Another new fog light install question - need advice on switch
Discussion in '2nd Gen Tundras (2007-2013)' started by bob4diapers, Nov 7, 2017.
  1. Nov 7, 2017 at 11:13 AM
    bob4diapers
    bob4diapers [OP] New Member
    2009 Tundra CrewMax 5.7 4WD
    Aftermarket headlights Fog Light Install ARE Topper Westin Stepbars
    hi folks,
    new member here. I just picked up a 2009 CrewMax at a Gov auction (side story, it was previously owned by the FBI and I'm discovering some of the associated peculiarities as I go through it...).
    The truck came without fog lights from the factory, however it IS prewired for them. I bought a ebay kit and have read many threads on various forums about the different ways to add fogs to a truck that didn't come with them.
    The kit I purchased came with the fog lights, wiring harness, switch, relay, fuse, etc. HOWEVER, since my truck is already prewired, I have decided to use the existing factory wiring harness and install a switch in the dash, tapping into the wires below the steering wheel. Loosely, the procedure is shown in this youtube video:
    https://www.youtube.com/watch?v=OQiFLtb-mnU
    However, it does not work. My switch lights up (green luminescence), but no 12v power at the lights. It appears that the switch is not triggering the relay. I believe that I have the same aftermarket kit, same approach, and same problem as described in this thread:
    http://www.tundratalk.net/forums/tundra-lighting-electrical/102637-wiring-foglight-switch.html
    Essentially, it seems that the polarity of the switch provided in these kits is opposite of what is needed if one wants to use the OEM factory installed foglight wiring harness instead of running the harness that comes with the kit. However, apparently the correct style switch can be obtained as referred to in the forum threads (and as shown in the youtube video above). But these are all old threads and I can't find a current link to a product that can be obtained in exchange for money.
    In short, I'm wondering if anyone knows what switch is needed to make this setup work - i.e., installing foglights using the prewired harness?
    Thanks!
  2. Nov 7, 2017 at 8:26 PM
    nuclearlemon
    nuclearlemon New Member
    wyoming
    2012 dc
    factory foglight switch is on the stalk. a rotational switch
  3. Nov 7, 2017 at 8:29 PM
    bob4diapers
    Yes, I understand that. And that is certainly one option. Another option is to install a switch to left of steering column as shown; question is which switch to make that happen.
  4. Nov 9, 2017 at 12:07 PM
    bob4diapers
    Look at this on eBay
    ON/OFF Push Button Switch Fog Light Symbol for Toyota Tacoma Tundra 4Runner
  5. Nov 9, 2017 at 1:49 PM
    bob4diapers
  6. Nov 9, 2017 at 1:50 PM
    bob4diapers
  7. Feb 7, 2021 at 11:19 AM
    1stand3rdgen
    1stand3rdgen New Member
    2016 Tundra SR
    Wheels, 1/2 fog lights
    Hi Bob, where did you hook up that new switch? Or better yet, what wires did you connect it to?
