Amsoil in 5.7
Discussion in 'General Tundra Discussion' started by camerond, Sep 9, 2022.
  1. Sep 9, 2022 at 6:56 AM
    camerond
    camerond [OP] New Member
    I just purchased a high mileage 2014 tundra with a 5.7 engine. I am switching the oil to amsoil ss from here on out. I ordered 6 oem oil filters without thinking about an amsoil filter.. can I run oem filters with amsoil signature series or should I buy different oil filters?
  2. Sep 9, 2022 at 7:13 AM
    18" TRD Off Road Wheels
    Of course you can use OEM filters (or any other filter) with that (or any other) oil.
    07 Tundie and KNABORES like this.
  3. Sep 9, 2022 at 7:59 AM
    Welcome from NY.
    Yes on the filters.
  4. Sep 9, 2022 at 8:03 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Welcome from Austin. What kind of OCI are you going with?
  5. Sep 9, 2022 at 8:11 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    I wouldn’t mix and match oil filter with oil, but I’ll pay for the shipping and take those factory oil filter off your hands…lol
  6. Sep 9, 2022 at 8:24 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Yes you can. Love Amsoil
  7. Sep 9, 2022 at 3:46 PM
    camerond
    I will be running either a 1 year/10,000 interval or if for some reason I start getting past 10,000 in a year I’ll go every 6 months.
  8. Sep 9, 2022 at 3:52 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I'm running an OEM filter with Amsoil SS
    e30cabrio likes this.
  9. Sep 9, 2022 at 3:53 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    10k?? :goingcrazy:
    nobodyintexas, Sumo91 and hagrid like this.
  10. Sep 9, 2022 at 3:58 PM
    camerond
    Excuse me, I mean 6months/5k miles. I like to do it in the spring and in the fall. Will an oem filter be fine for 6months/5k on amsoil?
    texasrho83 likes this.
  11. Sep 9, 2022 at 4:00 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    For sure.
    GODZILLA likes this.
  12. Sep 9, 2022 at 7:48 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Without a doubt. I've been doing 10k OCIs and change my filter every 10k as well. I also cut open open my filter after the oil has drained from it for a week or so and see if there is an carbonaceous build up, or anything unusual. Nothing so far.
  13. Sep 11, 2022 at 6:07 AM
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    What brands of filters would be synthetic media?
    I have been using the OEM filters, but now am thinking of changing.
  14. Sep 11, 2022 at 6:55 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    No expert here, but if these synthetic filters are able to "filter MUCH better", would it not stand to reason the synthetic filter has to be changed MORE often?
    If it is collecting more, smaller particles, won't it clog up more quickly, necessitating more frequent replacements inorder to maintain oil pressure and flow?
    An extra oil change (and filter) over the year is not going to break my body or the bank.
    I personally plan to keep it simple. Use quality oil and change it and the OE filter at 5k miles. Also reminds me to rotate my tires.
  15. Sep 11, 2022 at 7:00 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Welcome!
    I have been running Amsoil SS & OEM filters for years. I live in extremely high air particulate Az and do 3.5-5k changes and get great reports from Blackstone.
  16. Sep 11, 2022 at 7:07 AM
    COTundie
    Trey
    Pretty things
    Not sure I buy it.
    If simply comparing filter to filter, we must also assume the engine will produce(?) The same amount of contaminants. Keeping everything else consistent, I still maintain the filter rated to remove smaller particles will clog up more quickly.
    If I were using said filter, I would be inclined to replace it more frequently. Which is why I will continue not to use them.
  17. Sep 11, 2022 at 7:23 AM
    e30cabrio
    I'm not advocating for them but here is what Amsoil says:
    https://www.amsoil.com/p/amsoil-oil-filter-eaoilfilt/?code=EA15K04-EA
    AMSOIL Oil Filters feature advanced full-synthetic media that traps and holds a greater amount of small, wear-causing contaminants compared to conventional and other high-efficiency filters.
    See the Product Data Bulletin for full details.
    Advanced, Full-Synthetic Media
    • Provides filtering efficiency of 99 percent at 20 microns1
    • Allows lower restriction, keeping engine parts lubricated
    • Provides greater capacity for small, wear-causing contaminants than competing filters
    • Helps reduce engine wear
    1In accordance with industry-standard ISO SO 4548-12.
    99% Efficiency at 20 MicronsAA
    Filtering particles >20 microns fights engine wear.
    I might try one, I'm willing to give Amsoil the benefit of the doubt.
  18. Sep 11, 2022 at 8:21 AM
    Sumo91
    TN
    Synthetic filters on these trucks are a waste of money. My truck has 247k on 10k OCIs with regular OEM filters from the dealership. I do regular UOAs as well, so if my OEM filter wasn't filtering correctly, it would show that in either wear or particle count. These engines are extremely reliable and easy on oil, a synthetic filter isn't going to provide any negligible amount of engine life by filtering a few microns better compared to an OEM filter
  19. Sep 11, 2022 at 8:23 AM
    COTundie
    Trey
    Pretty things
    This is the only point I was attempting to make, since you had mentioned feeling comfortable with longer filter change intervals.
    I will obviously continue to do what I am comfortable with (quality synthetic oil with OE filter @5k miles), regardless of your sarcasm.
    Not looking to trash your filter, just passing on what is logical in my mind regarding finer filter media.
