Another Eibach Coilover Thread :rollseyes:
Discussion in 'Suspension' started by atxtundra, Aug 11, 2018.
  1. Aug 11, 2018 at 9:35 PM
    atxtundra
    atxtundra [OP] New Member
    I know it’s been beat, but I couldn’t find anything on it.
    Is anyone running the front Eibach coilovers only? I’m looking at fitting 295/70/18’s and am 100% pavement only. Would it be feasible to only run these or is it recommended to at least do some type of lift in the rear as well? I was almost ready to just do a 3/1 level with a spacer lift, but if this is possible I’d rather have the better ride quality.
    Thanks in advance.
  2. Aug 11, 2018 at 9:39 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Its a 3" front lift. You are going to want to lift the rear so your front doesnt look high.
    Just go for the kit
  3. Aug 11, 2018 at 9:59 PM
    atxtundra
    I know it’s just for the front. I should have been more clear.
    Would I be ok just running blocks in the rear for the lift and saving a couple hundred bucks?
  4. Aug 11, 2018 at 10:09 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
  5. Aug 11, 2018 at 10:21 PM
    dawgfan706
    dawgfan706 New Member
    I am also curious if this setup is possible. Just using the eibach lift in the front and the shackles in the back with the stock bilsteins.
  6. Aug 12, 2018 at 7:44 PM
    atxtundra
    This is exactly what I’m thinking, and would like to run. Just curious if it’s possible....
    I mean I’m sure it’s possible. But recommended? I dunno...
  7. Aug 13, 2018 at 8:16 AM
    dawgfan706
    I asked David with Toytec and he said running just the fronts with shackles in the back would be fine as long as you don’t articulate the rear end too much. Articulating too much would over extend the stock bilsteins.
  8. Aug 13, 2018 at 9:35 AM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    I think you should be fine OP running that setup for what you described your uses.
  9. Aug 13, 2018 at 12:00 PM
    atxtundra
    By articulate I assume you mean lift? I would just do the 1” shackles.
    Good to know it’ll work!
