American flag headliner
Discussion in 'General Tundra Discussion' started by airosey, Dec 11, 2018.
  1. Dec 11, 2018 at 6:39 PM
    airosey
    airosey [OP] 2009 CrewMax Limited 4x4
    East TN
    Slightly modified 2009 CrewMax Limited 4x4
    09 Tundra CrewMax Limited TRD Supercharger with URD pulley Tuned by OrangeVirus tuning (OV Tune) TRD Big Brake Kit with SS lines and titanium backing plates StopTech rear sport axle pack (rotors, pads, and SS lines) 7” Pro Comp lift 3” Performance Products Body Lift Coachbuilder 1” coilover shims Coachbuilder +3 shackles Coachbuilder Tie-rod ends 22x14 -70 Fuel Lethal’s - 2 piece 38x15.5 Mickey Thompson Baja Boss M/T’s King Shocks with remote reservoirs front and rear Nitro 5.29 gears front and rear Auburn LSD SPC adjustable UCA’s BAM 8” exhaust Pro Comp Traction Bars Enve Grille Smittybilt M1 front bumper Rough Country 12k lbs winch Demon Hook shackles front and rear Baja Designs Squadron Sport Amber and clear fog lights ADD HoneyBadger Rear Bumper with Rigid SR-Q reverse lights Sequoia Headlight conversion Switch-Pros SP-9100 mounted in overhead console SD Off-road MT under-hood tray AEM boost and afr gauges Hypertech Speedometer calibrator Bed and rear bumper are Bulletlined American Flag Headliner Mammoth Guards patriot edition Alpha and Omega Fabrication Patriot Hood shield 3rd gen door panels and steering wheel ProSpeed Catchcan Hornblasters Outlaw train horns Tufskinz real carbon fiber overlays Tufskinz carbon fiber B panels vLEDs footwell lighting front and rear vLED puddle lamps Lighting Trendz flow series wheel rings 16 RGB rock lights Toyota Bedmat Bestop Power folding steps Undercover bed cover Undercover SwingCase 4 gallon Rotopax fuel can Here’s a rundown of the audio setup. -Active front stage using a JL Audio TwK88 DSP, Focal 165KRX2 component speakers, powered by a JL Audio HD900/5 -Passive rear setup with Focal 165KRX2 component speakers -2 JL Audio Stealthboxes (13TW5’s) powered by a JL Audio HD1200/1 -Sony XAV-9500ES float mount display with a PAC Radio Pro 4 -Odyssey battery -JL 0 gauge power and ground cables -AudioQuest X-2 speaker cables and Golden Gate RCA interconnects -Entire cab has been lined with Dynamat Extreme and 1/4 CCF Amps and dsp are mounted under the passenger seat with a SoundsGoodStereo mounting plate.
    I’m a submarine veteran and really wanted to display the flag in some form. Yes, the stars should be over the driver, I didn’t notice until I was almost complete. I’m on the fence about it, but if I decide to rock it I’ll go ahead and recover it with the flag in the correct position, cover the sunroof panel and sun visors. Let me know what you think.
    IG @blue.streak.tundra
    2livewires, NIOSH, Patch999 and 59 others like this.
  2. Dec 11, 2018 at 6:41 PM
    Navi
    Navi New Member
    2019 CrewMax Limited
    very unique and never seen this before.
    love it.
    how did you do this? some type of felt??
    airosey[OP] likes this.
  3. Dec 11, 2018 at 6:44 PM
  4. Dec 11, 2018 at 6:45 PM
    airosey
    East TN
    I completely removed the original material, glued down headliner foam, then used a 5x8 flag (made in the USA of course)
  5. Dec 11, 2018 at 6:47 PM
    DJFaninTN
    DJFaninTN New Member
    Panama City Beach, FL
    2018 Super White 1794
    pretty cool!
  6. Dec 11, 2018 at 7:00 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I like it.
    joonbug and airosey[OP] like this.
  7. Dec 11, 2018 at 7:48 PM
    geno0506
    geno0506 New Member
    Michael
    Looks Awesome, Tundra Pride!
  8. Dec 11, 2018 at 8:05 PM
    AlmightyCrash
    AlmightyCrash Tundra Rookie, Jeep Veteran
    Crash
    San Leon, TX
    2015 Tundra MGM SR5 TSS CrewMax
    Very impressive.
  9. Dec 11, 2018 at 8:08 PM
    airosey
    East TN
    Thanks, it’ll look much better once I get the sunroof slider and sun visors covered!
  10. Dec 11, 2018 at 8:32 PM
    15whtrd
    15whtrd Mr. Blonde
    That is nice very impressive. But I think it would bug me and I would want it correct. If the stars are supposed to go over the driver that’s where I’d want them. And I think you should do the sunroof as well. But I definitely love it!
  11. Dec 11, 2018 at 8:42 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    Looks BA man!!!
    Technically, the orientation is fine. From the driver side view/door, I get it...you might want the Union over the driver seat.
    If you were laying on the ground, looking up at just the roof, the Union is in the correct position in the upper left corner.
    Either way, it's going forward....which is all that matters!! :headbang: :oldglory::headbang:
  12. Dec 11, 2018 at 8:46 PM
    15whtrd
    15whtrd Mr. Blonde
    I like your thinking!
  13. Dec 11, 2018 at 10:01 PM
    aperezsh
    aperezsh Blessed are the peacemakers
    Ali
    cal-exit landed in GA
    16 Tundra SR5 4x4 Crew Max Magnetic Gray Metallic
    A little this and that...Broke now
  14. Dec 12, 2018 at 5:04 AM
    Grizzly660
    Grizzly660 21 Army Green Sport
    North Dakota
    2021 Army Green Sport
    20 inch XD Hoss wheels with Nitto EXO Grappler Wetokole seat covers
    Looks awesome and something new and different! Thank you for your service!
    Stormtrooper81 and airosey[OP] like this.
  15. Dec 12, 2018 at 5:07 AM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    I like it, big thumbs up.
  16. Dec 12, 2018 at 5:32 AM
    airosey
    East TN
    Thanks, I agree completely. I thought I’d go ahead ahead and make sure I’m going to like it before I redo it. I had to order another flag. I’ll be covering the sunroof panel and sun visors as well.
    15whtrd[QUOTED] and TokerJoker like this.
  17. Dec 12, 2018 at 5:32 AM
    Stormtrooper81
    Stormtrooper81 Slow and steady
    Lost coast
    2011 DC
    Hell yeah. Original and beautiful!!!
    airosey[OP] and TokerJoker like this.
  18. Dec 12, 2018 at 5:43 AM
    airosey
    East TN
    Thank you! Yeah I’m always trying to come up with ways to be a little different.
    TokerJoker likes this.
  19. Dec 12, 2018 at 5:48 AM
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    That is absolutely freakin' awesome!! Great job!
    And thank you for your service!!!!
  20. Dec 12, 2018 at 5:56 AM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    That looks sweet!! Thank you for your service and if you don't mind me asking, what boat were you on? My father is a plank owner of the USS L. Mendel Rivers (SSN-686).
  21. Dec 12, 2018 at 7:10 AM
    airosey
    East TN
    I served on the USS Maryland (SSBN-738). It’s a Trident Ballistic Missile Sub.
  22. Dec 12, 2018 at 7:20 AM
    YZTundy
    YZTundy New Member
    Denver, Co
    2011 Crewmax Rock Warrior
    Most american thread yet! Awesome Idea! :oldglory::yay:
  23. Dec 12, 2018 at 7:47 AM
    TokerJoker
    Travis
    Nowhere, Specific
    None.....yet
    It was a shot that y'all crossed paths at some point.
    airosey[QUOTED][OP] likes this.
  24. Dec 12, 2018 at 7:55 AM
    mlucas555
    mlucas555 New Member
    Mark
    San Antonio, Tx
    2016 MGM Double Cab
    Still rocking the stock height.
    That is awesome! I think that it is good either way, since it's still going forward. It is up to you though. Cannot wait to see the pictures with the sunroof cover on as well.
    GODZILLA and airosey[OP] like this.
  25. Dec 12, 2018 at 7:58 AM
    Very unique to say the least. Pretty bad ass!
    I wonder how the blue/black for fallen first responders would look?
    Thanks for your service shipmate.
    @COMiamiFan @T-Rex266
    This would look bad ass in black interiors.
    15whtrd, TokerJoker and airosey[OP] like this.
  26. Dec 12, 2018 at 8:32 AM
    Fireace
    Fireace New Member
    Oregon
    2018 Crewmax SR5 CM
    BAmuffler Pro Comp 6” lift ADD bumper Smittybilt 10k winch
    Ooh I want to do that with a thin red line flag. I love the look!
    15whtrd and airosey[OP] like this.
  27. Dec 12, 2018 at 9:09 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    love it
  28. Dec 12, 2018 at 10:38 AM
    Outstanding!
  29. Dec 12, 2018 at 10:52 AM
    Ike74
    Ike74 New Member
    Anthony
    Sugar Land, TX
    2020 Kia Forte
    I love it, think it would be too busy to look at daily, but I am envious of it none the less
    airosey[OP] and jewsNbrews like this.
  30. Dec 12, 2018 at 12:42 PM
    airosey
    East TN
    Yeah I could see that. I don’t even notice it while driving. I work from home and do t really drive all that much either.
    15whtrd and Ike74[QUOTED] like this.
