Another one; RW, stock with 275/70/17?
Discussion in 'Wheels & Tires' started by Redcon41318, Dec 9, 2020.
  1. Dec 9, 2020 at 6:32 AM
    Redcon41318
    Redcon41318 [OP] New Member
    Hey all forgive me for this question; i have a stock sr5 CM 4x4. Will rock warrior wheels with 275/70/17 fit with zero frame rub?
    Does the 50mm RW offset allow for the 275 series tires? Compared to the oem 60mm with 255/70/18? Thanks guys i have a set RW im thinking of buying, i want to see what tire size i can run to get
    An advantage over oem.
  2. Dec 9, 2020 at 7:42 AM
    Hunterd_22
    Hunterd_22 New Member
    Hunter
    Kentucky
    2010 Black Tundra Rock Warrior
    Should be no problem at all. I ran that size and wheel set up on mine stock for a while.
