Another, but different, squeaking thread
Discussion in '2nd Gen Tundras (2007-2013)' started by McTundra12, Nov 20, 2017.
  1. Nov 20, 2017 at 10:20 AM
    McTundra12
    McTundra12 [OP] New Member
    '12 CrewMax TRD
    Notta
    Edited due to error.
    My 2012 CM TRD has been developing a squeak. This squeak seems to be located within the rack and pinion rather than bushing related. With my old lady turning lock to lock while I’m under the front end, the squeak is most apparent when the wheels are nearly straight forward, not turned at higher angles. I hear the squeak when driving slower speeds and windows down, but it does subside when I’m turning. As my wheels straighten out the noise returns. I also hear it going over bumps or depressions.
    I believe the noise is caused as the tie-rod shaft moves in and out of the seal on the rack body. Boots are still in good shape and no leaking fluids from the rack. I have also lubed all bushings with silicone spray, which didn’t solve this problem.
    Anyone in Tundraland have to repair/replace front drive axles due to squeaking? Other suggestions?
    Note: I have installed Bilstein 5100s for level 16 months ago.
  2. Nov 20, 2017 at 12:39 PM
    TheBeast The Beach
    are the zerks greased ? 5 total along the drive line.
    Black Wolf likes this.
  3. Nov 20, 2017 at 1:13 PM
    McTundra12
    '12 CrewMax TRD
    Notta
    Front drive line?
  4. Nov 20, 2017 at 1:20 PM
    Grease all zerks in drive line? Steering stops? Brake shoes glazing or wearing out? Any joints going out or rubber boots torn?
  5. Nov 20, 2017 at 1:22 PM
    TheBeast The Beach
    4x4 ? there should be 2 or 3 zerk fittings close to front diff.
    metallic sound ? any work on your brakes lately ? check the dust cover
  6. Nov 20, 2017 at 1:39 PM
    McTundra12
    '12 CrewMax TRD
    Notta
    Dude... slightly embarrassed and ashamed by my mistake. Not in the drive line as a stated in the initial post.
    Steering. The sounds seems to come for the tie rod, so I assume it’s actually coming from the rack.
    Thoughts?
    Looked at it yesterday in the dark and posted this afternoon.... embarressing to confuse these two parts.
  7. Nov 20, 2017 at 1:39 PM
    McTundra12
    '12 CrewMax TRD
    Notta
    It’s a 4x4
  8. Nov 20, 2017 at 4:42 PM
    It may well be the rack. Brian..aka csuviper...replaced his. Just may be the problem. It's a 4X4..
  9. Nov 21, 2017 at 6:30 AM
    McTundra12
    '12 CrewMax TRD
    Notta
    Anyone had experiences with the Rack making a squeaking noise without failing? Truck acts and drives great other that the noise. Im not convinced its a Rack failure, and i may poke a small hole in the boot and spray silicone lube in there.... puzzled.
  10. Nov 21, 2017 at 6:31 AM
    McTundra12
    '12 CrewMax TRD
    Notta
    Thanks for the lead. I contacted him and his problem was a complete failure. My issues are purely noise at this point.
