Amsoil for Tundra 2020 Towing ATF and Dif
Discussion in 'Towing & Hauling' started by flipnlyd, Jan 12, 2021.
  1. Jan 12, 2021 at 5:02 PM
    flipnlyd
    flipnlyd [OP] New Member
    After reading all the hubbub about Trans Cooling issues in the 19+, I am looking to see opinions on Amsoil full synthetic ATF and Dif fluid changes and thoughts on better temp management... let’s talk!
  2. Jan 12, 2021 at 5:12 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Highly unlikely that the temps would be reduced by any significant manner.
  3. Jan 12, 2021 at 7:51 PM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    The temperature will not drop significantly as so much of the temperature is contributed to the hydraulics of the torque converter. If under warranty, non Toyota tranny fluid is a great way to get warranty work voided.
    Metro14536 likes this.
  4. Jan 12, 2021 at 7:55 PM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    I've heard of Amsoil. Is this what you mean?
  5. Jan 12, 2021 at 7:57 PM
    GravityGear
    GravityGear Parking Lot Prerunner
    Aurora, CO
    2014 Black DC TSS Off Road 4x4 5.7
    Transfer Flow tank, Pinstripe Suit
    Amsoil users are like those people that knock on your door at inopportune times. Now that you've mentioned it, they're going to come to your door asking if you've met their lord and savior Amsoil, then give you a pamphlet as big as the phone book. They're like the Falken Wildpeak AT3 users.
  6. Jan 12, 2021 at 7:58 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    I wouldn't change the fluid unless it is time on maintenance schedule. It would be interesting to be able to see the difference with a Temperature scanning device. Is the Amsoil fluid rated for higher temps? It may not lower the temps but if rated for higher Temps.......
  7. Jan 12, 2021 at 8:01 PM
    619Tundra
    Amsoil is the best oil. Tests have shown it is the best.
    jordoncloutier and anthonygan like this.
  8. Jan 12, 2021 at 8:40 PM
    crewmaxlmt
    scott
    Not to be an ass, but if it is so good why don’t they get approval from Toyota as an approved replacement? Not saying that it is not better; it’s just a big gamble on a warranty. Also, do they really have your back? Or are they just trying to sell product?
    Sorry for the rambling but I have just been listening to the same thing for 20 years.
    Cpl_Punishment likes this.
  9. Jan 13, 2021 at 5:40 AM
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    I think OP was thinking the AMSOIL would handle the heat better and avoiding issues with stock fluids.
  10. Jan 13, 2021 at 6:08 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    :duh:
    :ohsnap:
  11. Jan 13, 2021 at 6:21 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Are you saying the newer Tundras don’t have a transmission cooler? Let’s talk about this.
  12. Jan 13, 2021 at 6:55 AM
    mountainpete
    Fixed it for you.
  13. Jan 13, 2021 at 7:23 AM
    Blue Thunder
    Washington
    Sounds like you have a solution in search of a problem. The debate is around the lack of cooler, not that Toyota’s oil is insufficient. No one has shown the OEM oil is not up to the task.
    If you are concerned with cooling, get a cooler. If you are just trying to talk yourself into the expensive oil, well there’s nothing anyone can do here to help. We all suffer from the “Must Justify” flu on occasion.
    GODZILLA, Wallygator and 619Tundra like this.
  14. Jan 13, 2021 at 7:24 AM
    Trooper2
    JR
    There is already at least one thread dedicated to it.
    Seems it may be a cost savings by Toyota. But their engineers had to be on board.
    Folks are adding back the cooler to their newer models.
  15. Jan 13, 2021 at 8:53 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    I was just being an A hole. I’m well aware of the hoopla on this site. :rofl::stirthepot::stirthepot::stirthepot:
  16. Jan 13, 2021 at 8:58 AM
    AZBoatHauler
    So.Arizona
    Kywildman, GODZILLA, hagrid and 3 others like this.
  17. Jan 13, 2021 at 9:01 AM
    Trooper2
    JR
    I should have known better, LOL
  18. Jan 13, 2021 at 4:24 PM
    flipnlyd
    Thanks... I have researched the crap out of the missing cooler issue was just thinking Amsoil might have higher viscosity and breakdown temperatures. I don’t believe Toyota would remove the cooler if it was bad for the truck transmission. Just wanting to see if anyone had looked into the “hot fluid” reduction of a aftermarket oil.
  19. Feb 1, 2021 at 6:26 PM
    The Dude
    The Dude New Member
    Chandler, AZ, not anymore :(
    I don't know about automobiles, but I have switched to AMSOIL in my 2001 GSXR 750, many years ago, and immediately noticed smoother shifting. Especially, going from N to 1st, and 1st to 2nd.
    619Tundra likes this.
  20. Feb 1, 2021 at 6:30 PM
    Brownsfanhere
    Brownsfanhere New Member
    2015 Crew Max
    *looks away and whistles softly*
  21. Feb 1, 2021 at 7:04 PM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    Because while Amsoil is better and surely exceeds Toyota’s standards, it is not cost effective for a manufacturer who sold 2.1M vehicles in the US last year. This is the same Toyota that deleted items like the drivers grab handle and the trans cooler from the Tundra. Also, Toyota gets cheaper oil elsewhere (Mobil1 engine oil, for example) that meets their standards.
    Suppose the fluid can handle extremely high temps. Does it then follow that those temps are good for the transmission itself?
    We have one Toyota engineer directly involved with the trans cooler, a contact of ColoradoTJ’s, speaking (1) NOT in a Toyota PR capacity and (2) on condition on anonymity that the external trans cooler deletion was a mistake, a penny pinching measure that will end up costing Toyota dollars when the failures from high temps—which this engineer said they’ve already seen—start to show up.
    What I want to know is, how many miles were driven under what conditions that caused the failures this Toyota engineer is talking about? o_O
    I added an ext cooler, which was a very simple install, and will stick with OEM trans fluid for the remainder of my warranty. Then it’s Amsoil for me! :spending:
  22. Feb 1, 2021 at 8:12 PM
    619Tundra
    Amsoil outperforms all engine oils. It is more expensive than Mobile 1. What is your argument against it?
    The Dude likes this.
  23. Feb 6, 2021 at 7:23 PM
    jordoncloutier
    jordoncloutier New Member
    Jordon
    Alberta , Canada
    2019 Tundra CrewMax SR5 Plus 4x4
    Daily Driver / Tow Vehicle , Retrofitted Trans Cooler , 10 Ply tires , Raptor Lined Ranch Hand Grille Guard
    Amsoil signature ATF is 100% synthetic , Toyota Ws atf is a semi synthetic made by exxon mobil for toyota , its a mediocre atf , nothing special . Amsoil atf clearly states on that it can be used in place of Toyota WS . No reason to think that warranty will be a concern . On my 2019 I retrofitted my own trans cooler and swapped out the atf for amsoil signature series , I noticed an instant improvement in shift quality. I also run amsoil severe gear 75w90 gear oil in my Diffs.
    I tow my 6500lb Jayco TT in the summer , trans temps stay nice and cool around 200 consistently.
  24. Feb 6, 2021 at 8:11 PM
    I use AMSOIL in my truck now. Started with the differentials and transfer case. The Allison will still get full synthetic Transynd from the factory, which has so close performance results with AMSOIL that most wouldn't even notice the difference. Understand, this is still a premium synthetic transmission oil, not a "blend".
    Lexus will be getting ASMOIL signature series ATF and 75/90 rear diff lube.
    ryanwgregg, Wallygator and 619Tundra like this.
  25. Feb 7, 2021 at 5:34 AM
    shoe07
    shoe07 New Member
    Ohio
    2004 Tundra Double-cab SR5 Tow pkg
    Where do you buy amsoil products for a reasonable price?
  26. Feb 7, 2021 at 7:09 AM
    blanchard7684
    blanchard7684 New Member
    Just like adding an additional cooler, adding the AMSOIL full synthetic will give you some additional margin of safety if you are towing at full capacity all the time. Changing fluid won't affect heat transfer in this situation.
    There are also higher capacity aluminum pans with cooling fins. PML Toyota AB60E, AB60F Deep Transmission Pan (yourcovers.com)
    There are group iii synthetics and group iv synthetics. This came from the improved processing of group ii oils into what is known as group iii oil but also a lawsuit between Mobil and Castrol.
    Group iv synthetic is a PAO based oil that isn't 100% derived from a refinement of crude oil. Group iii synthetics are derived from a crude oil but are processed extensively including catalytic dewaxing and a process called severe hydrocracking.
    The amsoil full synthetic is a PAO based (group iv) oil. Its ability to sustain >300F temps is greater than a group iii oil (like WS). Group iii oils are technically considered synthetic and have performance very near to a PAO oil. A major oil OEM (an oil super-major) I've recently worked with has tested their group iii base oils to 280 F and found no thermal degradation (inferred by acid concentration). Degradation was perceptible at temps above 300F. Group iv PAO synthetics are capable of >350F with no thermal degradation.
    So the PAO group iv stuff can give you some extra margin at higher temps. The boutique oil manufacturers also have different additive packages that can assist in lowering wear on mechanical components. Word of caution--when switching to a PAO make sure the oil manufacturer has thoroughly tested the oil blend for adverse effects on soft goods like seals and o-rings. Some materials don't work well with PAO...
    For reference Base Oil Groups Explained (machinerylubrication.com)
    ryanwgregg, Terndrerrr and Wallygator like this.
  27. Feb 7, 2021 at 7:25 AM
    Wallygator
    No it's not. As long as it is in spec with Toyotas requirements, any fluid is valid, and Toyota would have to prove it was the fluid that caused the issue.
  28. Feb 7, 2021 at 7:31 AM
    Catmann1972
    Catmann1972 New Member
    Greg
    Rhode Island
    2020 TRD Sport
    Very harsh comment...But I like it and it is spot on.:thumbsup:
  29. Feb 7, 2021 at 8:04 AM
    AZBoatHauler
    So.Arizona
    I just order direct off their website.
    OHwendTrd and Wallygator like this.
  30. Feb 7, 2021 at 12:34 PM
    crewmaxlmt
    scott
    The problem lies with manufacturers not releasing formulas and not approving companies like Amsoil to offer a replacement fluid. They have been doing this for decades. You may win out in the end with Toyota. But that would be a long and expensive battle. Heck, it probably would be cheaper to replace a transmission yourself than battle an automotive manufacturer about whether Amsoil contributed to the failure.
