Another PSI question
Discussion in 'Wheels & Tires' started by UTAHRTK, Nov 12, 2020.
  1. Nov 12, 2020 at 7:42 AM
    UTAHRTK
    UTAHRTK [OP] New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    I have read through the PSI threads- the info is broad in terms of best PSI...
    Does anyone know a good PSI for Mickey Thompson Baja ATZ p3 295/70r17 (E)? I have a crewmax. I have been trying to tweak between 38 and 32 psi. Currently at 32 PSI. Thanks
  2. Nov 12, 2020 at 9:10 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Pressure can depend on many things- tire load rating, rim width, how your truck is set up, the weight of the truck, load and accessories. Best practice is to do a chalk test so you know exactly what is best for your truck. It is super simple and really what you need to do if you install any tire other than the "stock" size and load that came on the truck. E load tires are a much different beast than the passenger tires/standard load. LT tires require more pressure to carry the same load vs standard load tires, which is why you can't use the door sticker pressure. This may help- https://www.youtube.com/watch?v=FabWgDAulGg
    Chucho, TTund16 and Uhhhh.... like this.
  3. Nov 12, 2020 at 9:29 AM
    AZBoatHauler
    So.Arizona
  4. Nov 12, 2020 at 11:26 AM
    UTAHRTK
    SOCAL
    Thanks for all the great info- that got complex real quick. I used a calculator and spoke with tire rep and it came down to 35 front/rear. Now wonder how much wiggle room I have to maximize ride comfort on road. I did the chalk test at 34psi and it looked good- gonna try it at 32 and see what's up.
    14burrito likes this.
  5. Nov 12, 2020 at 11:57 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    I run between 30 and 35 on my Toyo ATIII.
    Almost every D or E tire I have owned on this truck has been within that range for daily use.
  6. Nov 12, 2020 at 12:27 PM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    38 on my 295/70/18 Wildpeak's, passes chalk test. That's what my tire shop set them to when i got them mounted. Ride still comfortable with solid mpg.
  7. Nov 12, 2020 at 12:45 PM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    Chalk test put me at 36 front; 30 rear. Nitto 37s.
  8. Nov 12, 2020 at 1:07 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Lot of variances make it different for everyone.
    Rim width correlated to tire width, weights, load range just to name a few.
    Uhhhh.... likes this.
  9. Nov 12, 2020 at 1:28 PM
    Sunfish
    Sunfish New Member
    17 4X4 CM Limited
    If you can feel a front tire roll under in a turn it's not tight enough. The rear can go a little lighter if your not loaded heavy
  10. Nov 13, 2020 at 8:01 AM
    UTAHRTK
    SOCAL
    32 has the ride feeling nice. I will chalk test today.
  11. Nov 13, 2020 at 5:48 PM
    UTAHRTK
    SOCAL
    Chalk test at 32psi complete. Front are damn near perfect rear were a little over so dropped them to 31.
