Am I Crazy? Mirrors Adjusting In Reverse
Discussion in '3rd Gen Tundras (2022+)' started by WishfulWanderer, Dec 13, 2022.
  1. Dec 13, 2022 at 6:03 AM
    WishfulWanderer
    WishfulWanderer [OP] New Member
    2022 Tundra MGM Limited 4x4 Crewmax
    I have had my limited CM since around May/June of 2022. Maybe it is because I am normally looking at the backup camera instead of my side mirrors, but I have never noticed that they automatically adjust when putting the truck in reverse to give better visibility to the rear. This may be a feature in most trucks, and may have been in the previous generations before the tundra I had a 4Runner and a taco so this is my first full size. It has always done this though right? This isn’t something Toyota could add with a software update. I did just have my 5k mile service….
    I understand more likely it has always done that and I just never noticed before. I just thought it was a cool feature.
  2. Dec 13, 2022 at 6:08 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Our lexus does this. Pretty cool if they added this to the tundra....hopefully you can turn it off also, would be annoying if backing up a trailer.
  3. Dec 13, 2022 at 6:32 AM
    WishfulWanderer
    That I am not sure of yet, I haven’t looked in the settings for it. It is possible that with 7-pin connectors it disables it like the backup sensor but I have no idea.
  4. Dec 13, 2022 at 6:39 AM
    Gene5253
    Gene5253 New Member
    Gene
    Boise ID
    2020 Tundra CM Limited
    Easy to turn off. The knob on the ds door that is used to select mirror adjustment must be in either L or R to activate. Simple adjust knob to the center position and this disables the tilt down feature.
    G10dra, 22PlatWCP, TXBrit and 2 others like this.
  5. Dec 13, 2022 at 6:47 AM
    JUNNEL20
    JUNNEL20 New Member
    Junnel
    I concur with this procedure to turn it off. I find the automatic adjusting mirrors very helpful when I'm parallel parking. However, if I'm just backing into a trailer or parking spot, I easily just turn it off.
  6. Dec 13, 2022 at 6:53 AM
    WishfulWanderer
    Interesting, so that is probably all it is. I think I have always had the dial in the center, dealership maybe moved it to L/R which is why I am now seeing it function. Will need to check. The more you know and the things I learn from this forum.
  7. Dec 13, 2022 at 6:58 AM
    Limitrd
    Limitrd New Member
    Oregon
    22 Lunar Rock Limited Hybrid TRD Off Road CM 6.5
    You can adjust where your mirror tilts. Each one is independently adjustable.
    TXBrit likes this.
  8. Dec 13, 2022 at 7:30 AM
    hBaz
    hBaz New Member
    middle of nowhere south of OK City
    2021 black 1794 Edition with TRD package
    This thread helped for my new2me 21. Knew about tilt down in reverse but did not know that reverse positions also save with the memory buttons. Just went out to garage for test - works on 21. Sweet. Also did not know about disabling pivot down by putting adjust button to center - will be good for trailers.
    Thanks everyone.
    batman900 and Hippyhunter like this.
