Amp-Research bed extender for 2022, bracket PT392-34220-BK?
Discussion in '3rd Gen Tundras (2022+)' started by Trumbo, Nov 16, 2022.
  1. Nov 16, 2022 at 7:33 AM
    Trumbo
    Trumbo [OP] New Member
    David
    2022 Toyota Tundra 4x4
    I have an amp-research bed extender model AMP74803-01A and need to mount it on my 2022 Tundra Limited Crew Max SB. I don’t have the mounting bracket. I checked with Toyota and they have a bracket part #PT39234220BK but it’s not in stock and don’t have a picture of it. Anyone have this bracket or installed the amp-research with a modified or original bracket on a 2022? Thanks
  2. Dec 5, 2022 at 6:09 AM
    TundraLifeIsGood
    TundraLifeIsGood New Member
    I'm in the same spot as well. Recently got the same amp research bed extender model for my 2022 Tundra and would like to use a no-drill bracket. Amp research has a no-drill bracket that fits the previous generation Tundra (P/N 74614-01A). Can anyone here confirm whether that bracket would work on the 3rd generation Tundra? I looked at both beds (2021 and 2022) and it looks like the mounting location of the no drill bracket is the same. The 2021 has the steel bed and the 2022 has the composite bed but the hook locations (both sides of the bed) including the angle of the mounting locations look identical.
    I could be wrong?
    Or does the Toyota OEM bracket work with the amp product? If so, that might be the better bet as it definitely works with the 2022.
  3. Dec 8, 2022 at 4:10 PM
    Trumbo
    David
    I bought the Toyota no drill bed extender bracket part number PT392-34220-BK and it worked perfectly. No drilling, just unscrew, attach the bracket and rescrew it in. Perfect!
  4. Jan 5, 2023 at 7:52 PM
    Yota802
    Yota802 New Member
    2023 Tundra Hybrid Limited CM WP
    I just installed the Toyota OEM bed extender, 10mins-NO DRILL. Not sure why anyone would want to go aftermarket with this option available. $270
  5. Jan 25, 2023 at 4:57 AM
    obgod3
    obgod3 New Member
    NC
    2023 Tundra Limited
    Not sure that you figured this out but I have a older ReadyRamp that has been on several of my trucks, its not the cool fold in and doubles as a ramp. But the cool thing is they use tailgate clips that make it super easy to lock in and remove, and their is no permeant installation. The replacement hardware kit worked great on my 23 Tundra.
    https://readyramp.com/
    https://readyramp.com/shop/replacement-hardware-kit/
