Annoying squeak from the rear
Discussion in '2.5 Gen Tundras (2014-2021)' started by ToyotaTundraMike, Sep 23, 2016.
  1. Sep 23, 2016 at 8:04 AM
    ToyotaTundraMike
    ToyotaTundraMike [OP] Not A New Member
    2015 Tundra
    So I have an annoying squeak coming from the rear that has been getting worse. Only have 27k miles on the truck. Any ideas what it could be or how to troubleshoot? It isnt constant. Goes away at higher speeds and seems to happen mostly when the road is uneven or over small bumps. Also happens in reverse. Dont think its the leafs because I had a coworker jump up and down on the tailgate and didnt hear it. Ideas?
  2. Sep 23, 2016 at 8:49 AM
    Grizzly660
    Grizzly660 21 Army Green Sport
    North Dakota
    2021 Army Green Sport
    20 inch XD Hoss wheels with Nitto EXO Grappler Wetokole seat covers
    Check your u-joints on the drive shaft. Had that happen on a chevy. Sounds like same situation low speeds and reverse. Although it shouldn't be happening with that low of miles.
  3. Sep 23, 2016 at 8:53 AM
    RussellVaughan
    RussellVaughan New Member
    Houston
    2015 Gray TSS 5.7 CM SR5 4x4
    AMP Research PowerSteps; Katzkin leather seats (Nightrunner, all black, no perf/logo); TRD 18" BBS Forged rims; Nitto Terra Grappler G2 LT295/70R18) tires; LT295/70R18 spare tire; Rough Country speedo calibrator; Fox 2.0 IFP front & rear w/1" leaf blocks; TRD PRO black headlamps w/Headlight Revolution harness; TRD PRO grill w/color match hood bulge; RCI engine skid plate; BakFlip MX4 tonneau; Baja Design Squadron Sport fog lights w/clear wide lens; front/rear color match bumper covers; K&N CAI; Pedal Commander throttle controller w-trailer brake bezel; SE Toyota wireless charger tray; VLEDS interior and exterior LED lights; AJT Designs interior chrome delete; Sparks Parts driver side grab handle kit; Pop&Lock tailgate lock; ICS Fab dash mount w/support plate; ICS Fab center console mount; SNS Custom Design ABS sensor guards; TRD PRO shift knob; Undercover Swingcase bed storage; Rad Rubber Design engine splash guards; Bull Ring bed rail tie-downs; exterior debadge w/black & engine badge and black 4x4 badge; Charvonia Design billet bed tie-down anchors; rear console USB port; TRD rear sway bar; Fumoto Oil Pan Valve; Toyota metal oil filter assembly; Vexing R1 dash cam; X2Power 24F Battery.
    push up and down on the bed on each side of the truck. might be bushing on the shocks
  4. Sep 23, 2016 at 8:54 AM
    ToyotaTundraMike
    2015 Tundra
    That was one of my first thoughts since I had to replace all of them on my 06 Tundra, but that was after like 100k miles. Also seemed like the squeak was more constant when it was the Ujoints and it did it even on flat surfaces. Should I just have Toyota look at it next time I go in for service or is it something I should address asap?
  5. Sep 23, 2016 at 8:59 AM
    ToyotaTundraMike
    2015 Tundra
    Thanks ill give that a shot here in a few
  6. Sep 23, 2016 at 9:02 AM
    RussellVaughan
    Houston
    i had this happen on my chevy when i replaced the shocks. try all four corners. sometimes its hard to reproduce and pushing on the opposite corner of a bad bushing can cause it to squeak...at least on an old truck it did lol
  7. Sep 23, 2016 at 9:51 AM
    ToyotaTundraMike
    2015 Tundra
    May just do that Ron. My initial worry was that I'd get it there and not be able to reproduce it, but now that its more consistent and a bit louder I shouldn't have any problem making it squeak. Wondering if I can get by waiting til my next oil change coming up in 2500 miles or so or if I should go ahead and take it in next week sometime.
  8. Sep 23, 2016 at 4:03 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Stop eating Mexican. Should stop the squeak and prevent any fallouts.
    You're welcome.
  9. Sep 23, 2016 at 6:37 PM
    jburson250
    jburson250 Pensioner
    Newmarket, NH
    14 Limited TRD Crew Max
    TRD Pro Suspension, Custom Audio System.
    Hey Mike, just reviewed your build. Have you installed the Pro Skid Plate?
    It can make an annoying snap or pop as the truck rolls over uneven (side to side) surfaces - forward or reverse.
    It's actually near the center of the truck, but hard to locate due to what the sound might reflect off of.
    If it can pop (mine did) maybe it can squeak, too.
    There's a fix I can link you to, if interested.
    But if you haven't got the Pro Plate, never mind. The steel one doesn't do it.
  10. Sep 23, 2016 at 6:55 PM
    I have a weird sqeek come from my rear from time to time as well. Very uncomfortable in closed door meetings.
  11. Sep 23, 2016 at 7:10 PM
    Or get a better sound system and crank it up a little
  12. Sep 23, 2016 at 8:06 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Don't forget to crack the window a bit.
  13. Sep 23, 2016 at 8:11 PM
  14. Sep 23, 2016 at 8:28 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Not talking about this crack.
  15. Sep 23, 2016 at 9:24 PM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    I had a really annoying high pitch squeak from time to time. Ended up tracking it down to something on the spare tire carrier. Some WD40 and squeak be gone. Just crawl underneath and try to wiggle your spare around.
    Worth a shot!
  16. Sep 23, 2016 at 9:27 PM
    Probably a long shot...but double check all your bolts that mount your bed to the frame. (Like I said....a long shot)
  17. Sep 23, 2016 at 10:04 PM
  18. Sep 24, 2016 at 5:03 AM
    scout495
    scout495 New Member
    Same thing here. 2016 Tundra Pro with 18k miles. Toyota service already lubricated the bushings and that didn't work. I am bringing it in this week for them to take another look. I can duplicate the squeak by closing either rear door, though the sound is coming from somewhere in the bed. I also noticed that when it rains or there is moisture in the air you don't hear it.
  19. Sep 24, 2016 at 6:36 AM
    jburson250
    Newmarket, NH
    Was it the seat itself, or a frequent occupant? Clever solution, either way!
    BTW Ron, a viola is a large violin.
    NewImprovedRon and T-Rex266 like this.
  20. Sep 24, 2016 at 8:18 AM
    jburson250
    Newmarket, NH
    Thank you Ron.
    Proper spelling, grammar and punctuation are critical components of the stellar technical accuracy common and expected here on tundras.com, especially when addressing challenging issues such as annoying, intermittent rear-end noises.
    Run-on sentences should be avoided, as well. ;)
    ToyotaTundraMike[OP] and joonbug like this.
  21. Sep 27, 2016 at 8:14 AM
    RussellVaughan
    Houston
    i'm 99% positive my stock skid plate is doing this. every morning i reverse downhill and to the right out of my driveway. as i drive forward, POP! started after my 15k oil change. i took the plate off then retorqued all the bolts. now instead of a POP! its more like a pop. still annoying. What's the fix you're talking about? Would it apply to the stock plate?
  22. Sep 28, 2016 at 6:08 AM
    jburson250
    Newmarket, NH
    @RussellVaughan
    Hey Russell, sorry for the delayed response.
    Did you drive the truck with the skid plate removed? Any popping, then?
    My truck's a Limited, so I had the steel plate for about 18 months - no issues at all.
    Having more money than good sense, I bought a Pro plate - no issues for the first few months, then a pop during slow rolls over uneven surfaces (side to side) started.
    I thought for sure it was from the suspension - recently installed TRD Pro - but thankfully, it wasn't.
    Eventually found this Thread on TundraTalk. The fix is in Post 53. My response after I did the fix is Post 54.
    http://www.tundratalk.net/forums/tu...-issues/475906-popping-sound-front-end-4.html.
    Hope you find and stop the pop!
  23. Sep 28, 2016 at 6:34 AM
    RussellVaughan
    Houston
    Thanks! I plan to remove the plate this weekend so I can be absolutely positive. If it's the plate, which I'm guessing it is..then I think the rubber fix should work for me too.
  24. Sep 28, 2016 at 6:42 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    If it isn't your skid, you may want to check your bed bolts. Mine was making a loud pop every time I pulled into or out of my driveway until I realized that the line-x guy didn't tighten them down almost at all. I tightened them down and no more popping. It's a T55 bit for future reference.
  25. Sep 28, 2016 at 6:50 AM
    ToyotaTundraMike
    2015 Tundra
    Been raining a lot lately so haven't had time to stop by the dealership at all. Gonna get under the truck this weekend with some WD-40 and go to town and see if I can make it go away. Hoping I can track it down like this that way I know if anything needs to be replaced.
    Appreciate all the suggestions and opinions! Even the one about not eating mexican lol.
  26. Sep 28, 2016 at 7:02 AM
    jburson250
    Newmarket, NH
    For sure it was Ron. The Pro plate, being a long flat aluminum sheet, probably does a fine job of amplifying sound.
    Russell, maybe some rubber washers would work well with the steel plate, rather than the sheets. From what I remember, the steel one doesn't have as much surface area in contact with the truck frame as the Pro plate does.
    Excellent suggestion Kevin! I checked mine post-linex, as well. Fortunately, they were tight. "Trust but verify"
    Hope you find it Mike!
  27. Feb 25, 2019 at 8:56 AM
    Redz315
    Redz315 New Member
    Mark
    2014 Tundra SR5
    Stock for now but love the truck
    I also have a 2014 Sr5 about to roll 90,000 miles and am having some “squeaking” issues which sounds like from the left rear. At first I thought it was my brakes so I pulled all the tires and brakes are good all around. It use to just make noises when I would hit the brakes. But now it does when driving at any speed the only time it will stop is as soon as I hit the brakes it stops and will just make normal brake noise. I have also checked the spare tire and seems good to me. I’m just lost because it would only do it before when hitting the brakes but now it only stops when I hit the brakes. This is also my first tundra so any pointers/help would be greatly appreciated. An after searching around it seems like this left rear squeaking noise happens to a lot of people.
  28. Feb 25, 2019 at 2:21 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Ask @ARamirez73 he gets plenty of squeaks from his rear.
    SuperSilverTundra likes this.
  29. Feb 25, 2019 at 2:27 PM
    SuperSilverTundra
    SuperSilverTundra i didnt pull up i Landed
    Nick
    Los Angeles California
    16 TUNDRA 5.7 PLATINUM-PRO
    3"/1" TOYTEC 18x9 XD818 Heist 295/70r18 COOPER XLT DirtyDeeds BAMuffler 2018 LEDs KatzKin Leather S&B CAI
    :rofl::rofl:
    Law323[QUOTED] likes this.
  30. Jul 5, 2020 at 8:29 PM
    van
    van New Member
    Van
    '08 5.7 Dbl TRD ; EggNoG
    Custom Thru Fender Exhaust Custom Bull Bar Custom Body Paint Custom SS Hood Vents ...Lights, etc..etc..
    Yeah, More cowbell, Less Sqeak Hell
