Aluminum Radiator Suggestions/ Advise
Discussion in '1st Gen Tundras (2000-2006)' started by tuner429, Oct 21, 2021.
  1. Oct 21, 2021 at 10:45 AM
    tuner429
    tuner429 [OP] New Member
    Sergio
    2006 White Tundra Double Cab
    Stock for now
    Hello everyone, I sincerely apologize if this has been answered before.. I did perform a search but came up empty to a certain degree.
    I am interested in purchasing an aluminum radiator for my 2006 double cab. The bottom end tank is starting to ever so slightly seep which I noticed on the last oil change I did. The ones I can find are for single cab or access cab or ones that simply don't state that they are compatible with the double cab models.
    Anyone have any experience with certain brands and or fitment issues?
    Thank you in advance
  2. Oct 21, 2021 at 11:15 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
  3. Oct 21, 2021 at 11:21 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
  4. Oct 21, 2021 at 12:53 PM
    tuner429
    Sergio
    Stock for now
    i looked at both specs and the coldcaseradiators are .6 inches taller. I dont know if that is enough of a difference between the mishimoto radiator at 27.00 inches which specificallyt states not for double cabs. (w/ out double cab). I have emailed coldcaseradiators just to make sure on fitment
  5. Oct 21, 2021 at 12:57 PM
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
  6. Oct 22, 2021 at 9:29 AM
    tuner429
    Sergio
    Stock for now
  7. Oct 22, 2021 at 9:38 AM
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    I have had it going on 2 years no problem what's so ever. Only issue with going with a thicker rad is that the lower hose will get to close to the pully and make a hole in it. So I used a 1½ greenfield hanger to hold it out of the way.
    bmf4069 likes this.
  8. Oct 22, 2021 at 10:01 AM
    Tagging @Tundra2 because that hanger solution may actually work for his setup as well.
    Dave8699 likes this.
  9. Oct 22, 2021 at 10:01 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    im rocking a custom radiator from radiator supply house. i tried a CSF at first but the double cab was what it was designed for... so i went full custom... $$$ but man.. its amazing at keeping everything rock steady. my engine has never gone past 184 with this radiator even towing close to max capacity for 400 miles. trans temps improved too. highest i saw that trip was 200. before with the tow package cooler and stock rad 200 was not uncommon when unloaded in traffic...
  10. Oct 22, 2021 at 10:02 PM
    empty_lord
    05 rollover special
    the cold case and the CSF will hit the hood on an access and reg cab. so mishimoto is the only option. and i THINK they include trans coolers now.. but not sure.
  11. Oct 23, 2021 at 11:09 AM
    RR60
    RR60 New Member
    2003 SR5 Tundra long bed
    Curious, do you remember about what it cost. I remember looking and could not find a aluminum one that did not have bad ratings.
  12. Oct 23, 2021 at 11:30 AM
    empty_lord
    05 rollover special
    Around 800 shipped.
