Am I crazy, truck downsizing and towing
Discussion in 'Towing & Hauling' started by mtb_frk, Oct 31, 2024.
  1. Oct 31, 2024 at 3:51 PM
    mtb_frk
    mtb_frk [OP] New Member
    IMG_0787.jpg Hey all
    Ive been stuck in this should I or shouldn't I mode for a while now and hoping for some advice.
    Been considering buying a 21 or earlier SR5. Currently I have a 2018 F350 6.2l truck, and I'm getting tired of driving such a big truck, with such a stiff ride. My wife pretty much refuses to drive it, and I haven't had any death wobble in it, but I'm always afraid its going to happen when she is driving it. Its been my daily since new and have about 65k miles on it. We have a 25' TT, which claims to have a dry weight of 5600 lbs. We pack pretty light and most of our camping trips are just for a couple days and close to home, like 50 miles or less. We camped a whopping two times this year, and I think 3 last year. So 99% of the time Im just driving a huge truck around for no good reason. The problem is the camper has a hitch weight that I weighed of about 900 lbs, which eats up most of the payload of all of the tundras i have looked at so far. We are considering downsizing the camper also, but thats going to require some work to accomplish. Camping season is done here in Michigan, so now is not a good time to try to sell it. Part of me says if I find the right tundra, to just get it and figure out the camper later. The other part of me says I'm crazy to do it as I don't want to overload the truck. Originally when I bought the truck I thought we would be getting into a 5th wheel but ended up in a smaller camper than we had at the time. Missed out on a really nice tundra a couple weeks ago, am still kicking myself for not getting it but here I am...
    Really don't want to go into any of the big 3 trucks like a F150, however my truck has been fine other than a few things. But my wife's 4runner has 210k miles on it and still going strong.
    TIA
    hagrid and Florida AF like this.
  2. Oct 31, 2024 at 4:14 PM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    No you're not crazy. Your camping senario is similar to us as in time, distance, and two of us. So much easier with a smaller setup. And welcome to the site.
    Florida AF likes this.
  3. Oct 31, 2024 at 4:20 PM
    WNY PAT
    WNY PAT New Member
    Western New York
    2017 Crewmax Limited (Mines) 2019 Crewmax SR5 (Work)
    I tow 6Kish quite a bit (equipment trailer, tractor, etc). You'll know the travel trailer is there, much more so than your SD, but if you take it easy it'll be fine IMO. On the highway, if you're on any hills, the 5.7 struggles with that much weight. My snowmobile trailer is closer to 4500lbs and my Tundra is happier pulling that weight longer distances.
  4. Oct 31, 2024 at 4:34 PM
    mtb_frk
    Thanks for the replies.
    Its kind of crazy that my SD only gets around 9 mpg while towing. I guess being that it only gets 13 in daily driving shouldn't surprise me. From what I have been reading I would expect around the same with a tundra while towing.
    Tundra family likes this.
  5. Oct 31, 2024 at 4:39 PM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    Ya, I'm about 10mpg for our 100 mile round trip towing but there are some pretty big hills to climb on the way out.
  6. Oct 31, 2024 at 4:57 PM
    Warreng
    Warreng New Member
    2nd gen tundras do not have the smooth ride of the domestics, you may want to try one and make your own opinion on that.
  7. Oct 31, 2024 at 5:37 PM
    Welcome.
    Have you tried new shocks? A really good set makes all the difference on a HD truck.
  8. Nov 1, 2024 at 7:14 AM
    mtb_frk
    No I have not explored that option yet. I figure now is the time to decide go with a more practical truck like the tundra or put some money into the current truck and only use it for towing until the 2012 4runner dies.
  9. Nov 1, 2024 at 7:31 AM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    I have no problems towing our trailer, which I est to be approx 5500lbs loaded (w/40g water when boondocking, I still need to swing by a CAT Scale to verify). I live in the Phoenix area and frequently camp, year-round, with most of our trips consisting of a 5000'+ elevation gain...so lots of hills. MPG is atrocious with those climbs, typically 9'ish, but the Tundra handles it like a champ.
    I'm unsure of my exact TW but est it to be approx 750lbs plus the WD hitch I'm sure were maxed out with 2 adults and 2 dogs. I don't typically carry much gear in the bed anyway.
    In your search for a Tundra note the year that the factory trans cooler was no longer offered; 2019 if I recall...someone correct me on that.
    @SD Surfer has the same set up:
    KNABORES, SD Surfer and Florida AF like this.
  10. Nov 1, 2024 at 7:51 AM
    Florida AF
    Logan
    North Florida
    You are not crazy. But you have a lot to consider. I wanted a 250 or 350 for towing, but I hate driving those empty. Even with new suspension. I drive too many miles to be that miserable on the ride. The Tundra tows better than 2/3 of my Ram 1500's, but the MPG are terrible and there are limits. I need to hit a cat scale at the next run out of town, but when I typically camp with mine I have no issues. The last one was an evacution trip so I had more in the bed and I definitely noticed a difference, and not in a good way.
    TL/DR... you are not crazy, you should be good. Go to a Cat scale first and verify trailer specs.
    Tunrod and JMGmanAZ like this.
  11. Nov 1, 2024 at 7:54 AM
    BuzzardsGottaEat
    BuzzardsGottaEat New Member
    '16 Tundra DCLB
    Round Tires
    For whatever it’s worth, the Silverado 2500/3500 rides much smoother than the Ford offerings if you still want a 1 ton.
    That said, I like my Tunda DCLB infinitely more than our Silverados, obviously.
    Good luck!
  12. Nov 1, 2024 at 8:31 AM
    SD Surfer
    Bruce
    So Cal
    Yep, 10 is kinda' the magic number. Sometimes 9, sometimes 11, but I just budget for 10 MPG.
    Really doesn't seem to make much difference the size or weight of the trailer or what the tow vehicle is (unless it's a diesel)
    Frontal surface area (AKA Parachute) seems to have more impact on mileage than weight does. Towing takes power, and making power takes fuel, no getting around that.
    Your numbers are spot on and match my experience. In fact it's kinda' spooky how closely your numbers match mine, the only one that doesn't match is that we now have 3 dogs. (Cozy in the 1685)
    5,500 lbs. GVWR, and my TW's are typically from 700-750 lbs. I nearly always travel with full FW tank... known water source and I prefer the way the trailer handles with some TW.
    Most of our trips have similar climb/drops from sea level San Diego 5,000' up to the mountains, and often back down to the desert. If we camp in the mountains I use almost 1/2 my 38 gallon tank on the way up, and almost none coasting home down the hill.
    Tunrod, KNABORES and JMGmanAZ[QUOTED] like this.
  13. Nov 1, 2024 at 8:37 AM
    Tundra family
    Tundra family New Member
    For reference, I have a decent sized camper (about 1600 lbs) loaded in mine and I average 11 MPG with a mix of highway and city driving.
  14. Nov 1, 2024 at 8:45 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Whoa, whoa, whoa.
    Why not consider teh 3rd gen Tundroid? So many torks! Blows the 2/2.5 out of the water, so I've been told.
    PolishedTRD and JMGmanAZ like this.
  15. Nov 1, 2024 at 8:54 AM
    mtb_frk
    Well right now it’s price and looking for long term reliability.
    Ruggybuggy and hagrid[QUOTED] like this.
  16. Nov 1, 2024 at 11:20 AM
    The 6.2L is a good motor, and with some proper mods it can do better, but probably not enough to ever recoup your money.
    5Star Tuning is where I would start.
    For some reason people still think of tundra as a smaller truck. It isn't. You will get a better turning radius but still have the same difficulties day to day. The F-250/350 is taller....
  17. Nov 1, 2024 at 5:17 PM
    mtb_frk
    There is a 2021 SR5 with the sport package for sale by me. Anything different with this package that would make any difference in towing?
  18. Nov 1, 2024 at 5:25 PM
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    The added rear sway bar, stiffer front sway bar, Bilstein suspension, and 20” wheels of the TRD Sport package all lend themselves toward improved stability when towing.
    KNABORES likes this.
