Ambient outside temp reading off and A/C issue
Discussion in '2.5 Gen Tundras (2014-2021)' started by TonyNCo, Aug 23, 2022.
  1. Aug 23, 2022 at 4:05 PM
    TonyNCo
    TonyNCo [OP] New Member
    Tony
    2019 VooDoo Blue TRD Pro
    Audio, 11 channels Kenwood HU, Mini DSP Digital Sound Processor 2 Alpine 4 Channel Amps, 3 Alpine Sub Amps approx 4K watts 3 way Focal in dash, front doors. 6 1/2" in door swapped for 8" 10" Focal Sub, front passenger floor, custom sealed box 2 way Focal rear doors 2 JL Audio 12W6 Subs, behind backseat Aux lights, all but ditch on modified bumper light bar (3 Hella Rally 4000) Spot, Fog, and Euro beam. Euro beam has yellow bulb. 4 White Spot beam LED Ditch 4 Yellow Spot beam LED 42" Curved, Yellow/Fog LED light bar 50" Curved, White LED light bar 295/70/18 Falken Wildpeak, Revolver Bed Cover
    I just had the front windshield tinted with a very mild tint to block heat... Basically a visibility tint. But does block UV, etc... they removed the mirror and put back on. As far as I know they did not do any other wiring or related to cause this.
    My a/c was working normally on the way there. When they were done, the ac works sitting in park. I put it in gear, and sit still the ac stops cooling. Driving no change. Pull over, in park only, works fine again.
    The ambient outside temp sensor is reading from 35F to 45F driving today after the ac stopped working. As far as a I know it was reading correctly this morning. I know prior to today it has been.
    The bubble sensor on the dash, is it only a light sensor? Is it somehow related, as in UV/Sunlight being blocked by the windshield tint.
    I also noticed there is a clicking on and off from the front of the engine that is new. AC clutch?
    Anyone have any thoughts?
    It seems like the window tint is related, but that is an assumption.
  2. Aug 27, 2022 at 2:33 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Solar sensor maybe?
    I assume your ambient temp is off, you didn't mention the real outside temp. Just the range it was showing. Any other symptoms, parts of the truck not working correctly?
    HulkSmurf14 likes this.
  3. Aug 28, 2022 at 7:51 PM
    TonyNCo
    Tony
    Yeah, I forgot to list that. It was around 85. Fast forward, somewhere in reading on posts on here someone said they have had weird issues with a slight voltage drop before a battery quits. I was in the 3-4 year range and replaced my battery. Problem solved! odd...
  4. Aug 28, 2022 at 7:56 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Sucks when things happen at such a coincidental time, but glad that's all it was and was figured out before you pulled the tint back off!!!
  5. Sep 3, 2022 at 7:31 PM
    TonyNCo
    Tony
    Thx! No kidding!!! Funny how Murphy's Law is so interactive!
  6. Oct 13, 2024 at 4:07 AM
    Chuckt127
    Chuckt127 New Member
    Chuck
    2018 tundra crewmax trd offroad
    Well here it is Oct 2024 and I got my windshield tinted and gusse what exactly same problem. Ambient temp reads 46 degrees I'm in el paso real temp 98. And ac will not blow cold. So I read the post at the top and disconnected my battery and hooked it back up fixed temp issues. Still had ac issue It would only blow cold in park. Pulled the relay for mag clutch( Ac compressor) tapped it on the ground and it seems to be working fine now. Crazy issues I think they left the key on at the tint shop and ran my battery down which caused the computer to be reset.
    batman900 and HulkSmurf14 like this.
