailers then.
    Maybe hit up some of our regional thread areas to see if someone has an enclosed trailer near Memphis TN, put a car in it, see how close you can get to the 7000 lb weight and test it out.
  23. Apr 17, 2021 at 5:58 PM
    TundraHulk02
    There should still be something on the sticker stating the capacity of cargo/passengers then you have to minus that yellow sticker from it. That’s should be your actual payload your allowed.
    Cpl_Punishment likes this.
  24. Apr 17, 2021 at 6:10 PM
    ATCinfantry
    Trey
    Memphis, TN
    This is what’s inside the door.
  25. Apr 17, 2021 at 6:27 PM
    Gould71
    Gould71 Member
    2017 Platinum Midnight Black
    TRD swaybar, TRD shift knob, FN FX Pro wheels, Toyo AT/IIIs, VLED interior and puddles
    The sticker just below the one in your photo (the one with the tire pressure data etc.) will have the truck’s payload capacity. Subtract the 163 pounds from that number to get your net payload capacity.
    Assume a minimum of 10% of your total towed weight as payload. 10 - 13% of trailer weight is considered acceptable tongue weight to prevent sway and handling issues. You have some leeway in how you load your trailer to get the correct tongue weight.
  26. Apr 17, 2021 at 6:36 PM
    ATCinfantry
    Trey
    Memphis, TN
    So 1360 minus 163 is 1197
    So I can only carry 1197 lbs including the tongue weight? WTF am I supposed to do with that? Lol.
    I’m sure a trailer that weighs 7k lbs is gonna have a tongue weight of more than 1000 lbs. right?
  27. Apr 17, 2021 at 6:41 PM
    Gould71
    Gould71 Member
    You have the correct number. That’s what the payload is- it’s a weak point of the Tundra.
    13% of 7000 is 910- that would be the high side, 700 would be minimum for proper loading. Less than 10% can lead to sway. You can adjust the load in your trailer by moving the load forward or backward of the centerline of your axles.
    Providing you don’t have to haul the whole family and the dogs in the cab, you should be fine with your planned load.
  28. Apr 17, 2021 at 6:43 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Welcome to tundra life. Once the trailer is hooked up and you put your family in. Your ice chest and bbq in the truck bed put you over the weight limit.
    ive never understood why both gawr combined don’t equal the gvwr
    Terndrerrr, ColoradoTJ and Gould71 like this.
  29. Apr 17, 2021 at 6:49 PM
    ATCinfantry
    Trey
    Memphis, TN
    Well I doubt I can get 750 tongue weight.
    Guess I’m buying a diesel lol.
    that’s crazy “it’ll tow 10,500”...... “kinda”
    ColoradoTJ likes this.
  30. Apr 17, 2021 at 6:59 PM
    Gould71
    Gould71 Member
    That’s where they get you on the towing claims. It’s a problem in the 1/2 ton market. You’ll run out of payload before you reach tow capacity.
    Can’t tell you how many times I’ve heard a F150 owner tell me they can tow 13k because the commercial said it can. Then the argument ensues about it only applying to the 2wd regular cab long bed work truck package with the max tow and payload options, not the Platinum crew cab 4wd bells and whistles model they’re driving. The 13k rated F150s are unicorns- good luck finding one on the lot.
    A diesel can surprise you also as they’re heavy and subtract from your GVWR. Many times a gasser 3/4 or 1 ton has a better payload than the diesels- but the tow rating is far less.
