Amber DTRL's
Discussion in 'Lighting' started by Tacogrande, Dec 8, 2015.
  1. Dec 8, 2015 at 2:47 PM
    Tacogrande
    Tacogrande [OP] New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Is it just me or do you guys think amber DTRL's are odd? SR5 and Limited i believe have amber dtrl and i think you get the led dtrl on the Platinum.
    Seems like only the Tundras on the road have the ambers...
    I would rather have the LEDs.
  2. Dec 14, 2015 at 9:02 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I will be honest for some reason I like the amber DRL's, not as much as the LED DRL's, but I don't mind them a bit.
    I know the Tacoma's had amber DRL's as well.
  3. Dec 14, 2015 at 9:06 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    I kind of like them... They look good on a black truck. But I have seen some kits that use white light. They look good too.
  4. Dec 14, 2015 at 9:06 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I remember seeing some LED DRL's that are white when solid and turn amber for turn signal. I think it was on the DDM tuning page. Let me look. I was highly considering.
    TruckyTruck likes this.
  5. Dec 14, 2015 at 9:26 PM
    csuviper
    Broomfield, CO
    Well here is one from Amazon. Not the one i remember seeing but similar.
    http://www.amazon.com/gp/product/B00RV46YBC?keywords=led 4157NA&qid=1450157049&ref_=sr_1_2&refinements=p_89:JDM ASTAR&sr=8-2
    Note: you might need to add 50W 6-Ohm load resistors or change flash rely to prevent the LED bulbs from hyper flashing,
    The one i saw had the resistor in the set ready to go. Just cant find it now.
  6. Dec 14, 2015 at 10:06 PM
    csuviper
    Broomfield, CO
  7. Dec 15, 2015 at 4:33 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    I think I know the brand you are talking about @csuviper .
    The Retrofit source also sells an LED switchback and an HD resisitor.
    I have heard that some resisitors run hot, and the whole idea of going through trouble and having an electrical part get hot didn't seem worth it.
  8. Dec 15, 2015 at 5:09 AM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    I myself like the Amber. Would like to find a led in the amber color.
  9. Dec 15, 2015 at 6:23 AM
    csuviper
    Broomfield, CO
