Alternators dying after new HU install?
Discussion in 'Audio & Video' started by justKEV37, Sep 8, 2021.
  1. Sep 8, 2021 at 11:40 AM
    justKEV37
    justKEV37 [OP] New Member
    Austin
    2005 Tundra 4.7
    So, I recently installed a new stereo HU in my wife’s ‘05 Tundra. The alternator died shortly after, and I just replaced it. Now it is dying again. The alternator is 130 amp. The new stereo has a built in amp rated at 4x55w of power. Would leaving the factor amp connected be causing the issue?
    I am very much a novice when it comes to these things, but I checked all the wire connections, and they look good.
  2. Sep 8, 2021 at 11:45 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    New or rebuilt parts can be bad right out of the box. You can verify the current the alternator is putting out to see if it is bad and I would also test your battery, it could be bad or have a deal cell.
    TheBeast and 15whtrd like this.
  3. Sep 8, 2021 at 11:47 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Alternators fail, not uncommon with age. What you are describing sounds more like a battery that would be failing.
    Did you have the old alternator tested? The replacement could be bad luck. Have you had it tested?
  4. Sep 9, 2021 at 6:43 AM
    justKEV37
    Austin
    2005 Tundra 4.7
    I haven’t had the new alternator tested yet, but the battery is less than a week old. I figured I’d change them both at the same time.
  5. Sep 9, 2021 at 7:00 AM
    justKEV37
    Austin
    2005 Tundra 4.7
    Also, the truck ran perfectly with the new alternator for 3 days before I reinstalled the stereo.
  6. Sep 9, 2021 at 7:14 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Where'd you get the new alternator? Stick with Denso reman. We had another member get one from the local auto parts store and it was bad also.
  7. Sep 9, 2021 at 7:31 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    You need to retrace every last little item you touched. Then look adjacent and make sure you didn't bump something.
    And the belt. You've mentioned you're a newbie/novice. How do you know the alternator belt is tensioned correctly? Push perpendicular on the alternator belt with just moderate force of a single finger. Then report back how far that belt is deflecting.
  8. Sep 9, 2021 at 8:31 AM
    justKEV37
    Austin
    2005 Tundra 4.7
    Ok, I’ll check that.
  9. Sep 9, 2021 at 8:31 AM
    justKEV37
    Austin
    2005 Tundra 4.7
    I got the alt from oreillys.
  10. Sep 9, 2021 at 9:43 AM
    justKEV37
    Austin
    2005 Tundra 4.7
    Just checked the tension. It moves, but very little. Maybe a 1/4” of room
