Always On 12v Power for Topper/Camper Lighting
Discussion in '1st Gen Tundras (2000-2006)' started by pollymath, Mar 19, 2021.
  1. Mar 19, 2021 at 8:37 AM
    pollymath
    pollymath [OP] New Member
    2006 Limited DC 4x4 "Chunky Salsa"
    I want to add some LED lighting to my camper shell.
    I've successfully disable the cargo light and put it on an individual switch to stop throwing light on my sleeping family when I want to get into the front of the truck at night while camping.
    Next I'd like to add some lights inside the camp shell, as well as around the outside.
    Is there a power source at the back of the truck that's always on, or will I need run a line from the battery?
  2. Mar 19, 2021 at 8:37 AM
    My 7 pin trailer plug has an always on hot pin.
    2006Tundra and des2mtn like this.
  3. Mar 19, 2021 at 8:43 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Mine too, it's spliced and goes into my bed/ cap for power.
    FrenchToasty likes this.
  4. Mar 19, 2021 at 8:43 AM
    pollymath
    Ah ok. I assume it's AUX 12v:
    Dc2015, jerryallday and des2mtn like this.
  5. Mar 19, 2021 at 8:45 AM
    des2mtn
    SW
    Tonto cover
    Take the key out and confirm with a multi meter, but that should be it.
    Dc2015 likes this.
  6. Mar 19, 2021 at 9:18 AM
    pollymath
    No dice so far. 12v AUX doesn't appear to be hot.
    2006 DC Limited with factory installed tow package.
  7. Mar 19, 2021 at 9:23 AM
    Ericbike6
    Ericbike6 So we're doing this shit today?
    Eric
    Austin, TX
    2019 Tundra TRD 4X4 sport
    Air bags, ARK liners, misc bullshit added also
    Sometimes there is a fuse for this circuit, and it may not have the fuse installed, happened on my 2005 sequoia the first time I towed.
    Might be something to look at.
    I guess I should ask does it have power there when key is on?
  8. Mar 19, 2021 at 9:27 AM
    LittleTRD
    LittleTRD New Member
    James
    Central California
    2015 Tundra Crewmax
    Camburg UCA's, Fox Factory 2.5's Front & Rear, Coachbuilder +3 Shackles, Decked Bed System, Snugtop Rebel Shell, switch pros 9100, and baja designs for all additional lighting.
    2015 TRD Off Road- Mine only has power when the key is in on or acc position. No power when truck off keys removed
    jerryallday likes this.
  9. Mar 19, 2021 at 9:29 AM
    pollymath
    Any guesses on what the fuse/circuit is?
  10. Mar 19, 2021 at 9:36 AM
    costman13
    costman13 New Member
    Cam
    Oregon
    2003 AC Tundra TRD 4x4
    OME 2885, Nitrochargers, SPC UCA, Wheelers AAL, Firestone Ride-Rite Airbags, Method 701 & 285/75R16 Toyo Open Country AT III
    Why not just run a hot back there? Sure it's a bit of a larger project, but worth it IMO.
    You could add a small fuse block under the hood and pull from that to the bed. It's a nice way to future proof for accessories down the road.
    Or pull a larger AWG to the rear and put a fuse block in the back. That will give you options back there.
    Or do both?
    I find it nice to have individual circuits for each accessories, instead of tapping into existing circuits. Much easier to diagnose when things inevitably go weird.
  11. Mar 19, 2021 at 9:50 AM
    pollymath
    I wanted to determine if there was a possibility for something quick and easy. Got a lot of other projects going on right now and just wanted to add some lighting to the camper shell.
    If it's not easy, I'll pull 10g wire up to the battery, like you said, for future options.
  12. Mar 19, 2021 at 2:31 PM
    costman13
    Cam
    Oregon
    Yeah - I hear that.
    I would imagine there is a hot associated with the 7 pin... I know a buddy of mine pulled one to add a USB plug in the bed of his DC. I had initially assumed it was from the 7 pin, but now you have me second guessing.
  13. Mar 19, 2021 at 3:49 PM
    Wallygator
    This is what I would do. Mainly because once it's done right you will never have to mess with it again and can easily add whatever depending on the size of the fuse block. Also you should probably buy a jump pack, if you don't already have one, in case you drain the battery all the way down and can't start the truck.
    On a side note I power all my bed stuff from the solar system so it is completely isolated from the truck, it's been working out great. Recently went to Florida and the truck was parked for 10 days. Fridge, tent, lights, all powered off the solar the whole time. Never started the truck until the day we left.
    costman13[QUOTED] likes this.
  14. Mar 19, 2021 at 5:07 PM
    chunk
    chunk New Member
    110 miles north of Los Angeles, Ca.
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    How many watts of panel do you have? That's impressive. Just one battery??
    Wallygator[QUOTED] likes this.
  15. Mar 19, 2021 at 5:39 PM
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    I do the same as @Wallygator. I currently run a 95ah battery (happened to already have it) in the bed with a MPPT solar charge controller and a 100W solar panel on top of the topper. Used to run a 100W flexible panel on top of my tri-fold tonneau cover and that worked great before I installed the topper. Also have it rigged up with an AC-DC charger and DC-DC charger so I can charge it overnight if necessary from the wall or while driving if there's no sun.
    Wallygator and chunk[QUOTED] like this.
  16. Mar 19, 2021 at 7:05 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    I also have a 2006 DC with the factory tow package. I am almost certain that the 12v in the 7pin is ignition.
    I just ran an 8awg from my battery, along my frame to behind my driver side tail light. Behind there I mounted some cheap little 6 port fuse block and use that to power anything that I need inside my camper.
  17. Mar 19, 2021 at 10:36 PM
    des2mtn
    SW
    Tonto cover
    Now that's interesting. My factory 7-pin is spliced running into my cap and is hot at the plug. I'm curious if there's a difference between ours somehow or if there's something I'm missing.
  18. Mar 20, 2021 at 9:01 AM
    costman13
    Cam
    Oregon
    I've got the factory tow package on my 03 AC. I'll test for constant hot and report back...
    des2mtn likes this.
  19. Mar 20, 2021 at 11:34 AM
    chunk
    chunk New Member
    FWIW,I just checked my Tundra plug, looking at it from the rear, my pin # 3 on this diagram is hot with the truck not running and key off. 2001. I was looking at my install notes from 20 years ago, and I have the center pin labeled as an "extra" circuit.
    des2mtn likes this.
  20. Mar 20, 2021 at 3:38 PM
    jimf909
    jimf909 Battery almost dead...
    Washington or Idaho
    '03 Tundra SR5 AC 4.7 TRD w/LSD
    Dead stock with oem 16" starfish wheels. We'll see how long that lasts. :) Topper of unknown origin.
    Ha! We're all going out and checking out trailer plugs.
    My '03 with factory trailer wiring (per the build sheet) is wired as indicated in the diagram above. #4 aux 12v is only powered with the ignition on. #3 is powered with the taillights on, regardless if the key is in.
    The PO ran a fused wire from the battery back to the cap for lighting in the bed.
    des2mtn likes this.
  21. Mar 20, 2021 at 3:52 PM
    Wallygator
    It's a Renogy 160 watt panel.
    chunk[QUOTED] likes this.
  22. Mar 20, 2021 at 4:05 PM
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    This is beginning to make me wonder if there is a 2 position, 3 pin fuse located somewhere. There can’t be this much variation.
    des2mtn likes this.
  23. Mar 20, 2021 at 5:24 PM
    chunk
    chunk New Member
    I think mine is wired the same as yours. I'm going check all the pins tomorrow, truck running, ignition on, not running, and key out and will post the results.
    Edit for update:
    I looked at my plug this morning, with a multi-meter in hand, and it is wired the same as this diagram. Just FYI.
    des2mtn and Tundra2 like this.
  24. Sep 10, 2021 at 8:54 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Did you ever figure it out? I have the same truck, I added lights to the shell bed today and taped pin #4. It only powers on when the key is the ignition.
    going to run a wire to the battery most likely.
  25. Sep 13, 2021 at 6:26 AM
    Teutonics
    Teutonics BestGen Member
    2005 DC SR5 4WD
    Just a friendly reminder to install a fuse in-line somewhere close to the originating power source.
    I was doing some work on my truck recently, and found that a prior stereo installer ran a 0awg wire from the battery to the amps with NO FUSE. The problem I was diagnosing was a loose wire at a distribution block.... if that had come out and grounded, or worn through the sheathing? Yikes.
    Wallygator and shifty` like this.
  26. Sep 13, 2021 at 9:24 AM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Got it. The wire has a fuse but it’s next to the on/off switch in the bed of the truck. Should I move it next to the battery?
  27. Sep 13, 2021 at 9:36 AM
    Teutonics
    2005 DC SR5 4WD
    As close to the battery as possible.
  28. Sep 13, 2021 at 9:37 AM
    You always want to fuse or breaker your power leads as close to the power source as possible. If your fuse is at the bed/switch, what happens if you ground out in the cab?
    When we were entering cars in IASCA competitions back in the day, IIRC the regulation was to have a fuse within 18" of the battery for all power leads elsewhere.
    Wallygator and MrDirtjumper like this.
