amp research power steps
Discussion in '2.5 Gen Tundras (2014-2021)' started by tjacob95, Nov 1, 2024.
  1. Nov 1, 2024 at 2:52 PM
    tjacob95
    tjacob95 [OP] New Member
    2014 toyota tundra limited
    anyone know if there is a website running a deal on the amp research power steps, or just the best and cheapest place to buy them ...thanks
  2. Nov 1, 2024 at 3:03 PM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Normally they're $1,799 for the plug and play version and they're currently on a $300 off promo direct from Realtruck which we're matching ($1,499). That said, we've got them over here at Hotshot Offroad, and as long as you're in the lower 48 I can probably save you a few bucks! Shoot me a message with your zip code and I'll see what I can do!
  3. Feb 10, 2025 at 7:19 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    '18 Tundra TRD Sport 2WD 5.7 Crew Cab MGM
    What's the plug n play version? Does that mean no needing to splice into the wires behind each kick panel?
  4. Feb 10, 2025 at 8:56 PM
    Oolypoolay
    Oolypoolay Meh
    2015 Limited Crewmax
    Bilstein 6112/5160 Method 702 0 offet Toyo open country 285/75 17 Form led headlights OEM Toyota led fog lights Morimoto 3rd brake light Morimoto tail lights Amp Research power steps
    Pretty sure that the plug and play version comes with the OB2 plug and controller. That did not require you to splice, run the 2 wires to the ob2 dongle and plug it in.
  5. Feb 10, 2025 at 9:52 PM
    TacomaTRD4x402
    Southern California
    Yeah, I do see that AMP has a "pass through harness" that basically turns your 1 OBD to 2 to allow connecting to OBD. Cost of that is $120
    One of the bulleted features for the steps states "Newer applications connect to OBDII port via Plug-N-Play module".
    So I'm wondering if my '18 is considered a "new application"
    If all what the pass through harness from AMP does is creates a 2nd OBD than I could just get the splitter from Banks for $30. I might give that a try and see if that works.
    @memario1214 I sent you a DM for pricing for the steps. Thank you
    memario1214 and AZBoatHauler like this.
