Amp running boards
Discussion in '2.5 Gen Tundras (2014-2021)' started by 510Krish, Jan 20, 2019.
  1. Jan 20, 2019 at 8:56 PM
    510Krish
    510Krish [OP] New Member
    2018 Toyota Tundra Platinum 4x4
    Hey, does anyone know if I can install amp boards on a 2018 Toyota Tundra. If so, how do I install it? I know that the plug n play don’t work from the 2017 have they made something that’s works on the 18s? If not what’s the alternative
  2. Jan 20, 2019 at 9:51 PM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
  3. Jan 21, 2019 at 7:52 AM
    pughfish
    pughfish New Member
    William
    Fayetteville, NC
    2024 Tundra Celestial Silver Metallic, Capstone
    I love those LED strips.
  4. Jan 21, 2019 at 8:40 AM
    510Krish
  5. Jan 21, 2019 at 8:47 AM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    I installed them on my 2016. Will be the same for 2018. You don't want plug & play - unless you don't mind your OBD port used, or spending extra money on an OBD splitter. Just wire it directly to the battery & be done with it. It's easy. The provided instructions, from what I remember, are fairly decent - they should provide you with all you need. I also used this video - pretty helpful:
    https://youtu.be/FvNGJLMrVic
    Good luck. They're great running boards.
    r1-superstar likes this.
  6. Jan 21, 2019 at 9:52 AM
    spryan
    spryan New Member
    Shawn
    2019 white CM
    I have a 2019 that I’ve installed the steps and have wired the pass side. I’m a novice would say a level 2/3 out of 10 when it comes to wiring. My butthole puckers and I sweat. Was able to install the pass no worries. Live in Maryland and it currently minus 14 on the wind chill. 30-40 mph winds. Feels like the frozen tundra. I know, I know. Most of you live in colder states and I should just suck it up.
    I’ll be wiring the driver side when it’s above 40 degrees. Very nervous about this side :(!
  7. Jan 21, 2019 at 10:28 AM
    r1-superstar
    DB
    UTAH
    Yes, it was a bit difficult at first to find the proper wire. Here is a picture showing exactly which one to tap in to.
    The blue arrow is pointing to the exact wire.
  8. Jan 21, 2019 at 10:57 AM
    spryan
    spryan New Member
    Shawn
    2019 white CM
    Is that for the driver side rear door? And it’s pointing to the red one?
  9. Jan 21, 2019 at 2:08 PM
    r1-superstar
    DB
    UTAH
  10. Jan 21, 2019 at 2:12 PM
    spryan
    spryan New Member
    Shawn
    2019 white CM
