Annoying noise
Discussion in 'General Tundra Discussion' started by JROCK915, Apr 6, 2015.
  1. Apr 6, 2015 at 7:19 PM
    JROCK915
    JROCK915 [OP] Trust noone, and be prepared!
    Jeremy
    Palm Desert, CA.
    2011 Trail ready SR5
    Icon 1.5" leaf pack, w/ Pro Comp 1" block Rear Pro Comp SS shocks ToyTec/Eibach coil overs, on Pro Comp SS shocks, SPC UCA AFE Stage II C.A.I, and throttle body spacer N-Fab nerf bars N-Fab RSP front bumper with Hella Optilux 30" LED bar, and Hella Optilux 4" (2) HID driving lights Federal Couragia 33x12.5x20, wrapped around 20x9 Fuel Boost Fender flares Spyder LED tail lights (smoked out)
    I'm getting an annoying noise while @ 35-55 mph (after 60, the tire noise kicks in). I know it's coming from the front dust shields. My guy has tweaked them a few times. It's not unbearable, nor does it seem be be causing any mechanical issues. Just a light ear sore at certain times.
    My questions is: Has anyone removed their dust shields? If so, any problems? If not, is it a bad idea to?
    Thanks!
  2. Apr 6, 2015 at 7:45 PM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    You sure it's not a ball joint or wheel bearing going south? Causing a slight movement alowing to hit the dust sheild?
    JROCK915[OP] likes this.
  3. Apr 6, 2015 at 10:33 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I was thinking wheel bearing. Lift the truck and spin the wheel. You will hear or feel a difference if one is going bad.
    Is there any physical sign that the dust shields are being contacted/rubbed? Are they tight, or maybe slightly loose. Haven't pulled mine off yet to know how they are attached. Hub or brake caliper.
    Are the brake pads thick enough to not need replacement? Is the rotor showing signs of warping or grooves?
    T-Rex266 and JROCK915[OP] like this.
  4. Apr 6, 2015 at 10:34 PM
    JROCK915
    Jeremy
    Palm Desert, CA.
    I'll have him check this week. Didn't think of that.
    He made some adjustments to the dust shield, and it sounds 90% better than when I first heard it. That's the only reason I was thinking it could still be that.
    Thanks for the suggestion.
  5. Apr 6, 2015 at 10:41 PM
    JROCK915
    Jeremy
    Palm Desert, CA.
    It started after the spindles & coils were installed. He made adjustments to the dust covers. It's 90% better now.
    Brakes seem to be really good. I'll double check it.
    It's going back to shop this week for bumper upgrade. I'll have him check the joints/bearing.
    Thank you.
  6. Apr 8, 2015 at 6:08 PM
    JROCK915
    Jeremy
    Palm Desert, CA.
    Bumper additions are back from powder coat. Gonna drop her off, in the am.
    My guy says dust shields are clear. Looks like it may be the wheel bearings. I'll know for sure tomorrow.
    Anyone recommend a brand? I'm reading good things about SKF. Plus, they're warranted for 100,000 miles.
  7. Apr 8, 2015 at 6:46 PM
    Virgils12
    Gotta love a warranty!
  8. Apr 8, 2015 at 8:30 PM
    csuviper
    Broomfield, CO
    If new spindles were installed make sure that the dust seals were installed on the back side of the bearing. They were missed by the installer on my Tacoma when i got a 6" lift. Had one wheel bearing go out within a month or so and the other 6 months later. Got sand and dirt right up to the bearing.
  9. Apr 8, 2015 at 8:49 PM
    JROCK915
    Jeremy
    Palm Desert, CA.
    Unfortunately, don't think warranty will cover them, due to 3" spindles, UCA and Coilovers. IF it's something my guy forgot during the install, he'll cover it.
    csuviper, I ask him to check that too. Is it something I could notice, if I crawl under it?
  10. Apr 8, 2015 at 9:58 PM
    csuviper
    Broomfield, CO
    No its on the back side of the spindle where the CV attaches and is hidden by the cv
  11. Apr 8, 2015 at 9:59 PM
    csuviper
    Broomfield, CO
    Its listed on this drawing as Item #2: Knuckle Seal
  12. Apr 9, 2015 at 5:43 PM
    JROCK915
    Jeremy
    Palm Desert, CA.
    You rock csuviper! Thanks for the help & illustrations.
    My guy (Stan @ Crawluroffroad, if you guys have any Jeep toys and are in SoCal, he's the man. Good w/ my truck too.) said that it could very well be a ball joint starting to go bad. BUT, he said there's no play in it any where (either side). And of course...I didn't hear the noise this morning, nor did he hear the noise on a test drive.
    He said the spindle is completely sealed and feels/looks good.
    Thanks for all the help. I'll keep ya posted.
    On a lighter note. Front bumper is back, mounted and wired. Super stoked. I'll post picks later, when the sun goes down.
