Another brake question....
Discussion in '1st Gen Tundras (2000-2006)' started by SWVA_Tundra, Dec 24, 2016.
  1. Dec 24, 2016 at 10:15 AM
    SWVA_Tundra
    SWVA_Tundra [OP] New Member
    Otto
    2000 White Toyota Tundra 4X4 SR5
    I have a 2000 Toyota Tundra SR5 4X4 that has 198,000 miles on it and the frame was replaced during the recall. I recently replaced the brake rotors and pads with EBC rotors and pads for a 2000 Toyota Tundra (this was before I read some of the previous threads on this forum) and they worked well for about a month and I have noticed that when I am going downhill and press the brakes the entire truck vibrates just like before I replaced them. They are going to need to be replaced and was wondering if I should buy 2005 Tundra rotors, pads, and calipers. I absolutely love my truck and don't want to get rid of it but the brake issue is cursing me. Any help anyone can provide would be much, much appreciated.
    Thanks in advance for your response,
    Otto
  2. Dec 24, 2016 at 10:37 AM
    Mike Tread lightly.
    south carolina
    Check your pm bro.. and grab some coffee it's long.
    NewImprovedRon likes this.
  3. Feb 12, 2017 at 8:28 AM
    peck
    peck New Member
    2000 tundra 4x4 king cab 270,000 miles
    k/n air filter
    i had a tie rod end that went bad and it acted just like a warped rotor disc when i would hit the brakes. jack the front of the truck up, and grab the wheel on both sides and try to turn it while watching the tie rod end . any play at all you should have it replaced,and front end realigned . 17.00 for tie rod end and 129.00 for labor and front end alignment hope this helps!
  4. Feb 13, 2017 at 1:23 PM
    SWVA_Tundra
    Otto
    I had all front suspension and tie rods checked and everything was okay. So, I upgraded the front brakes to a 2006 caliper and rotors and the problem seems to be solved. Thanks for your input
    040Tundra likes this.
