Always hot 12v outlet?
Discussion in 'General Tundra Discussion' started by scpete24, May 15, 2017.
  1. May 15, 2017 at 11:42 AM
    scpete24
    scpete24 [OP] Duuuuuuude
    Orange County, CA
    2016 TRD Pro Super White
    On my tacoma, I was able to mess with the relay and make the 12v outlet always hot/on so I could charge things when the key was not in the ignition. Has anyone seen or done something to this effect with the Tundra? I'm not worried about draining my battery as its mostly for charging cell phones/small devices while I'm at the gym or away from my truck.
    Thanks in advance for any responses
  2. May 15, 2017 at 12:01 PM
    n2deep
    n2deep Pavement Princess
    I just rewired mine so I had them hot all the time. Upgraded to 10ga wire too - instead of that tiny factory stuff they used.
  3. May 15, 2017 at 12:04 PM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    I rewired one of mine while I was pulling cable for off-road lights. I just pulled a new (+) wire and spliced it to the receptacle. Don't forget to insulate the old (+) because it will be hot whenever the ignition is on.
    scpete24[OP] likes this.
  4. May 15, 2017 at 1:12 PM
    ramonortiz55
    ramonortiz55 I don't Even Own A Tundra
    Ramon
    2001 4runner, 2015 tacoma
    If you can find the relay for the outlets, I can get you a write up for this
    scpete24[QUOTED][OP] likes this.
  5. May 15, 2017 at 2:42 PM
    R0CKETMAN
    R0CKETMAN IG: @rocketmanmtb
    NGAMTNS
    '17 TUNDRA TRD PRO CEMENT ‘15 TUNDRA SR-5 WHITE
    I need this for a pending project.
  6. May 15, 2017 at 3:44 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I'd like to do this as well. So no one has a DIY write-up about it, hmmmm.......:annoyed:
  7. May 16, 2017 at 5:13 AM
    ramonortiz55
    Ramon
    https://www.4runners.com/threads/always-hot-power-outlets-pictures.665/
    This is the write up I did for 4runners.
    The steps are exactly the same for a tundra, just need to locate the relay for the power outlets.
    Flyinryank likes this.
  8. May 16, 2017 at 6:12 AM
    ramonortiz55
    Ramon
    Nope. Doing this mod provides power to your outlets FULL TIME. Truck off or on.
    If you did this mod to your fog light circuit, it will leave your fog lights on FULL TIME. Truck off or on, fog light switch off or on.
  9. May 16, 2017 at 6:13 AM
    ramonortiz55
    Ramon
    it will leave your fog lights permanently on. Even if your fog light switch is set to off.
  10. May 16, 2017 at 7:16 AM
    ramonortiz55
    Ramon
    ask me how I know :anonymous:
    Luckydog, JC303 and NewImprovedRon like this.
  11. May 16, 2017 at 11:29 AM
    scpete24
    Orange County, CA
    thank you guys for all the responses. I will try to find the relay as that seems to be the easiest option. If I fail there then I'll just find a always hot wire and splice into that. Will keep you guys posted if I can find the relay...
  12. May 16, 2017 at 11:39 AM
    n2deep
    Careful if you splice into another hot wire you could overload that circuit and blow fuses or worse. Worst case run a new circuit with the proper gauge and fuse for what you plan to use it for.
    ramonortiz55 likes this.
  13. May 23, 2017 at 8:57 PM
    IB-IN-YA
    IB-IN-YA RUNAMUK !!!!!
    Republic of Texas
    2017 TRD PRO TUNDRA
    I have a radar connected to my review mirror wires. If I did the mod to my charging sockets would it also put power up to my radar. ???
    I just want my charging sockets to work with out ignition on
    Cheers
  14. May 24, 2017 at 5:24 AM
    ramonortiz55
    Ramon
    If you did this mod it will power up anything you connect into that socket.
  15. May 25, 2017 at 9:13 AM
    IB-IN-YA
    Republic of Texas
    2017 TRD PRO TUNDRA
    My radar is not plugged into the socket.its hard wired in to the rear view mirror ignition on for power.my question is if I do the mod will it make the rear view mirror always hot also.
    Thanks
    Cheers
  16. May 25, 2017 at 10:21 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    10ga is way overkill. Need to match wire to breaker. On 15A breaker 16 is fine with DC.
  17. May 25, 2017 at 11:07 AM
    n2deep
    I never said it has a 15a breaker. I ran a whole new circuit and disconnected the factory wire. Now I can run my portable inverter that the factory setup wouldn't support.
